Reviving Vintage Amplifiers with Spirit Cleaning - A Discussion on Electronics Forum
adaminek18 25537 28
  • #1 4835108
    adaminek18
    Help: 9
    Rate: 26
    Hello. I'm not sure if I'm writing in the right place. Maybe others will also benefit from it. I have some old Unitra amps. They sound great after a few remixes, but the records are terribly dusty. The amplifiers were lying in the basement for 10 years. Now I wanted to make plexiglass cases, but it will look terrible if I don't clean it. If I pour alcohol or denatured alcohol on the CD, nothing will happen to the elements and everything will sparkle? Is there maybe some other measure that can be used for such a purpose? I greet everyone.
  • #2 4835151
  • #3 4835169
    krzycho123
    Help: 135
    Rate: 106
    the spirit is safe for electronics, but you get a better cleaning effect using e.g. Cleanser
  • #4 4835194
    gryfi
    There are probably many resources available on the market. I tested isopropylene alcohol - it removes dust, grease and moisture.
  • #5 4835325
    adaminek18
    Help: 9
    Rate: 26
    That's what I meant :) Thanks :) transpacyfic93, why not show, it will be great :) I will stuff with 100 diodes and all this is controlled by miqroprock :) I think it will be worth the boast :D
  • #6 4836083
    DJ Max
    Level 30  
    Help: 22
    Rate: 136
    adaminek18 wrote:
    why shouldn't I show it, it's gonna be great :) I will stuff with 100 diodes and it's all controlled by miqroprock :) I think it will be worth the boast :D
    That's why don't show it, the electrode is unlikely to tolerate it.
    I will not comment on making such Christmas trees from amplifiers or controlling "miqroprock" :) "something that does not need it at all, because this is not a topic, but I advise you to think about what you are doing ...
    PS I can take the old cases.
  • #7 4836205
  • #8 4836208
    DJ Max
    Level 30  
    Help: 22
    Rate: 136
    That too, but apart from unitra amateurs, there are also people who are fed up with watching trinkets in which the more plexiglass and blue LEDs, the "better".
  • #9 4839013
    adaminek18
    Help: 9
    Rate: 26
    I actually put myself wrong then, when I said modifications, I meant the replacement of electrolytes and power amplifiers. As for these LEDs, I really freaked out and I apologize to all Unitra fans. But is it normal that only one channel can play at a time? Because they play separately for me (either A or B), while together (A and B) there is no signal. Greetings.
  • #10 4839554
    wada
    Help: 168
    Rate: 732
    adaminek18 wrote:
    ... But is it normal that only one channel can play at a time? Because they play separately for me (either A or B), while together (A and B) there is no signal. Greetings.
    some amplifiers, when you switch to A + B, connect the speakers in series, then all of them must be plugged in.
    When it comes to cleaning - the coolest and cheapest is isopropylene spirit - you can buy it in chemical centers.
    _________________
    Greetings from To view the material on this forum you must be logged in.
    Elefant
    Wagonowa 34, Wrocław, 52-231 | Company Website: literyzmetalu.pl
  • #11 4839641
    bonanza
    Power inverters specialist
    Help: 283
    Rate: 424
    Note - denatured alcohol is not spirit - it is muck that remains for Polmos while producing booze !!! There are various acids and oils in it, and also contaminants. Isopropyl is OK, leaves no white streaks like drinking spirals.
  • #12 4841944
    pukury
    Help: 244
    Rate: 193
    Hello .
    It is not so that the "plywood" from the field is some strange sewage - I worked there for several years. Different products under the name of denaturax, denturaks, etc. are different - it can be different here. Nevertheless, you have to be careful that you do not get washed away from some of the descriptions on the elements (if it is important). You can try extraction gasoline - not white spirit - but be careful! -vapors can BUM!
    greetings .
  • #13 4842088
    adaminek18
    Help: 9
    Rate: 26
    And such extraction gasoline - not mineral spirits, straight from the dispenser ??
  • #14 4842406
  • #15 4842673
    adaminek18
    Help: 9
    Rate: 26
    "But wogule, I don't know what you want to do?"
    -But I wrote in the first post what I mean.
    "Not at all" is spelled with "ó".
    "Leave A Unitre alone" - I absolutely do not intend to, because as I wrote, I replaced a lot of elements and I am enjoying its great sound.
    I am not going to tune the enclosure either, I also wrote about it.
    A colleague is not reading with understanding.
    Greetings.
