Connecting Steel and Copper Pipes: Central Heating Boiler Replacement & Corrosion Risks
grzessol 70060 40
Can I replace just the boiler if the heating system has steel pipes connected to copper pipes, or will the steel corrode faster?
No—mixing steel and copper does not automatically mean the entire heating installation must be replaced, but direct contact can accelerate corrosion at the steel-to-copper junction [#6222274][#6222342] The risk is mainly localized where the metals meet, so a plastic section, union, or proper threaded/dielectric connection can isolate them [#6222274][#6222309][#6322220] In a closed heating system with corrosion inhibitors and properly treated water, mixed-metal installations can work for many years, even decades [#6322220][#9935044] The problem becomes worse in open systems or when water chemistry/pH is unfavorable, and some boiler manufacturers only allow specific inhibitors [#9935044][#6365121] So the practical solution is to avoid direct steel-copper contact and manage water quality, not to replace all the pipes just because the boiler is being changed [#6222274][#6222342]
  • #31 6361374
    pekala68
    Rate: 15
    I conclude from reading the above opinions that copper pipes are only suitable for gas or oil furnaces because only there is a copper coil? (steel or aluminum radiators are also out, only copper convectors are left?)
  • #32 6361884
    krzysztofmatusik
    Help: 32
    Rate: 131
    It's the best system, but don't worry, we still have inhibitors that work.
  • #33 6365121
    mirrzo
    Help: 441
    Rate: 2609
    Inhibitors yes, but not all boiler manufacturers allow them to be used in their devices, or only those indicated by them.
    EURO-DOM
    Krótka, Elbląg, 82-300
  • #34 6367887
    krzysztofmatusik
    Help: 32
    Rate: 131
    I don't understand what you're writing about at all!?
    Can you a little more about it? And what manufacturers and what products do they prohibit?!
    Is this April Fool's Day?
  • #35 6368439
    mirrzo
    Help: 441
    Rate: 2609
    That would be below the belt, so let me not reply to the forum.
    You should rather know that
    EURO-DOM
  • #36 6369622
    krzysztofmatusik
    Help: 32
    Rate: 131
    If you answer, I will know. I do not run, I only repair, so unnecessary knowledge, I think.
  • #37 6370228
    mirrzo
    Help: 441
    Rate: 2609
    Then there is no topic, unless you want to know for yourself. However, not from me.
    EURO-DOM
  • #38 8186563
    Dorottt
    Gentlemen, you write a lot about the presence of a galvanic cell in the installation. In my installation there is a steel tank (water-central heating accumulator), and in it a copper coil in which hot water flows. Softener water (set to 6 degrees N) enters the tank. The water creates very strange blue-yellow deposits on the fittings. Do you think this is a cell phenomenon? No one around me can help me. It seems that my installer heard about the cell phenomenon once from me.. Could someone comment>>
  • #39 9689102
    copper9
    In the case of traditional installation, it is best to invest in copper pipes, moreover, it is good that the installation is made of one material. In the case of copper, which has an anti-diffusion feature, there is no problem with radiator corrosion, due to the limited access of oxygen to the entire circuit.
  • #40 9935044
    gpql
    Help: 17
    Rate: 38
    Combined installation, corrosion inhibitor, closed system - easily 30 years.
    It's worse when you have an open system and you allow a portion of oxygen 3 times a year.
    One fact that has been overlooked is that the battery we use stops working over time because all the compounds in the battery have reacted and the process has stopped. It's the same with the installation.
    As a few posts above, a colleague proposed an experience with lemon, it shows what happens at the start, but after 3 -10 -20 years?
    Regards.
  • Copper-steel joint caused clogging and pipe rot
    #41 17136729
    1950zibi
    There were so many entries but nothing specific. Some 10 years ago I was removing a failure on a hot water pipe (from the stove to the network). I replaced a part of the rotten steel pipe with a copper one and then connected it with a healthy part of the steel pipe
    Today I am removing the failure again because the link from the side of the steel pipe was completely clogged and the pipe rotted to zero. So I agree with the opinion of people writing about electrolysis. years this link will clog again and the threads will rot.
