Light Switch Mounting: Up or Down Position, Trends, Standards, and Installation Guidelines
sebo 81730 14
How should a light switch be mounted—so that pressing up or down turns it on—and is this regulated by a standard?
For ordinary home lighting switches, the thread says there is no specific standard, but the common convention is that pressing the upper part turns the light on [#4486203][#4489243] Some participants note that general ergonomic standards such as PN-EN 894 and PN-EN 61310 define the direction of activation/increase as up for vertical controls and right for horizontal ones, but another reply says these standards do not really apply to the most common household light switches [#4489281][#4489839] The practical advice repeated in the thread is to keep all switches mounted consistently, usually with the ‘up’ position meaning ON [#4486171][#4494782]
  • #1 4486108
    sebo
    Rate: 14
    I have a trivial but I think a matter-of-fact question. How should the light switches be mounted? They are to be turned up or down.
    Is it just a matter of a trend or is it regulated by some standard :?:
  • #2 4486171
    PAWEŁ74
    Help: 78
    Rate: 119
    I do not know if it is regulated by a standard, but I remember when I was in a construction site where I did automation, an electrical installation inspector ordered an electrician to move all the switches so that the light was turned on after pressing the lower edge of the switch ...
    I was a bit surprised by such an order ... But after this fact I noticed how such switches are mounted and in 99% of them they are mounted as ordered by the inspector ...
  • #3 4486203
    hur
    Rate: 35
    There are no and never have been any standards in these matters.
    However, I have encountered a recommendation that, for example, the lift switches in staircases should be installed in such a way that when turned on, the * lever * is at the top. This was explained by the fact that when turned on the reverse, the weight * of the lever * in the upper position as turned off, could accidentally fall with its weight and activate the circuit.
    They were old * knife * switches.
    I didn't notice any rules with the key breaks.
  • #4 4486208
    sebo
    Rate: 14
    I also personally assemble the switched-down ones and most of my electrician friends. But there are also supporters of the reverse version, and we almost did something on the construction site. Dloatego, I want to approach this matter substantially and explain it.
  • #5 4486224
    mada30
    Help: 8
    Rate: 25
    My foreman from the Guild of Various Crafts (pre-war) gave me many "golden rules" that work to this day, including:
    -do not believe anyone, especially yourself - check DISCONNECTION 2 times!
    - always switch it on with the lever up!
    -check the covers with the OUTSIDE of your hand!
    -if you are looking for a short circuit in the circuit, switch all the switches of this circuit ONCE!
    I have never inquired why this is so (upwards) but it seems to me that it is related to the natural human reflexes, a wave downwards means negation.
    At that age, an exclusion was used. Lever (resembling overcurrent breakers, e.g. S301-attached top)
    Maybe there is actually a standard for it?
    Or is it "Good Practice"?
  • #6 4488761
    ANDYW6
    Help: 39
    Rate: 303
    There is no standard, because what to do with staircase and cross switches.
  • #7 4488858
    jacur
    Level 32  
    Help: 166
    Rate: 296
    The matter is simple, if the switch in the off state will stick out with the upper part of the flap, dust will collect there, and when the lower one sticks out when it is turned off, the dust collects only when turned on ;)
  • #8 4489243
    Andrzej-65
    Help: 8
    Rate: 31
    This topic was discussed at the SEP Forum, and probably also at Elektroda. There is no standard, but switching up is assumed, as well as in the sockets the phase on the left side, the pin up.
    Greetings.
  • #9 4489281
    kaputo
    Help: 37
    Rate: 128
    Mates. Exactly that there are standards that regulate it. Take a look at PN-EN 894, PN-EN 61310. In short, it looks like this:
    The activation or increase of the parameter is always:
    - if the buttons are vertical, then the top one
    - if the buttons are horizontal, then the right one
    - if the button is pressed bistable, it is forced to inhale
    - if there is a knob, turn it to the right
    - if there is a lever, it is up or to the right.
    and a few more cases I just don't remember.
  • #10 4489775
    andwod
    Rate: 8
    switches should be built in such a way that a person
    standing before tipping over (or falling) hitting a switch turned it off.
    Zal up
    Piss on down
  • #11 4489839
    lukas1850
    Help: 6
    Rate: 30
    But neither of these cases can be applied to the most popular home lighting switches.
    Honestly, he convinced me the most jacur .
  • #12 4489868
    kleki
    Help: 95
    Rate: 142
    I have the opposite of what Col. Kaputo suggests. ;-) It turns down. I enter the room, it is dark. I am looking for the switch with my hand on the wall rather from the top, so it's more comfortable for me. I will always ask the client if he prefers. I prefer not to fall over there. ;-)
  • #13 4494782
    dariooo
    Hello ! An old and trivial problem! It is important that they are all mounted the same! :D This proves the diligence of the contractor. :D
  • #14 4496502
    krzysztof_93
    it's good to go down and it's better that everyone should always do this because the problem appears when there is no light and we have to go somewhere, if we do not know it, it will turn out that after coming home we had all the lights on, and if we were not there 2 weeks it cost us a little extra
  • #15 4496636
    sebo
    Rate: 14
    Summing up, no matter how the "up" and "down" supporters are, the only argument I have heard about this is the one Jacur quoted about the dust collecting. You could conduct a poll on this but as for me "down" For ever!
The discussion centers around the mounting position of light switches, specifically whether they should be oriented upwards or downwards. Participants note that there are no formal standards governing this practice, although some recommendations exist, such as installing switches so that the lever is up when activated. This is believed to align with natural human reflexes and safety considerations. Some users prefer downward switches for ease of access in low-light conditions, while others argue for uniformity in installation. The conversation also touches on practical aspects, such as dust accumulation and the importance of consistent installation for contractor diligence.
