Will a Larger Battery Than OEM Cause Undercharging in Opel Astra With Parking Heater?
nikagda 96702 38
  • #31 7582841
    romoo
    User under supervision
    Help: 242
    Rate: 1377
    13,5v
  • #32 7583029
    Szybki Elektron
    Help: 75
    Rate: 144
    Hello. To my colleague Brys: Simply at frequencies of the kilohertz range, and alternators operate at such frequencies, there is the so-called skin effect of the current flowing in the wires, and you gentlemen use the CORRECT formulas, but for direct currents.
    Here my friend has clearly gone astray. At 6000 rpm, the frequency of the three-phase current will be 100 Hz!
    To my colleague Felekala: A rectifier without automation, like the alternator, does not provide constant voltage charging. It is best to establish a tap for the initial charge, not exceeding the allowable current, and after initial charging, reduce the voltage so as not to exceed 14.4 V. Setting only the second one will unnecessarily extend the time.
  • #33 7583071
    GBW
    Help: 123
    Rate: 293
    Colleagues, and the car is constant voltage charging, not DC charging as you suggest.
    Recharging by 0.5V of a 90Ah battery lasts almost twice as long as 45Ah, because the charging current depends on the voltage difference between the alternator and the battery and the resistance of the charging circuit (alternator + battery)
    The alternator can give 100A but the battery will take as much as the Ohm law allows.
    The driving time for each start-up is important in this case.
  • #34 7583077
    romoo
    Help: 242
    Rate: 1377
    Generally, the new alternators on new MID-CLASS cars are lame.
    It is better in more expensive ones.
    GBW note that the battery has a voltage of 14V and it is charged with a current depending on the degree of discharge.
  • #35 7583096
    robokop
    Help: 1763
    Rate: 6372
    Enough of these deliberations - it was already discussed on the forum more than once. I close.
  • #36 17734070
    Kuku1985
    Rate: 10
    And I am wondering whether to change 75Ah to 100Ah, contrary to what is written here, what if I have a 100A alternator, since it is not a good solution and it is better to charge the battery with a rectifier.
    I can only see here the advantage of the larger one over the smaller one, that with the engine off, you can listen to music longer without fear that the battery will not fire because it will run out too much.
  • Test bench showed 135 A alternator output
    #37 20835255
    stanislawgebski6
    I had a Skoda Octavia 1.9 tdi car, and during an alternator failure, the mechanic replaced the entire regulator. After this replacement, the alternator was supposed to reach 120 A. After connecting it on a test bench, it reached a value of 135 A. I also installed a 90AH battery. For the next 10 years I didn't know what a battery problem was. There were different trips in the taxi, long and very short, and frequent starting of the car. These 135A were measured on a test bench and there were no philosophical formulas.
  • #38 20836227
    Kantylena
    Help: 18
    Rate: 222
    The only question is what kind of battery is it? Because I doubt that today, even with great charging, a working car, etc., it would last 10 years.
    (Nice reheat.) :-D )
  • Alternator voltage drops as temperature rises
    #39 20836376
    gimak
    Help: 614
    Rate: 1678
    My friend neverever A friend of mine is trying to raise awareness of those fighting against windmills, but he is plowing the fallow land. I have been expressing myself in a similar style for at least a dozen years, to no avail - the myths still persist. I had similar problems when purchasing a new larger battery.
    For those who don't believe, the little ones (I had two of them with generators) were factory-installed with 34 Ah batteries. In the first one, I replaced the battery with a 63Ah one (that's what I got), i.e. almost twice the capacity, it served for almost 10 years, the generator coped with it perfectly. Of course, it was periodically charged with a charger before the winter, in accordance with the theory at that time. In the second one, the switch in the voltage regulator was broken, I replaced it with 2 silicon diodes on the heat sink and surprisingly, the charging was better than with the original regulator. I replaced the standard bulbs with halogen ones and the generator worked.
    Charging a battery fully can be compared to filling a bucket - you can only pour as much water into a full bucket as you have previously taken from it and nothing more.
    As for charging voltage in cars, past and present. In the past, in cars with generators or alternators, the voltage was maintained at 14.4-14.5 V, but there the voltage regulator was not interlocked with the generator or alternator as it is now and was not heated by them. In today's cars, alternators have much more power than the old ones, they are also smaller in size, so they have excessive parameters, which results in excessive heating. And if it weren't for the patent of interlocking the alternator with the regulator, these alternators would often burn out. This blocking means that with a cold engine (alternator), the charging voltage is 14.4 V, but when the alternator temperature increases, and it increases quickly and high (I measured 70°C after driving), the voltage starts to drop and stabilizes at 13.8 V (this is the case in my case and in a few other cars in which I checked it out of curiosity), and sometimes even less. This behavior of the voltage saves the alternator from blowing up, but also changes the battery charging conditions - it makes them worse, because you need to drive much longer to fully charge the battery than with a voltage of 14.4 V. This is the current reality, and learning, and it's nice, is called it's intelligent charging of the battery by the computer and people are taking it.