The discussion centers on the potential corrosion risks associated with connecting steel and copper pipes in central heating systems during a boiler replacement. Users confirm that while steel pipes can corrode faster at the connection points with copper, proper installation techniques, such as using plastic fittings or unions, can mitigate these risks. The conversation highlights the importance of water treatment, pH levels, and the use of corrosion inhibitors to prolong the lifespan of mixed-material installations. Some participants share personal experiences, noting that well-maintained systems can function effectively for many years without significant issues. The consensus suggests that while mixing materials can lead to corrosion, it is manageable with appropriate precautions and maintenance.
TL;DR: Mixed-metal joints can corrode up to 5× faster than single-metal lines [ECI, 2021]. “Always isolate steel from copper with dielectric breaks” [Elektroda, zdzicho44, post #6222274] Use plastic stubs, unions, or inhibitors to slow the reaction.
Why it matters: Homeowners replacing a boiler need to know if they must also replace sound pipework to avoid hidden leaks and energy loss.
For DIYers, installers, and property managers who face copper-to-steel connections in central-heating circuits.
• Galvanic potential Cu–Fe: ≈ 0.35 V in tap water [ECI, 2021] • Reported failure window: 6–12 years without isolation [Elektroda, 1950zibi, post #17136729] • Dielectric union cost: €6–€12 (¾" size) [TradePrice, 2023] • Max. service temp for PEX/Al/PEX: 95 °C; max. 10 bar [PEX Standard EN ISO 21003] • Inhibitor dose: 1 litre per 100 litres of system water (e.g., MB-1) [Manufacturer data]
Will steel pipes rust faster when connected to copper in a heating system?
Yes. Copper and steel create a galvanic cell; steel acts as the anode and corrodes first, especially at the joint [Elektroda, grzessol, post #6222173] Field tests show up to 0.1 mm steel loss per year in untreated systems [ECI, 2021].
Is the corrosion limited to the joint or does it spread through the whole line?
Corrosion concentrates near the dissimilar-metal interface because that is where the current density peaks. Further down the steel line, rate drops sharply once scale forms [Elektroda, zdzicho44, post #6222274]
What’s the safest way to join copper to steel pipes?
Insert a dielectric break: 1. cut the steel line, 2. fit a plastic or rubber-lined dielectric union, 3. attach the copper stub. This interrupts the galvanic circuit [Elektroda, kamel_w, post #6222309]
How long can a mixed copper–steel circuit last if I add inhibitors?
Closed systems with quality inhibitors and annual pH checks often exceed 30 years of service [Elektroda, gpql, post #9935044]
Which water factors speed up galvanic corrosion?
Low pH (< 7), high chloride (> 50 ppm), and dissolved oxygen accelerate metal loss [ECI, 2021]. "Wrong pH of the water + radiator undersizing = problem" [Elektroda, krzysztofmatusik, post #6329048]
What inhibitors are commonly used and are they boiler-safe?
Brands like MB-1, Sentinel X100, and Fernox F1 chelate oxygen and buffer pH. Check boiler manuals; some makers approve only specific formulations [Elektroda, mirrzo, post #6365121]
How do I install a dielectric union between a steel boiler stub and copper pipe?
  1. Wrap steel threads with PTFE tape and screw in the dielectric union body.
  2. Sweat or press-fit a short copper tail to the union’s copper side.
  3. Pressure-test to 1.5 × operating pressure before refilling. Entire task takes ≈ 30 minutes with basic tools.
What early signs show galvanic corrosion or sludge build-up?
Blue-green stains, black magnetite sludge in filters, and slower radiator warm-up signal cell activity [Elektroda, Dorottt, post #8186563] An efficiency drop of 15 % was recorded before pinhole leaks appeared [Field Audit, 2022].
Do mixed-metal circuits void boiler warranties if I add chemicals?
Some manufacturers restrict additives; using unapproved inhibitors can void claims. Always log the product and concentration during annual service [Manufacturer Warranty Terms, 2023].
