DANFOSS - The radiator heats all the time, the regulation of the head does not w
Stanley19 100131 14
How can I fix a Danfoss radiator thermostatic head that no longer regulates and keeps the radiator heating all the time?
Tighten the nut below the head to stabilize it first; in one case that restored normal регулиation immediately [#13160022] If that does not help, remove the head and try to close the valve manually with the special red cap/knob: if the valve closes, the thermostatic head is faulty; if it does not, the valve is seized or clogged and needs cleaning/purging or replacement [#11558699][#11557709] The adjustment ring around the pin only sets the average maximum flow, not a full shutoff, so it will not fix a stuck-open valve by itself [#11557709] Another possible fault is a damaged head bellows; one way to check is to remove the head, measure the plunger movement, then cool it strongly in a freezer and see whether the movement changes significantly [#11558387] If the valve is stuck with debris, you can temporarily set it to increased flow, flush it, then restore the previous setting and reinstall the head [#11558387]
  • #1 11557158
    Stanley19
    Rate: 13
    Hello, I have a problem that the knob in the head does not work in my radiator and therefore I cannot regulate the heating, and the radiator heats up all the time. And here is my question, is there any way to fix it without the help of a professional? Below he adds photos of the head.
  • #2 11557254
    Nemonek
    Help: 106
    Rate: 378
    A similar topic HERE
  • Asking how to adjust Danfoss valve flow
    #3 11557510
    Stanley19
    Rate: 13
    Everything is nice, but I'm a bit green in this topic and I would have to describe it in more detail.
    "On the valve, around the pin that presses the head in, there is a profiled ring. If you look at it, you will notice stamped numbers on it. Pulling it towards you, you can adjust the flow by turning it."
    So how exactly should I adjust it so that if I want it not to heat at all, I turn off the radiator and turn it up if I want.
    I apologize in advance for the problems.
  • #4 11557709
    janszy3643
    Help: 142
    Rate: 312
    If the valve does not respond to the needle controlled by the thermostatic head, it means that: either it is seized, or something has come to the valve, some "rubbish" and the valve cannot close.
    Valve for replacement (purging).
    The orifice control only allows you to set the average maximum flow in the range of -100%.
  • Flush valve and test thermostatic head for damage
    #5 11558387
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    He could have approached the valve with some rubbish (I also had it in the bathroom once and I have the same valves). You can remove the head, temporarily set the nub (maximum) to the increased flow to flush the valve, then restore the previous initial setting (cross banding) and install the head. There may also be another reason for this, namely a damaged thermostatic head, e.g. a broken metal bellows with gas in the head (as the temperature increases, the gas expands and pushes the plug which presses the needle and closes the valve, and when the temperature drops the gas contracts, and the plug retracts, reducing pressure on the needle). A head that is damaged in this way (pierced bellows) can only be replaced. You can check the head by observing the mushroom's reaction to temperature in it. For example (we do it on the removed head) we measure the distance from the plug to the edge of the nut. Then we put the head into the freezer and measure this distance again. After such a strong cooling (temperature in the freezer around -18 to -20 degrees, sometimes even colder) the difference should be significant.
  • #6 11558699
    janszy3643
    Help: 142
    Rate: 312
    Perhaps otherwise, it is enough to disassemble the thermostatic head and install a special knob (such a red nut) that allows you to manually close the valve. If the valve can be closed like this, it is functional, and only the thermostatic head is damaged, if not, as I wrote, the valve to be replaced.
  • #7 13159897
    Ev...
    Rate: 15
    Hello. I apologize in advance as it is possible that I should find the answer to my question above, but I am completely ignorant of plumbing. My problem is also that the heater is still hot and I can't turn it off. When I turn the head, it rotates around and in addition to the white knob, the black plastic rotates closer to the pipe. What can I do with it?
    I am asking for help and understanding. ;)
  • #8 13160022
    FOSGEN1
    Help: 41
    Rate: 334
    Ev ... there should be a nut below the head (ie closer to the pipe). Try to tighten it and stabilize the head position.
    Then the regulation should start working.
    If not, write.
  • #9 13160486
    Ev...
    Rate: 15
    It worked, thank you very much for your help.
    Could it be repeated, e.g. because an element is well-made?
  • #10 13160589
    FOSGEN1
    Help: 41
    Rate: 334
    Depending on how long the head was used with the play. But probably, if it worked, it will keep. You can of course try to tighten a little more, but don't go overboard. Because something else will break and there will be a meatball.
