Car Paint Quantity: Estimating Varnish & Waste for a Fiat Punto in a Spray Booth
Tremolo 134306 11
How much varnish and spray waste should be estimated for painting a Fiat Punto in a spray booth?
There is no exact universal amount, but a practical estimate for a Fiat Punto is about 1.5–2 liters of acrylic paint for the car, which becomes roughly 3–4 liters of sprayable mix in a 2:1:1 ratio, and about 30–50% may end up as overspray/waste depending on the gun and painter [#5054169][#5050727] Paint consumption also changes with the number of coats, whether the inside/engine bay is painted, the color, and the car's complexity, so real use for a medium car can vary from about 1 to 4 liters [#5025506][#5028326] One reply also noted that roughly one-third of the total amount is solvent that evaporates [#5028326] High-pressure guns were cited at about 50% efficiency, while HVLP/LP guns were cited at about 70% efficiency [#5050727]
  • #1 5024470
    Tremolo
    Help: 1016
    Rate: 497
    It's hard for me to get such data, but when it comes out more or less - let's say we have the whole car already phosphated and we start painting with a gun in the spray booth - how much varnish will come out of it and how much waste will be there. Such estimated information cannot be obtained, but I need it for my diploma thesis.
    As an example of a car, let's say Fiat Punto. Maybe someone works in the paint shop? Maybe someone has a car paint container with them and the performance is given there?
  • #2 5025506
    turpik5
    Help: 19
    Rate: 105
    It's hard to say how much paint goes on the car. It depends on many factors. What paint, how many layers, how complicated is the car structure, will it be painted inside (engine compartment, etc.) and maybe who is also painting. How much paint goes into the air depends on the method of painting, where to paint and who is painting.
  • #3 5027595
    Tremolo
    Help: 1016
    Rate: 497
    From what I read briefly, this car has about 19 m2 - parts of the exterior of the Nissan Primera. The engine is probably cataphoretically covering. And for such a medium-sized car, 5 liters are available. Only how much of it drips off as SLUD and how much will evaporate. An average for the varnish is enough and let's say someone knows about it.
    Let's say we have one backing layer and 3 outer layers. I do not know what is the matter with the inner part of the car body, how many layers are there. Perhaps I am interested in the data on how much paint sludge in the spray booth per car is. Let's say a paint shop of 20 cars and how many barrels of sludge they produce ...
    marcys20
    Help: 21
    Rate: 49
    Tremolo wrote:
    It's hard for me to get such data, but when it comes out more or less - let's say we have the whole car already phosphated and we start to paint with a gun in the spray booth
    on a medium size car such as Ibiza mk1 goes from 1L to about 4L - it all depends on:
    1. the skills of the painter
    2. whether we change the color of the car
    3rd varnish manufacturer
    4. the color of the paintwork
    so as you can see the forks are huge and it's hard to say exactly how much of it will come! some varnishes / colors cover the other better, the other one ... on average, about 1/3 of the total amount is a solvent that evaporates, a certain amount goes into the air as waste / blow, etc., etc ... and it is impossible to accurately determine how much we the paint will come off, therefore there is no ntt data!
    Dee Jay Gucio
    Help: 15
    Rate: 31
    At work, you can enter the amount, e.g. 3L, if they have any questions where this info comes from, answer that yesterday you painted such a car, not a questionable argument. But seriously, check this forum http://www.farby.brcs.pl/phorum/list.php?f=1 Regards
  • #6 5039838
    Tremolo
    Help: 1016
    Rate: 497
    I had an apprenticeship in a steel coating factory and so far know the exact proportions of the ingredients inside. It would be useful to analyze how many guns are blown out in addition to the paint of solvents and how many do not hit the car because the sum sumarum with more cars appears sludge.
    Because if you count that 1 liter is enough for 20m2 and covers a 20um layer, we have a layer with a volume of 0.4 liter = 20um x 20m2 only 0.6 liters evaporated somewhere. I understand that there is a contraction, I will evaporate a little on the way, some will stay on the gun. But how much paint will not go under the car, to the sides of the cabin, to the filter, to the water vacuum, etc. in combat conditions.
    The work is about varnish sludge. Because recently they put one in jail for keeping such buckets in a bricked-up room. Well, looking at their properties, they can be used to make everything, burn it, make damping materials for the car ...
    Dee Jay Gucio
    Help: 15
    Rate: 31
    It all depends on the effectiveness of the gun, HP high-pressure guns have, from what I remember, about 50% efficiency, i.e. only half of the paint goes to the painted surface, while (HV) LP (low pressure) have an efficiency of about 70% (but for painting with such guns you need an efficient hand) it all depends on the manufacturer of the gun.
    ŚNIADY
    Rate: 19
    Hello. As my previous speaker wrote, the dust goes from 30 to 50% depending on the gun. To paint Punto in acrylic, I would buy 1.5 or 2 liters of paint (if I mixed it in accordance with the 2: 1: 1 ratio, I would get 3 or 4 liters) depending on whether the center would be painted. Of course, the amount of paint also depends on the color, because not all of them cover the same.
  • #9 5055386
    adam7009
    Help: 656
    Rate: 1635
    the ratio of the varnish is 2: 1 and max. 10% solvent for acrylic varnishes, for base varnishes 2: 1 and 1: 1 depending on the manufacturer, we do not dilute water-based varnishes, they are immediately ready for use and are still more efficient than the others. As for the efficiency, there are differences depending on the gun and the ability of the painter, one needs 1 liter, the other 2 liters for the same car, the painting surface also has a big impact, the larger the surfaces, the greater the efficiency, with small surfaces most of the paint goes into the air. according to manufacturer, how much paint is needed for a meter, for example, I can give something on Monday
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #10 5055811
    Tremolo
    Help: 1016
    Rate: 497
    He's not in too much of a rush. It is about estimates that I already need to know very much. As far as I know, 1 liter per 20m ^ 2.
    It is simply about the source according to which it would be possible to estimate how much varnish waste is generated in Poland, some respect
  • #11 5061377
    ŚNIADY
    Rate: 19
    Try to call or write to the sales representative of one of the manufacturers, he may give you an estimate of how many varnishes they sell each year. I think that on this basis it will be easiest to estimate the amount of waste, and maybe they have some data.
    Added after 21 [minutes]:
    PS The proportions and the estimated quantity per 1 m2 are given on the websites of some producers. Regards
  • #12 5081589
    Tremolo
    Help: 1016
    Rate: 497
    You would have to know all the manufacturers. And the producers often do not provide anything for reasons of industrial secrecy.
Estimating the amount of varnish required for painting a Fiat Punto involves several variables, including the type of paint, the number of layers, the painter's skill, and the painting method. Responses indicate that for a medium-sized car, approximately 1 to 5 liters of paint may be needed, with 1 liter covering about 20 m². The efficiency of the spray gun significantly affects paint usage, with high-pressure guns having around 50% efficiency and low-pressure guns about 70%. Additionally, a substantial portion of the paint (30-50%) may be lost as overspray or evaporation. For accurate estimates, consulting paint manufacturers or industry data may provide insights into varnish waste generation.
