Fixing Oversized Drill Holes in Concrete for Expansion Plugs Compatibility
Vein 106374 12
How can I repair an oversized drilled hole in concrete, brick, or hollow block so an expansion plug will still hold?
Fill the oversized hole with elastic tile adhesive or a special two-component anchor adhesive, then push the plug in while the adhesive is still wet and screw in the fastener after it sets [#6313398][#6311758][#6312968] For small-load fixings, a wooden plug or even a cut broomstick can also be used as a filler before re-drilling or screwing in [#6314449][#6315190] If the hole is only slightly too large and the load is significant, use a larger-diameter metal expansion bolt instead of trying to save the original one [#6311234] If the damage is too bad or the wall material is weak, drilling a new hole and masking the old one is also suggested [#6312968]
  • #1 6311126
    Vein
    Rate: 51
    The matter is trivial, the ideas are there, but I want to be sure.
    Too large holes have been drilled for expansion plugs, unfortunately larger plugs cannot be inserted due to the size of the mounting screws. how to fix these holes? Glue the wall plugs with glue? Maybe it is possible to fill the quality of a too large hole and re-drill it? Unfortunately, it does happen to me from time to time, the material being drilled into is different. Currently, it is a brick or a block.
    What can you advise me? How can these holes be repaired?
  • #2 6311139
  • #3 6311161
    spider446
    Help: 5
    Depends on the loads the dowels will carry, how small the dowel can be glued onto the plaster, when it dries up, screw in the screw
  • #4 6311234
    shadow0013
    Help: 243
    Rate: 314
    This depends on the load and whether the bolt will be pulled out by the load or sheared by it. If there are not many of these holes, you can use metal expansion bolts (they are more expensive but also have larger diameters).
  • #5 6311758
    mareklan
    Help: 11
    Rate: 30
    There is a special two-component adhesive in packaging such as silicone, which is used for gluing, for example, anchors.
  • #6 6312396
    Vein
    Rate: 51
    Thanks for the answers. Some of these fasteners will carry quite significant loads (e.g. cabinets, mirrors) and some only small (clothes hangers). The small holes are always the most problematic.
    Best regards,
  • #7 6312968
    kemot55
    Help: 184
    Rate: 147
    In Castorama, I saw a whole system for fixing dowels in porous and generally weak walls. It consists in inserting an appropriate tube with holes and then filling it with a special mass.
    Personally, however, I have another patent from recent renovations. I fill the hole with elastic tile glue and push the plug in the wet mass (reaming a little - the glue is too thick) and then screw in the screw while wet. It is a bit cheaper than the ready-made mass and is effective.
    And sometimes it may be better to drill a second hole and simply mask too large one (unless it is structurally not feasible)
  • #8 6313308
    mczapski
    Level 40  
    Help: 468
    Rate: 1659
    Well, you write in the title about holes in concrete and then in brick or hollow brick. Decide. And finally, how big are these holes, 1 mm or 5 mm? Another problem is how many of these holes. First, they are alternatives to the plastic pins. Secondly, you can put a type of T-shirt on the pegs. Thirdly, since you have time for the question, you could fill these holes a long time ago. It seems like you don't want to think.
    We also do not know if we are dealing with holes of 5 mm or maybe 12 mm.
  • #9 6313398
    tomas323
    Sometimes I also recalibrated the hole. If it is a brick wall or some reinforced concrete or similar. it is best to fill the hole with tile adhesive, then press the "fur" of the pin. As the glue binds, you can screw the pin. The plaster dries faster, but it is weaker.
  • #10 6314319
    Vein
    Rate: 51
    I am accused of not thinking. The holes are different as I wrote, sometimes the problem is with 4mm holes when they will ream 5mm and sometimes with 8mm holes which will ream 9mm.
    With light loads, I used paper tape as a "filler", but unfortunately the tape holds much too weakly.
    Someone noticed that he writes once about concrete, another time about brick. The problem is that it just happens that I ream in concrete, sometimes in brick, and then in hollow brick. There are 5 badly made holes for the whole house. I was doing differently, either masking it or correcting it with tape.
    Flexible tile adhesive is a very interesting tip
  • #11 6314449
    000andrzej
    Level 37  
    Help: 302
    Rate: 238
    If it is "only 1mm" in diameter - a good expansion plug, as the name suggests, should expand.
    I also cope with plastering (there was no need to use glue yet).
    By always drilling with a 1mm smaller drill bit, then I calibrate it gently with the face value and there is no problem with the hole unless I find a hole in a brick. Then just stick with something. Always be careful when entering, because there is a layer of brittle plaster.
    I used a wooden dowel in the hole several times. It all depends on the circumstances.
  • #12 6315190
  • #13 6375797
    Vein
    Rate: 51
    I coped with pasting pins on "sudal", the glue that connects everything to everything :)
The discussion revolves around methods to repair oversized drill holes in concrete and brick for the installation of expansion plugs. Various solutions are proposed, including using two-component adhesives for anchoring, filling holes with elastic tile glue, and employing metal expansion bolts for larger diameters. Participants emphasize the importance of considering the load requirements of the fasteners, with suggestions to either fill the holes and re-drill or use alternative fastening methods. The conversation highlights the variability in hole sizes and materials, such as concrete and brick, and the need for effective solutions to ensure secure installations.
