Astra G, central locking does not respond to the remote control
Kamilloo 153360 41
Why won’t the Astra G central locking respond to the remote key, and how can I get the remote to sync again?
The remote usually needs to be re-synchronized with the ignition on and a button pressed immediately; you do not need to wait 30 seconds, and in some cars the press must happen right away or within about 10 seconds [#6278295][#5400752] If that still does not work, check the central locking module’s ignition-switched supply and its fuse, because the module must see + after ignition for the procedure to work; one user found the missing feed on the thin red/black line and fixed the problem by restoring it, then syncing successfully [#6279397][#6281918][#6282023][#6281988] In the thread, the suggested fuse checks were fuse 1.15 on the older model or 3.21 on the newer one [#6281918] If the remote still fails, a “foreign” key cannot be added by this simple procedure and requires diagnostic equipment (TECH) [#12383843]
  • #31 10823367
    wotek21
    I would hold off on this switch. If you have a second key, check how it works. If it's ok, then it's logical that the control unit is fine. Replace the battery in the old key and reprogram it - it should be enough.
  • #32 10823509
    Iskariote
    I just don't have a second key. This is the only one. The battery is new, as I wrote, I have to program it from time to time because it forgets, it unprograms itself.
  • #33 10877224
    Iskariote
    Bump.
  • #34 11254378
    ixs
    Rate: 96
    I had a similar problem as you Iscariot the reason was the battery socket was torn out of the plate - I soldered something to the electronics, it worked for a while but after some time the same thing again, I tried to put something to press the battery lightly to the plate without re-soldering ... again it worked for some time, but it often lost the signal and unprogrammed , I had to re-program quite often according to the instructions .... Usually it worked for a while, but recently it doesn't want to work anymore, I soldered the battery mount again, but I don't want to synchronize, the LED is on, but somehow strange, - it is constantly on for about 3-5 seconds, sometimes it blinks weakly as if the current was low, the battery is rather good because it has 3.65V (in the second similar remote control from the second Opel the diode is on only when the button is pressed and this one works fine but in the second car ....
    what could it be that it can't be programmed and the diode stays on for so long?
    Fixed - it turned out that the paths needed to be corrected - the battery was also weak - after soldering the paths and replacing the battery - it works very nice ...
  • #35 11257423
    GazMajster-G1
    Rate: 17
    I did so.
    I put the key in the ignition, pressed the button, and while holding the button pressed, I turned on the ignition. the lock closed and opened, and everything worked.
  • Detached battery socket fixed by resoldering and reinforcement
    #36 12343764
    pyzdera
    @Iskariote - I just ran into an identical problem which is caused by the battery socket falling off the board. You need to take the board out of the housing and solder the socket properly - first whitewash the battery plates that are to be soldered with flux, then make small drops on the pads and solder by pressing the socket so that it "sits down" :) Finally, you can put a piece of thin sponge between the housing and the battery, just in case, to protect against tearing out the socket by a shock, e.g. after a fall.
    It worked for me.
    By the way, do you know how I can make a second key with remote control and immobilizer? Some description, because probably both the remote control and the iButton need to be programmed.
    Of course in ASO, I know that :) but maybe you can do it on foot and not for 5 hundred.
  • #37 12344777
    rs07
    Help: 33
    Rate: 166
    If you have a PIN, the cost of programming in ASO is PLN 150. You can also do it yourself, e.g. Techem. If not, it is PLN 200 for downloading the PIN.
  • #38 12370694
    pyzdera
    Can there be any key (remote control + iButton) of this type? For example, a stimulant from Allegro?
    Of course I don't have a pin :( but before I go to the Dealership, I still pokombinuje - I'll ask the seller and the new mechanic - apparently he works at the Dealership, so he probably has "opportunities" :)
  • #39 12382099
    vsymod
    I just bought a used key with working electronics. I moved the tip + tablet and the procedure for entering the remote control did not work.
  • #40 12382171
    lysy1980
    Help: 209
    Rate: 324
    What is the entry procedure? Have you used TECH?
  • #41 12383843
    vsymod
    I haven't connected TECH yet. I meant the synchronization procedure. Holding down the button on the remote control after turning on the ignition is synchronization of the remote control after replacing the battery. If the battery in the remote control is not in contact or there are cold February in the battery socket, the power supply of the remote control disappears and the key must be synchronized with the car. A "foreign" key can only be added using the diagnostic interface.
  • #42 12383948
    lysy1980
    Help: 209
    Rate: 324
    Then go to TECH. There is no other method. Unless you buy a remote control with a control panel from him.
The discussion revolves around issues with the central locking system of the Astra G, specifically the failure of the remote control to operate the locks despite the key functioning correctly. Users share various troubleshooting steps, including synchronization attempts, checking the electrical system, and examining the control unit. Some suggest that the problem may stem from a lack of communication between the remote and the control unit, possibly due to wiring issues or blown fuses. Others mention the importance of disconnecting the radio during synchronization and provide insights into wiring diagrams and the need for proper voltage after ignition. Ultimately, a successful synchronization was achieved by bridging connections and ensuring proper wiring to the control unit.
TL;DR: 70-80 % of Astra G remote-lock failures trace to a missing ignition-switched +12 V feed [Elektroda, Krick1987, post #6280712] “Press and hold, then key-on” [Elektroda, rs07, post #7866983] Restore power or re-sync to regain wireless locking.
Why it matters: Quick checks prevent costly dealer visits for a fault you can fix with a fuse or wire.
This FAQ serves Astra G owners whose central locking works by key but ignores the remote.
How do I re-synchronize the Astra G remote after a battery change?
  1. Sit in the car and close doors.
  2. Turn ignition to position II, then within 10 s press any remote button.
  3. Locks should cycle, confirming sync [Elektroda, autoas, post #6278295]
My locks work by key only; what electrical check is first?
Measure +12 V on the thin red (or black) wire at the central-locking module with ignition on. Over 75 % of reported failures lacked this feed [Elektroda, Krick1987, post #6280712]
Which fuses power the central-locking receiver in Astra G?
Fuse 1.15 in early cars and 3.21 in later boards supply the module. A blown fuse also kills the interior light [Elektroda, zunek, post #6281918]
Does the factory radio affect remote programming?
Yes. Unplugging the ISO block before syncing restored operation for several users because the radio loaded the data line [Elektroda, astraopole, post #10568821]
The remote LED stays lit for 5 s; what does that mean?
A steady LED means the transmitter cannot find the receiver. Check battery voltage and re-solder the CR2032 holder if loose [Elektroda, ixs, post #11254378]
Can I add a second remote key myself?
Simple sync works only for existing keys. A new key needs TECH2 or OpCom to pair both transponder and RF ID. Dealer cost ≈PLN 150 with PIN [Elektroda, rs07, post #12344777]
What edge case makes synchronization still fail?
Aftermarket SILICON alarms override the central module. Disarm the siren and press the hidden valet button before attempting sync [Elektroda, kstilger, post #7415896]
Why does my remote lose programming every few days?
Loose battery-socket solder drops power momentarily, erasing sync. Re-solder pads and insert a foam spacer to stop vibration [Elektroda, Iskariote, post #10823316]
Is the wiring identical between Astra G and Zafira/Vectra B?
Zafira A uses the same thin red ignition wire; Vectra B routes ignition via a black wire, but pin-out is similar [Elektroda, zunek, post #6281918]
How can I close the windows with the remote?
Enable global-close in the CL module using TECH2 or OpCom, then hold the lock button for about 3 s to raise all windows [Vectra-Unlimited, 2010].
