3-Wire Chandelier Configuration: Connecting 4-Bulb Chandelier with Dual Switch Control
primo82 148528 11
How do I wire a chandelier with three conductors so that one switch key lights half the bulbs and both keys light all of them?
You wire it with one neutral and two switched phase conductors: blue to blue for neutral, and the other two wires as the two phase feeds from the double switch [#5344481] This is a normal series/double-switch connection, so the chandelier can be split into two groups of bulbs; for a 4-bulb chandelier that can be 2+2, or another split such as 1+3 if the fixture is built that way [#5344675][#5343886] In an old TN-C installation, the protective conductor may be a PEN and the yellow-green wire must never be used as phase or neutral unless it is clearly re-marked at both ends [#5344481] If the chandelier has a metal housing and a PE terminal, connect the protective conductor to it; otherwise the wiring still works for the lamp circuits themselves [#5344481]
  • #1 5343818
    primo82
    Rate: 24
    I wanted to ask how to connect the chandelier in a 3-wire configuration. In the simplest words, 3 cables stick out of the ceiling, which go to the box, and also 3 cables from the box go to the light switch. The chandelier would have, say, 4 bulbs, and it would light 0 (switch off) / 2 (on the first 'flap' of the switch) / and 4 on both 'flaps'.
    I have searched a lot on the internet, but unfortunately there is either a 2-wire or 4-wire connection described everywhere. Some people said that a 3-wire connection is impossible, but I used to have a wiring diagram in this way, unfortunately I lost it ...
    Does it need a special chandelier for such a connection? Are they universal in this respect?
    If you need a diagram, please let us know - I will draw it.
    Greetings.
  • #2 5343852
    mr_kciuk
    Help: 25
    Rate: 29
    write what colors of the wires come out of the connection (most likely blue, brown and yellow-green); with this configuration, you can connect it to 0/4, i.e. either all are lit or none
    have you not written whether it is new or "old" installation?
  • #3 5343863
    vexed
    Rate: 10
    I assume that the chandelier also has 3 wires and the switch is double. So it looks like this phase you have at the ceiling divided into two and neutral for this. and in the chandelier it is the same.
    I did it so that I screwed on the same lamps in the chandelier (all) and checked with an ordinary ohmmeter between which outputs of the chandelier have the highest resistance and these two are phases. later it is easy to check that from each phase to ground there is half of this resistance
    there is no concept that says that it is impossible to connect 3 wires because half of the chandeliers have this
  • #4 5343886
    jdjan1
    Help: 124
    Rate: 169
    Hello!
    My friend primo82 please see this topic: Link .
    Diagram for three bulbs, so for you, connect two to one key (in parallel) and two to the other.
    Jan
  • #5 5344433
    primo82
    Rate: 24
    The installation is new, done by me. The cables in the box are also not connected yet. The colors of the cables are as provided by mr_kciuk.
    I have read the link from jdjan1 and found a diagram of interest to me:
    Looking at this, it is not necessarily 0/4 joining, you can even do 2/2 and 1/3. As I understand it, I just have to connect the phase wire going to the box with the two wires going to the chandelier, and the neutral wire going to the rest.
    I just wonder what about the cables for the switch, because according to this diagram there should be two and I have three ... (Installation in this room does not have a PEN cable) Do you also connect two into one or just leave one unused? (Although I know that in this diagram that I used to have all the wires were used)
    Greetings.
    mr_kciuk
    Help: 25
    Rate: 29
    You have PEN for sure - you just do not have N and PE separated into separate ones, i.e. the installation of the older type TN-C; The PE vein is unused; for 2 keys, as in the picture you need 2 phase wires and a neutral one, with N there will be no problem - you take blue, one of the phase ones - brown for sections I, now there is power to section II - conditionally you can use yellow and green, only and exclusively when you clearly mark on both ends that it is no longer PE - mark it with paint, electrical tape, no matter; there must be a clear and permanent indication that there is a change in the use of the vein !!!
    Next: you connect neutral in the box and you pass the phase wires through the bipolar connector
    As for the connection of the candlestick itself - write what the cube looks like and how the colors are preserved (I hope that the 'foreman' was not hung over when folding and kept the colors with the standard ;) ); from the description that there is a 3-wire connection, you have a simple matter: blue-blue -> neutral, and the other two are phases, with a small exception: as you will see yellow-green on the chandelier, God forbid you connect the phase !!
    jdjan1
    Help: 124
    Rate: 169
    Hello!
    I can see that the connection is not fully understood by my colleague.
    In that case, please watch more: Link .
    In this document it is a diagram with a series (candlestick) switch.
    Jan
    PS The technical language is not prose, but a diagram, characteristics, table of measurements, etc. Hence, my answers are limited only to this kind of statements.
  • #8 5344912
    michcio
    Electrician specialist
    Help: 145
    Rate: 481
    Besides, it is a pity that when you did this installation, you did not think about the PE cable to the chandelier (grounding), i.e. a total of four wires. This is required by the regulations and common sense.
    And, as mentioned above, you must never use the yellow-green wire as phase or neutral! This color is reserved only for the PE conductor. If you play something else on it, it is very possible that it could cost someone your life in the future.
    Similarly with the color blue - only neutral.
    With the phases, however, we have freedom - white, gray, red, black, brown, etc.
    In the will to be exact, since you did this installation yourself, I hope that you led to the sockets for 3 wires, not two ... And do the sockets at least have a 2.5 mm cable and secure it? 16 A, 1.5 mm light and 10A fuse ...
  • #9 5346981
    primo82
    Rate: 24
    jdjan1 - this is the pattern I meant, now it's all clear. There should be no problem with connecting. Thanks!
    The installation has a PE conductor (or rather PEN, because it is an old building, additionally this is what an electrician friend recommended to me and so I connected it), but only in the kitchen. The chandelier is in the room, and it does not use devices with a "pin" there, so the PE wire was not connected (except for one socket to the computer). Indeed, I could have thought about the PE cable for the chandelier, but I will not be making the walls again now, maybe at the next renovation.
    Thanks to everyone for help and advice,
    Greetings!
  • #10 5347040
    kamilero
    There is no big tragedy with the lack of a PE conductor (I'm talking about practice) due to the fact that a large part of the lamps do not have such contact.
  • #11 5347294
    mr_kciuk
    Help: 25
    Rate: 29
    How is the TN-CS installation and there is a PE wire, with a metal lamp housing, what's the problem to screw the protective cover to it?
  • #12 5347353
    primo82
    Rate: 24
    No.. :) The situation is that I do not have this lamp / chandelier yet, I will probably buy it during the weekend, then everything is clear.
    Greetings.
The discussion revolves around connecting a 4-bulb chandelier using a 3-wire configuration with dual switch control. The user seeks guidance on wiring, as they have three cables from the ceiling and three from the switch, aiming for a setup that allows for 0, 2, or 4 bulbs to be lit. Responses clarify that a 3-wire connection is feasible, with suggestions to connect two bulbs to one switch and two to the other. The importance of proper wire color coding and the potential use of a PEN conductor in older installations is emphasized. Diagrams and links to wiring schematics are shared to assist in the installation process. Concerns about grounding and safety regulations are also discussed, highlighting the necessity of a PE conductor for metal fixtures.
