Dealing with Overheating Radiator: Adjust Danfoss Radiator Head Settings in Apartment (1-7, N)
totenkopf1 46137 13
How can I stop a Danfoss thermostatic radiator valve from keeping one radiator hot when the head is set to minimum?
Fully close the radiator valve manually—if the thermostatic head does not shut it off, use the manual cap or the shut-off valve at the bottom, because the head may be mismatched or the valve itself may be damaged [#13265607] [#13264296] Setting the dial to 1 only limits the flow to a minimum; it may not completely stop heating [#13264327] Check whether the head is seated correctly, and compare the valve stem travel and the distance from the head to the spindle with another radiator or by swapping heads to see whether the fault is in the head or the valve [#13262347] [#13263207] In this thread, the radiator stopped heating only after the supply was turned off [#13266068]
  • #1 13262235
    totenkopf1
    Hello, I'm new to this forum, sorry if I added the topic in the wrong place.
    I have blockades for radiators in my apartment in position 2, which is around 16 degrees. My apartment is in the middle of the building and it is well insulated, all the radiators are in position 2 and they are cold. One in the large room is also in position 2, but still heats up a lot, I checked the temperature in the room and it is as much as 25 degrees, which is much too much for me and I'm afraid that I will pay a lot for heating, another identical radiator in the same room it is also cold. I have no idea how to set the heater to stop heating. The photo shows a Danfoss radiator head, after downloading, you can see a yellow ring with numbers from 1 to 7 and the letter N.
    Thank you very much for help Dealing with Overheating Radiator: Adjust Danfoss Radiator Head Settings in Apartment (1-7, N) since all the others are cold
  • #2 13262338
    pioart
    Help: 343
    Rate: 1473
    At the beginning, you can swap the valves and you will find out whether the valve or the regulator / danfos /.
  • #3 13262347
    kryststgpom
    Help: 78
    Rate: 381
    The valve is one thing and the thermostatic head is the other, maybe you have the wrong head and there is no contact with the stem in the valve. If you set the head to 1 or snowflake, does the radiator still heat up?
  • #4 13262406
    totenkopf1
    Hello, my house is only from 2 up, there is no snowflake or 1. All other heaters in the house are just for 2 (i.e. as little as possible) and are cold, and this one is also for 2 and heats up strongly.
    Added after 26 [minutes]:
    I swapped the valves, took the one from the radiator that was cold and put it on the one with which I had a problem, and it's still hot. It didn't help. I noticed that on this radiator, which was cold, and I took the valve from it, it started to heat up a lot.
    Added after 18 [minutes]:
    I noticed that the radiators that are cold do not make any sounds, and the one that is warm all the time hisses slightly around the valve, when I push this metal pin into the center of the head, then it stops
  • #5 13263207
    kryststgpom
    Help: 78
    Rate: 381
    As you press the plunger to close the flow, measure whether the spindles are equal in both radiators, whether they have the same stroke and overall visually, whether the valves are the same.
    Screw in the thermostatic head from this radiator, which heats up all the time, to another, maybe the head is to blame.
    Compare in both heads whether the distance to the disc that acts on the spindle is the same. It is best to take measurements with a caliper.
  • #6 13263278
    andrzej lukaszewicz
    Help: 626
    Rate: 2121
    You can put something under the mandrel and tighten the heads, e.g. 5 groszy.
    The second option is to close / cover the valves on the radiator connection, at the bottom.
  • #7 13263807
    totenkopf1
    Thanks for your help, it looks like something is wrong with the head. If I turn off the water supply to this radiator, will it stop filling me with heat consumption on the meter?
  • #8 13263843
    brofran
    Help: 650
    Rate: 1406
    If the temperature in the room is above 10 °, the meter must show some consumption - of course also very small. Regardless of whether the radiator will be warm or cold. :D
  • #9 13264261
    totenkopf1
    Yes, I understand that such miracles that the meter did not indicate anything and it was warm, there is no :D I just want to turn off the water supply to this heater because if it's 25 degrees in the room, it surely eats up a lot of energy :)
  • #10 13264296
    vodiczka
    Help: 1185
    Rate: 4311
    Does water come out of it when you turn off the tap over the sink?
    If you close the water supply to the radiator, it will stop heating. Easy?
    There are plastic knobs that you can screw instead of the head onto the valve thread, when you tighten it all the way, it will stop heating, and if it does not stop, the damaged valve, not the head.
  • #11 13264327
    arturccc
    Rate: 45
    On the valve you have numbers from 1-7 and a marker. Set so that the marker on the valve points to 1, you will limit the flow to minium.
    Theoretically, radiators of this type should also have shut-off valves at the bottom, line "I" water flows to the radiator, line "-" water does not flow.
    The head is not a CLICK by chance? You are sure that it is well positioned, to attach it, you have to twist that white ring, then such teeth will pop out.
  • #12 13265607
    musculus
    Help: 8
    Rate: 162
    I do not know what it looks like at the moment, but when I bought thermostatic valves some years ago (probably Danfoss), the complete with the valve was a red plastic "cap" screwed on instead of the head. It was possible to close the valve manually (tightening it caused the valve to close). To work with the thermostatic head, this "cap" (or whatever it is professionally called) had to be unscrewed and in its place, the head was screwed on. See if you did not get these caps together with the valves - if so, try to put it on and screw it up completely. If the radiator stops heating it means that the thermostatic head is damaged, and if it continues to heat - the valve is damaged.
  • #13 13266068
    totenkopf1
    Thanks to everyone, I did it, I turned off the heater and it doesn't heat up anymore.
  • #14 13266768
    kryststgpom
    Help: 78
    Rate: 381
    Only this is a half-way solution, did you turn off the valve on the return?
    Have you found the reason why the head does not regulate the flow?
The discussion revolves around a user experiencing overheating issues with a Danfoss radiator head in their apartment. Despite setting the radiator to position 2, one radiator heats excessively, reaching 25 degrees Celsius, while others remain cold. Users suggest troubleshooting steps, including swapping valves and checking the thermostatic head for proper contact with the valve stem. The user confirms that the problematic radiator continues to heat even after valve adjustments. Solutions proposed include turning off the water supply to the radiator, using a plastic knob to stop heating, and ensuring the thermostatic head is correctly installed. Ultimately, the user successfully stops the radiator from heating but is advised to investigate the underlying issue with the head's regulation.
