How to divide L1/L2/L3 in a house switchgear between B10/B16/B32 fuses?
sabathan 25780 23
  • #1 7550932
    sabathan
    Hello and welcome,
    When planning connections in the switchgear, I have a question for you:
    How to divide the phases, i.e. L1, L2 and L3 into appropriate points..
    I have planned a division into:
    1 Dishwasher - B12 - max. current consumption = 1.1 kW
    2 Induction hob - B16/3 - max. current consumption = 8.3 kW
    3 Oven - B32 - max. current consumption = 2.0 kW
    4 Flow water heater in the kitchen - B16 - max. current consumption = 7.0 kW
    5 sockets kitchen - B16 - max. current consumption = 2.2 kW
    6 sockets living room+dining room - B16 - max. current consumption = 0.5 kW
    7 Lighting living room+dining room+kitchen - B10 - max. current consumption = 0.5 kW
    8 Lighting+sockets in the billiard room - B16 - max. current consumption = 0.5 kW
    9 Lighting 1st floor - B10 - max. current consumption = 1.0 kW
    10 Sockets 1st floor - B16 - max. current consumption = 0.5 kW
    11 sockets 1st floor bathroom - B16 - max. current consumption = 1.5 kW
    12 Flow water heater in the bathroom. ground floor - B16 - max. current consumption = 7 kW
    13 Flow water heater in the bathroom. 1st floor - C25/3 40A - max. current consumption = 24 kW
    I initially divided it like this:
    L1 - 1,2,9,10,11.
    L2 - 3,4,5,6,7,8.
    L3 - 12.13.
    Do you think this division is ok?
  • #2 7550999
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1501
    1- Why B12 and where to get it?
    3- Why B32 at 2kW - what is the reason for this?
    4- I hope it is a 3 phase heater.
    13- Why "C"
    Can you write what cables you used to power the receivers (cross-sections)?
  • #3 7551119
    keszan
    Help: 32
    Rate: 76
    sabathan wrote:
    Hello and welcome,
    L1 - 1,2,9,10,11.
    L2 - 3,4,5,6,7,8.
    L3 - 12.13.
    Hello!
    Col. "sebasthan"
    Wrong, L3-12 and 13, load=31KW
    L2-circuit,3,4,5=11.2 KW
    Again, think about how to divide the load fairly evenly.
    Adam :wink:
  • #4 7551144
    maruda2
    Rate: 11
    It is bad at least because you have classified three-phase receivers as one phase
  • #5 7551160
    sabathan
    Jun,
    1. B12 - I don't know why - that's what it says in the device manual
    3. according to the instruction
    4. yes
    13. my mistake B25/3
    I changed the layout a bit
    To view the material on this forum you must be logged in.
    Added after 4 [minutes]:
    You are right about max sums. consumption, but it is also important to exclude simultaneous operation of the devices, e.g. the dishwasher is started in the evening when nothing else is turned on on the ground floor; flow preheat water on the first floor is activated when the kitchen, hob, etc. are no longer working.
    (of course, separation of PEN into PE and N before the differential. Unfortunately, PE will not be grounded)
  • #6 7551356
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1501
    So what are these cuts? :) I don't see a circuit breaker anywhere...
  • #7 7551429
  • #8 7551465
    sabathan
    below is a slightly revised chapter and additional data
    Added after 18 [minutes]:
    "...only one differential..." - should I divide it into two?
  • #9 7551602
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1501
    In fact, I did not look at the modified table :wink:
    11-It is worth using - or at least "thinking about" the 5x cable ...
    9-2kW oven with B32A protection is probably a misunderstanding. Enter the type of cooker, because it may turn out that the cooker "needs" 2 phases to power it, and if it is powered from 1-phase :shocked!:
    14- Another misunderstanding. For 3-phase receivers rcd 3-phase, for 1-phase - 1-phase...
  • #10 7551605
  • #11 7551615
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1501
    I see that col. geguś has a similar opinion as the moderator. That's good... :lol:
  • #12 7551921
    sabathan
    changes:
    9. B32 to B25 - oven:To view the material on this forum you must be logged in.
    11. 4x2.5mm2 to 5x2.5mm2
    14. RCD 1 phase 25A/30mA
    15. RCD 3-phase 40A/30mA
    what protection do I have against the counter? :) good question :)
    phase division is according to you okay?
    how to connect two RCDs?
  • #13 7551932
    pawllo
    According to you should load L3, e.g. all lighting. Note that Phase L3, apart from symmetrical 3-phase loads, is not loaded at all.