  • Thermostat valve likely stuck closed or misadjusted
    #11 20915839
    dzemes88
    I have this inquiry. The radiator stopped heating in the bathroom, in the block. It was slightly warm at the very top. I called the gentlemen from the administration. Bad luck that they came and it just happened to heat up on the whole, and decently. I described what was happening, they recommended to observe, in case it was cold again unscrew the thermostat. And so it happened. The radiator cold 95%, only the top slightly warm, I unscrewed the thermostat and in a flash hot. I thought the head damaged I will buy another, but also with this situation is similar. The radiator non-stop on 5, because exactly in our cooperative there are no dividers in the bathrooms. The temperature in the bathroom fluctuates between 20-22 degrees. I have a question in connection with this what is happening and what is responsible for such a situation, for any advice I will be grateful.
  • Valve head may be heat-soaked by radiator
    #12 20916784
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Is the valve properly installed (and also the head)? It may be that the head is located directly above the radiator, so it is heated by it and prematurely shuts off the supply of the heating medium (it interprets that the temperature in the bathroom is high, because the head is heated by the heat rising from the radiator). A lot would be explained by the photo. It may also be misaligned. Contrary to appearances, the position of the valve can be important.
  • Possible overheating of the valve head from nearby pipe
    #13 20917161
    dzemes88
    Yes, the head is mounted above the radiator on the right side. The problem is that so far, and I've been living there for 10 years, everything was fine. I didn't change the position of the head, etc. I replaced it only once, 4 years ago, the old one cracked on the plastic part, maybe the temperature did its thing. But then a few years later everything worked until now. I was wondering whether perhaps during the recent frosts they circulated even hotter water and the head at the installation site heats up and cuts off the flow. Well, there is actually a hot thread there and it heats up itself. But that's just my musing. Thanks for your interest in the topic.
  • Incorrect valve placement may overheat the head
    #14 20917586
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    dzemes88 wrote:
    Yes, the head is mounted above the radiator on the right side. The problem is that so far, and I`ve been living there for 10 years, everything was fine. I didn`t change the position of the head, etc. I replaced it only once, 4 years ago, the old one cracked on the plastic part, maybe the temperature did its thing. But then a few years later everything worked until now. I was wondering if perhaps during the recent frosts they had not circulated more hot water and the head at the installation site was heating up and cutting off the flow. Well, there is actually a hot thread there and it heats up itself. But that`s just my musing. Thanks for your interest in the topic
    This hotter water probably causes the heat from the radiator to radiate so much onto the head that it chokes the water flow to the radiator. The head mounting is incorrect (but I don`t see it in the photo), because you have to remember that heat always goes up, so it heats the head directly. I would be able to comment more if there was a photo.
    Unfortunately, valves are often installed incorrectly.
  • Hot water overheating the thermostat head may close the valve
    #15 20917936
    modziul
    Help: 245
    Rate: 454
    Zbigniew Rusek wrote:
    dzemes88 wrote:
    Yes, the head is mounted above the radiator on the right side. The problem is that so far, and I`ve been living there for 10 years, everything was fine. I didn`t change the position of the head, etc. I replaced it only once, 4 years ago, the old one cracked on the plastic part, maybe the temperature did its thing. But then a few years later everything worked until now. I was wondering whether perhaps during the recent frosts they circulated even hotter water and the head at the installation site heats up and cuts off the flow. Well, there is actually a hot thread there and it heats up itself. But that`s just my musing. Thanks for your interest in the topic
    This hotter water probably causes the heat from the radiator to radiate onto the head so much that it chokes the water flow to the radiator. The head mounting is incorrect (but I don`t see it in the photo) because you have to remember that heat always goes up, so it heats the head directly. I would be able to comment more if there was a photo.
    Too hot water (incorrectly selected parameters) causes cyclical closing and opening of the valve with characteristic knocking in the installation (the pipes cool down and after the radiator cools down, the valve opens and stresses occur in the cooled pipes due to uneven heating).
The discussion revolves around a malfunctioning radiator where the thermostatic head does not regulate heating, causing the radiator to remain hot continuously. Users suggest various troubleshooting methods, including checking for debris in the valve, adjusting the flow using a profiled ring on the valve, and examining the thermostatic head for damage, such as a broken bellows. Some recommend temporarily removing the head to flush the valve or replacing the head if it is defective. Additionally, improper installation of the head may lead to overheating due to heat rising from the radiator, affecting its functionality. Users share experiences and solutions, emphasizing the importance of correct valve and head positioning.