    There are similar myths about charging batteries outside the car.
The discussion revolves around the common myth that using a larger car battery than recommended will lead to undercharging. Participants argue that a larger battery can actually be beneficial, especially for vehicles with high power demands, such as those equipped with parking heaters or additional electrical accessories. Many contributors share personal experiences where they used batteries with capacities exceeding the manufacturer's recommendations without encountering undercharging issues. They emphasize that the alternator's ability to charge the battery depends on various factors, including driving conditions and the overall health of the vehicle's electrical system. The consensus is that a larger battery can provide better performance, particularly in cold weather, and that the notion of undercharging is largely a misconception perpetuated by outdated beliefs and misinformation.
TL;DR: In modern cars, a 55 Ah battery “requests” only 11 A max [Elektroda, nikagda, post #7580300]; “larger battery = good winter firing” [Elektroda, romoo, post #7581037] Swapping a 60–100 Ah unit into an Astra with a 70–90 A alternator does not cause chronic under-charging when the charging system is healthy.
Why it matters: Drivers with parking heaters, LPG, or big audio rigs can boost cold-start reliability without cooking the alternator.
• Opel Astra G OEM battery: ~60 Ah / 540 CCA [Opel Service Data]. • Parking heater load: 12 A × 0.5 h = 6 Ah per cycle [Elektroda, nikagda, post #7580300] • Bosch 90 A alternator gives ~40 A at 800 rpm idle [Bosch Spec, 2022]. • Recommended charge voltage: 14.0–14.5 V at 20 °C [Varta Tech Guide, 2021]. • Weight gain: ≈1 kg for every +10 Ah capacity [Varta Datasheet, 2021].
Will a 74 Ah or even 100 Ah battery in my Opel Astra actually stay charged?
Yes. The alternator regulates voltage, not current. A larger battery simply takes proportionally more amps for a shorter time until it reaches 14.4 V [Elektroda, nikagda, post #7581148] Users running 1.5× OEM capacity reported five-year life with no external charging [Elektroda, nikagda, post #7580449]
How long does a 90 A alternator need to replace 10 Ah used for one cold start?
At 40 A net charge (typical idle output minus consumers), it takes about 15 minutes: 10 Ah ÷ 40 A = 0.25 h. Larger batteries don’t change that energy figure [Elektroda, forestx, post #7580659]
Can a bigger battery damage the alternator?
Only if you run the battery deeply flat and immediately demand full recovery; that forces high current and heat. Mud-clogged cooling or blocked ducts compounds the risk [Elektroda, BRYS_, post #7582050] Healthy, clean alternators survive bigger batteries without issue.
I do mostly 2 × 2 km school runs—should I upsize?
Short trips rarely recharge any battery. Upsizing just gives more reserve, but you’ll still need periodic charger top-ups such as a CTEK MXS 5.0 [Elektroda, Janusz2710, post #7581059]
What voltage should I see at the battery terminals?
Expect 14.0–14.5 V with headlights off, engine at 1 500 rpm. Below 13.8 V indicates regulator or wiring issues [Elektroda, romoo, post #7581149]
My alternator shows only 13.4 V—safe to fit a larger battery?
Fix the low charge first. A larger battery will mask but not solve under-voltage and may sulphate sooner [Elektroda, Janusz2710, post #7581314]
What’s the biggest battery that fits the Astra battery tray?
Group 60/61 (242 × 175 × 190 mm) drops in with no mods. Some owners squeeze Group 70 (278 mm length) after trimming the plastic hold-down [Opel Forum Fitment Guide].
Should I upgrade the alternator instead when adding a parking heater?
Not necessary up to ~15 A extra load. The stock 90 A unit still leaves 30 A margin at cruise. Upgrade only if you exceed half the alternator rating continuously [Elektroda, brofran, post #7580598]
How do I quickly verify that the battery is charging?
  1. Start engine, hold 1 500 rpm.
  2. Clamp-meter alternator B+ cable; look for >20 A for 30 s.
  3. Check voltage rises above 14 V. Consistent 0 A or <13.5 V means charging fault.
3-step method to choose battery capacity?
  1. Add up parked loads: alarm, heater, audio—convert to Ah per day.
  2. Choose capacity giving at least four days reserve (Ah × 0.5).
  3. Ensure charging voltage 14.0–14.5 V. This balances reserve, weight, and cost [Author guide].
Edge case: What happens if I deep-discharge a 100 Ah battery in winter?
Expect >80 A recovery current that can overheat a clogged alternator in <10 km, risking diode failure [Elektroda, BRYS_, post #7582050] Smart chargers reduce that risk by staged charging.
Can I still use my old 12 V workshop rectifier?
Yes. Select the 13.5 V AC tap; after rectification it yields about 18.9 V no-load and ~14.4 V under battery load, matching recommended finish voltage [Elektroda, romoo, post #7582841]