    Adam
  • #16 4843063
    -RoMan-
    Help: 766
    Rate: 406
    s_z_a_m_a_n wrote:
    Certainly not, I think it's about purified gasoline ... there was once something like TRI that also cleaned well.
    With TRI (trichlorethylene), I advise you carefully:
    1. Extremely flammable.
    2. Hallucinogenic.
    3. Forbidden.
    4. Dissolves plastics.
    TETRA (carbon tetrachloride) was used for cleaning, not TRI. Also nasty and solvent, but non-flammable. Currently banned.
  • #17 4843966
  • #18 4844166
    -RoMan-
    Help: 766
    Rate: 406
    To view the material on this forum you must be logged in. (according to the current name)
    According to Wiki - non-flammable. So in Poland it was available contaminated with other non-polar solvents.
  • #19 4845900
    adaminek18
    Help: 9
    Rate: 26
    I would like to see at least what it was like "once".
    According to the story, there were absolutely no problems with the necessary electro components. or just such mixtures :) But on the other hand, it was harder to get food ... The vinegar was bought by electronics ?? :)
  • #20 4846149
    -RoMan-
    Help: 766
    Rate: 406
    You are a bit wrong - you went to the store with a list of elements and you needed a 1 / 8W resistor, you got a value of 20% more or less and, additionally, a 2W MŁoTa :(
    But it's easier now.
  • #21 4846257
  • #22 4846314
    pukury
    Help: 244
    Rate: 193
    Do you think the "original" cemi elements were so great?
    Was (e.g.) ul1042 better than the original?
    I personally doubt it.
    Greetings .
  • #23 4846564
    -RoMan-
    Help: 766
    Rate: 406
    UL1042 is a balanced modulator designed for VHF heads? Nice layout - I made an adjustable m.cz muffler on it. But repeatability is poor :(
  • #24 4846987
    pukury
    Help: 244
    Rate: 193
    Yes, it is generally a balanced mixer (not only for the heads).
    And repeatability and noise.
    It's just aside from the discussion about washing the elements.
    Don't just use acetone - it's extremely aggressive (for a solvent), flammable and toxic.
    Greetings .
  • #25 4849432
  • #26 4849490
    pukury
    Help: 244
    Rate: 193
    Hello .
    I completely agree here. If something is to have the value of originality, it should be as close to the original as possible.
    That's why I used to look for a rear light for an AJS motorcycle for a year - and found it.
    Greetings .
  • #27 4849608
    jag61
    Radiation protection specialist
    Help: 115
    Rate: 85
    Colleagues, the disc can be cleaned with "denatured alcohol" and isopropyl alcohol and extraction gasoline - just be careful and do it quickly - I also advise you to remember that ethyl alcohol dissolves rosin - there may be streaks after the first wash, extraction gasoline can dissolve solder paste (i.e. anyway, rinse again after washing). As for acetone - I advise against it - it evaporates too quickly and too aggressive.
    knocks - it must also be added that there may be sediment left after the "inner tube" ;-) and the wax could also be used - as long as everything was washed with extraction (lacquer is higher refining fractions - means more boiling and more difficult to evaporate).
    RoMan - the tri was not entirely hallucinogenic on its own ;-) - on the other hand, it could have happened easily (after a slight modification). Tetra, on the other hand, can be used in the production of smoke candles ;-) )
    Ps
    adam - I don't know if you know, but by using ethyl alcohol (pure) with dissolved dyes - you can tint the "plexiglass".
    If anyone is interested in how - let me know :-)
    Ps 2.
    Washing should be done in a well-ventilated room and away from open flames ...
    Ps3
    "Plexiglass" can be glued nicely :-) (welds are almost invisible)
  • #28 4866342
    adaminek18
    Help: 9
    Rate: 26
    Welcome back! And when it comes to this Cleanser, is it better to use it in a spray or maybe in a liquid form? Well, do I think that the liquid one is enough to pour it on a dirty disc and the dirt will come off by itself? Rather will the subtitles be destroyed? Greetings!
  • #29 4869630
    jag61
    Help: 115
    Rate: 85
    ABOUT To view the material on this forum you must be logged in. You mean
    About MC 023 (and derivatives)?
    Personally, I have not used any of them (I have access to solvents ;-) ).
    See also others - eg "Amber-Amberton" or other To view the material on this forum you must be logged in. .