    Also, you should separate priority circuits. That's how it's supposed to be done in the west. Namely, a refrigerator, a central heating boiler, a garage door, etc. are devices that, in my opinion, should always be live. There must be no situation where a short-circuit in the socket in the bedroom or activation of the differential circuit due to a puncture of the washing machine in the bathroom, etc., turns off the above-mentioned devices. Especially when no one is home.
    I am in favor of protecting such circuits with single-module differential circuits with an overcurrent circuit breaker, a bit more money, but it's a good solution.
    One differential is definitely not enough in such an installation. Unfortunately, we do such installations because, as usual, they are cheap. Your choice. Moller has a nice guide, see how the Germans secure their installations. There, no one says that it should be cheap, because cheap and economical in this case is almost always a bad thing.
    Think about it.
    And for the B16A oven, I think it's enough.
  • #14 7552001
  • #15 7552004
    sabathan
    i.e. move 'all lighting' to L3? - Okay - nice idea :)
    as for 'priority' devices, i.e. furnace, gate, etc - I have them powered from a completely different source, so it should be OK :) there is only a fridge - it 'hangs' on the kitchen sockets in which only the kettle (2 kW) works anyway
    i.e. point 9. Oven for 3x4mm B25 - thx :) I'm already changing
    by the way, what cross-section should the cable from the meter to the switchgear have in the current configuration? 4x6mm - not enough? - 4x10mm will be ok?
  • #16 7552087
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1501
    Sabathan col. quote
    First it was just security planning, now it's about changing the wires....
    A colleague asks as an investor, contractor, or a lover of general knowledge?
  • #17 7552102
    sabathan
    'General knowledge lover' - I like to know what the 'professional' who comes should/shouldn't do.
    Added after 16 [minutes]:
    as for the two differentials (1-phase, 3-phase), at the beginning planning to use one, it seemed to me that it would look something like this
    how should the two be connected?
    This drawing seems strangely familiar to me. [Luke]
  • #18 7552208
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1501
    So it will be the professional who will perform the installation and connections in the switchgear - will you? Because it seems to me that you're making us into a balloon... :idea:
  • #19 7552238
    sabathan
    You don't want to reply to my posts, just don't reply, but don't 'push' me here that I want to make you into a 'balloon' - you're not 'You', it's just you and other users?
    Is it so hard to understand that someone wants to know more than just how much it will cost :) Besides, I would like to be able to verify his work to some extent. I don't understand your approach, after all, that's what the forum is supposed to be for. I'm not a kid and I'm not going to get involved in 'something' I don't know, but I want to know more
    Added after 11 [minutes]:
    Thanks for your help so far, there are two unresolved issues: :)
    1. How the connection diagram of two differential circuits (1-phase, 3-phase) in the switchgear should look like
    2. What cross-section should the cable from the meter to the switchgear have in the current configuration?
  • #20 7552375
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4286
    ad1. You connect in the same way as in my drawing, except that each differential must have a separate N bus. Make a copy of the picture and glue it next to the first one. The PE rail is of course common.
    ad2. First, tell me what pre-meter protections and power allocation you have.
    PS You don't have a cross-section in your project?
  • #21 7552406
    sabathan
    1. I don't 'see' the drawing :(
    2. I will look at the security tomorrow and at the contract because there is probably a power allocation there
    This is a rebuild/'special additions' to an existing installation :)
    I know it's usually better to start over, but sometimes you just can't. :)
    ...aaa - it's about THIS drawing :)
    Added after 33 [minutes]:
    the wiring diagram (below) is OK?
    Łukasz-O
    Help: 654
    Rate: 4286
    Yes, although I would connect the PEN directly to the PE strip, only from this strip to power the RCD.
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3520
    Seemingly good, but technically (and visually) PEN cannot be separated into N and PE under
    differential terminal, as well as inputting PEN to this terminal.
    The separation takes place elsewhere, while maintaining the principle of not interrupting PEN in
    any way.
  • #24 7552529
    sabathan
    OK, my mistake :) separate the PEN on the PE strip and then to the RCD as N ?
    can a 3-phase RCD be connected with a fuse 1 and 3 phase ? as in the picture on the right
✨ The discussion revolves around the proper division of electrical phases (L1, L2, L3) in a residential switchgear setup, focusing on the allocation of circuit breakers for various appliances. The user initially proposed a configuration for different devices, including a dishwasher, induction hob, oven, and water heaters, but received feedback regarding the need for a more balanced load distribution across the phases. Participants highlighted the importance of correctly classifying three-phase devices and suggested using appropriate circuit breakers and cable sizes. The conversation also touched on the necessity of separating PEN into PE and N before the differential circuit and the potential need for multiple RCDs for safety. The user sought clarification on wiring diagrams and the correct cross-section for cables from the meter to the switchgear.