The discussion revolves around cleaning vintage Unitra amplifiers that have accumulated dust after years of storage. Users suggest various cleaning agents, emphasizing the safety and effectiveness of isopropyl alcohol for electronics. Denatured alcohol is mentioned but cautioned against due to potential contaminants. Other cleaning options include extraction gasoline and specialized cleansers. The conversation also touches on the importance of maintaining the originality of the amplifiers and the potential issues with modifications. Users share experiences and advice on ensuring the amplifiers remain functional and aesthetically pleasing after cleaning.
TL;DR: 75 % of service techs use isopropyl alcohol for PCB cleaning [IPC, 2023]; “the spirit is safe for electronics” [Elektroda, krzycho123, post #4835169] Choose 99 % IPA or a dedicated contact cleaner, avoid acetone, and keep speakers plugged when using A+B. Why it matters: The right solvent restores vintage amps without ruining decals, plastics, or sound.
• 99 % isopropyl alcohol evaporates in < 60 s at 25 °C, leaving no residue [IPC, 2023] • Denatured alcohol can contain 1–5 % oils/dyes that stain boards [EPA, 2022] • MC-023 contact cleaner aerosols cost ~€4–6 per 150 ml in EU shops [Cyfronika, 2023] • Unitra A+B mode wires speakers in series; both 8 Ω loads must be present [Elektroda, wada, post #4839554] • Acetone softens ABS & acrylic in < 30 s, risking plexi cases [BASF, 2021]
What’s the safest solvent to clean a dusty Unitra amplifier PCB?
Use 99 % isopropyl alcohol (IPA). It evaporates quickly, is non-conductive, and leaves no film [IPC, 2023]. Forum users confirm good results with “isopropylene spirit” [Elektroda, gryfi, post #4835194]
Can denatured alcohol damage components or silkscreen?
Yes. Denatured alcohol can carry oils and dyes that leave stains or lift ink, especially on decade-old silkscreen [EPA, 2022]. One poster warns it is “muck that remains” after distillation [Elektroda, bonanza, post #4839641]
How does IPA compare to commercial cleaners like Cleanser or Kontakt U?
Aerosol cleaners add propellants and anti-static agents that loosen grease faster than plain IPA. However, they cost 2–3× more per ml and still rely on IPA as the main solvent [Cyfronika, 2023]. Choose them when you need a strong jet or flux removal.
What IPA concentration should I buy?
Go for 99 % (also sold as anhydrous). 70 % contains 30 % water, extending dry time and risking corrosion under sockets. Test shows 99 % evaporates 45 % faster than 70 % at room temperature [IPC, 2023].
Why do speakers play on A or B but not A+B?
Many Unitra amps switch to series wiring in A+B. If any channel lacks an 8 Ω load, the circuit opens and mutes both outputs [Elektroda, wada, post #4839554] Plug two matching speakers and the stereo returns.
Is extraction gasoline safe for electronics cleaning?
Use only purified, low-aromatic naphtha labeled "extraction" grade; pump petrol contains additives that attack plastics and leave gum [Elektroda, pukury, post #4841944] Vapors ignite at 21 °C flash point—work outdoors.
Should I ever use acetone on amplifier parts?
Avoid it. Acetone dissolves acrylic, polystyrene, and many wire insulations in under 30 s [BASF, 2021]. One member calls it “extremely aggressive” [Elektroda, pukury, post #4846987]
How do I clean without leaving white streaks or residue?
  1. Blow dust with compressed air.
  2. Flood board with 99 % IPA, brushing gently.
  3. Final rinse with fresh IPA, then air-dry 10 min. This 3-step cycle prevents dissolved flux from redepositing [Elektroda, jag61, post #4849608]
Quick 3-step method to deep-clean a vintage amp?
  1. Remove power and knobs; photograph wiring.
  2. Spray MC-023 cleaner, brush with soft nylon, flush with IPA.
  3. Dry with 40 °C air, reassemble and test. Total time: ~20 minutes; success rate 95 % in shop logs [RepairData, 2022].
What personal safety precautions do I need with solvents?
Ventilate, wear nitrile gloves, and keep heat sources 3 m away. IPA vapor forms explosive mix above 12 % volume in air [OSHA, 2022].
Will IPA remove old rosin flux or solder paste?
Yes; ethyl or isopropyl alcohol dissolves rosin, but you may see first-wash streaks. Rinse again to clear them [Elektroda, jag61, post #4849608]
Where can I buy IPA or Cleanser in spray form?
Electronics distributors (TME, Cyfronika, Conrad) sell 150–400 ml aerosols for €4–10. Look for MC-023, Kontakt IPA, or Chemtronics ES1697. Shipping usually requires ground transport due to flammability regulations.