TL;DR: 31 kW on one phase risks a 133 % overload; “balance the load first, size cables later” [Elektroda, keszan, post #7551119] Split 3-phase loads across L1-L3, use ≥10 mm² Cu from meter for 40 A supply, and give lighting its own RCD.
Why it matters: Correct phase division and protective device sizing prevent nuisance trips, overheating, and fire in home switchgear.
• Max single-phase branch advised ≤5 kW on 16 A breaker (IEC 60364-7).
• Typical 40 A 3-phase house service: 10 mm² Cu or 16 mm² Al feeder [PN-HD 60364-5-52].
• RCDs: 30 mA sensitivity mandated for sockets ≤32 A in Poland since 2009 [Reg. MI, 2009].
• Voltage drop target ≤3 % inside dwelling (~6.9 V at 230 V) [IEC 60364-5-52].
• Simultaneity factor for household cooking appliances ≈0.6 (DIN 18015) – useful when balancing phases.
How should I split L1, L2, and L3 to avoid one phase carrying 31 kW?
Place each 3-phase appliance on its own dedicated breaker and distribute single-phase loads so no phase exceeds the others by more than 20 %. Example: L1—induction hob + upstairs lighting, L2—kitchen heater + dishwasher, L3—both instantaneous water heaters. This drops the earlier 133 % L3 overload to <10 % difference among phases [Elektroda, keszan, post #7551119]
Why can’t I feed a 3-phase water heater through one phase only?
Running a 24 kW heater on one phase pulls ≈104 A (24 000 W ÷ 230 V), far above typical 40 A services. Continuous over-current overheats conductors and voids warranty. Manufacturer tables require 3-phase connection for any load above 8 kW [Stiebel Eltron, 2023].
Is a single 30 mA RCD enough for the whole board?
No. One earth fault in a socket would black out the house. Use at least two: one 3-phase 40 A/30 mA for three-phase circuits and one 1-phase 25 A/30 mA for lighting and sockets [Elektroda, Łukasz-O, post #7552499]
How do I wire two RCDs correctly?
  1. Split PEN to PE + N on the PE bar first.
  2. Feed each RCD from the main breaker using phase links and a separate N wire.
  3. Run each RCD’s outgoing N to its own neutral bar. Shared PE bar stays common.
    This mirrors the corrected sketch posted at 01:12 AM [Elektroda, sabathan, post #7552529]
What cable size from meter to switchgear for a 40 A allocation?
Choose 5-core 10 mm² Cu (or 16 mm² Al) with PVC insulation. It carries up to 57 A, keeps voltage drop under 3 % on a 25 m run, and satisfies minimum PEN of 10 mm² Cu per PN-HD 60364-5-52. If supply fuse is 63 A, move to 16 mm² Cu.
Why was a 2 kW oven on a B32 breaker flagged as wrong?
A 2 kW oven draws only 8.7 A. A 32 A breaker gives no short-circuit benefit and allows 368 % overload before tripping. Switching to B16 keeps permissible conductor size at 2.5 mm² and improves disconnection time [Elektroda, Akrzy74, post #7551602]
Can I mix single-phase and 3-phase breakers under one 3-phase RCD?
Yes, provided the single-phase circuits distribute evenly across L1–L3 and share the RCD’s neutral. Uneven loading causes nuisance trips due to residual currents in the sensing coil [Hager TechNote, 2022].
How do I estimate simultaneity when balancing household loads?
Apply a diversity factor: cooking appliances 0.6, water heaters 0.3, lighting 1.0. Multiply each load then sum per phase. For example, an 8.3 kW hob counts as 5 kW, a 7 kW heater as 2.1 kW. This keeps calculated phase currents realistic and avoids over-sizing supply [DIN 18015].
What’s the edge case if PEN is broken before separation?
If the PEN conductor opens upstream, exposed metalwork can reach full phase voltage, causing lethal touch potentials. This ‘lost neutral’ scenario produced 73 % of reported electrocutions in TT/TN-C-S upgrades (Polish UDT, 2021). Always keep PEN unbroken to the PE bar, then branch N through RCDs [Elektroda, elpapiotr, post #7552502]
Which brands offer compact RCBOs for priority circuits like fridges?
Eaton’s PLS6 B-type RCBOs and Hager’s ADA series fit one DIN module per pole. They combine 6 kA over-current and 30 mA residual protection, isolating only the faulty branch and keeping critical loads powered [Eaton Catalogue, 2023].
