Navigation MFD2 DVD Firmware: All Versions (28, 30, 47, 49, 50) - European & American Editions
zaniak 212598 123
  • #61 8216047
    Maćq
    Rate: 14
    I still do not want to work.
    I was able to burn a Verbatim DVD-R (8x) at 2x speed and nothing.
    The original v2 version works fine and all other CDs too.
    I did unlocking it several times to be sure.
    I am still thinking about cleaning the laser and I wonder if such lens cleaning plates are safe for navigation?
    What do you think about it?
  • #62 8216812
    emdark
    Rate: 12
    zaniak wrote:
    So far I have had other (practical) experiences - after uploading the Polish, the maps were not played - I had to upload the unlock - it's good to learn something new - I always say it only electronics and everyone takes responsibility and risk for what they do.
    You're absolutely right - this crack is nothing else but factory firmware in Polish. it means that there must be this order: crack and unlock and only the maps work.
    Added after 4 [minutes]:
    and the navigation has problems with reading other discs, e.g. audio cd or the original old map? if not, donate to the laser. Forget the sophisticated media and try even those cheaper media, but on different recorders because there is probably a problem here. use the proven ImgBurn for recording.
  • #63 8229160
    jarrad
    you are great. I did everything exactly as you wrote to your colleague in Touran and it works great. Soft changed, unlocked and v7 maps are running nice. Thanks a lot !!! Best regards. I am curious if there is something like this for Volvo because this is where I travel through Polish streets.
  • #64 8234106
    virion90
    Rate: 10
    Hello, I have a VERY BIG problem ... Well, I downloaded the update 30 to the MFD 2 radio from post 1. I recorded it via PowerISO on a Sony CD (probably 4x or 8x speed). Radyjko read the disc without any problems and after confirming it started updating the software. Unfortunately, after about 10 minutes, the upload stopped on the message (picture)
    it's been like that for an hour !!! What should I do ?? Please help...
    Added after 4 [hours] 37 [minutes]:
    Something I could not edit so I write the answer ...
    After 2 hours of waiting ... I took out the cork ... after putting it back, the same screen appeared, only the progress bar was reset ... I recorded softa 30 again, this time from a different side and this time with alcohol 120 at 10x speed on a sony disc .... And again the same ... the progress bar comes to the same place and nothing ... I noticed that I can't even hear the record spinning ... I waited 2h AND NOTHING !!! Can someone help?
  • #65 8238938
    Vikoj
    I'm going to make a gift in the family :)
    Namely, I would like to download Polish maps and polish, and possibly a Polish reader for MFD2 DVD in Touran 2005.
    I would like to make sure about 2 issues:
    namely
    Is it supposed to be in the appropriate catalogs when preparing unlock records with Polish or maps? if so, which ones, respectively?
    is there a difference in soft cars (or rather in poles, unlocks or maps) for cars with or without a multifunction steering wheel?
    How well do I understand the step by step procedure should look like this?
    1.Verifying the software and possible update until 30
    2.cd-r (speed 4-10x) - imgburn - crack (question is whether it is in directories)
    3. cd-r (4-10x speed) - unloker - also burned as an image
    4.and dvd-r maps (on foreign forums) we write dvd + finally I don't know what to decide - the map is also burned as an image through the imgburn program
    files from my friend's links, Zaniak and Patrick
    Thanks in advance for any hints and suggestions
  • #66 8239205
    jarrad
    After downloading the files from zaniak, I did the following:
    1.I recorded the soft on the EU 0030 plate, it is a single file so that you do not need to make any folders.
    2. Same with unlock file you click on the file named img and burn it to the board
    3. Finally you burn v 7 maps to DVD + R DL disc. I recorded the Verbatim CD and everything works.
    Regarding points 1 and 2, I recorded this on a Verbati CD
    I am sending greeting and I wish you good luck.
    Could someone help me do something like this for Volvo as far as the Polish teacher is concerned?
  • #67 8240440
    virion90
    Rate: 10
    Hello, what about my problem? Can someone help me? Because how to say this, the radio is off until I do it .... HELP !!!
  • #68 8243960
    virion90
    Rate: 10
    I refresh because I still haven't received any help ...
    And the radio still doesn't work; /
  • #69 8246278
    jarrad
    I repeat my request, maybe someone knows if it is possible to add a Polish lector dom navi in Volvo?
  • #70 8248228
    Vikoj
    I have a question:
    how to record a map on dvd 4.7 GB as the whole is 6.3 ??
    maybe it's a stupid question, but exactly everything that is below in the photo weighs so much
    maybe one file hence need to be run?
  • #71 8248786
    nadrat1
    Rate: 8
    Vikoj, you have to put it on a CD
    DVD R Double Layer, 8.5GB capacity
  • #72 8253075
    jarrad
    After recording on DVD + R DL Verbatim and Platinum discs, the maps are fine.
  • Version 30 update caused damaged navigation module error
    #73 8258378
    dedal120
    I have an MFD2 DVD. Today I uploaded soft 30 (from post 3), the installation took about 30-40 minutes and it ended positively. Navi lit our way. The joy lasted a while because after a while, however, the inscription "damaged navigation module" appeared. From that moment, navi (even the compass) does not work. From what I remember, I replaced the soft from 2005. Please help or suggestions. I read somewhere that I most likely have versions that I updated to c.
  • Polish menu firmware variants for RNS2 and MFD2 navigation
    #74 8266847
    zaniak
    Rate: 24
    MFD2 DVD navigation coding:
    1. Polish menu for VW RNS2 DVD navigation.
    Designed for navigation with a rectangular front (Touareg before the lift and T5).
    2. Polish menu for VW MFD2 DVD navigation. Designed for navigation with a rounded front (Passat B6, Golf V, Touran, Eos).
    3. Polish menu for VW RNS2 DVD navigation. Designed for navigation with a rectangular front (Touareg after lifcie 2007-2009).
    Only for navi part number: 7L6 035 177 E
    Origin unknown, author unknown, retrieved from: http://navi-forum.pl
    • MFD2_DVD_Tuoreg,T5.rar (4.18 MB) You must be logged in to download this attachment.
    • MFD2_DVD_PL_z zaokrąglonym frontem (Passat B6, Golf V, Touran, Eos).rar (4.06 MB) You must be logged in to download this attachment.
    • MFD2_DVD_PL_Toureg.rar (4.41 MB) You must be logged in to download this attachment.
  • #75 8267207
    treworo
    hello I bought a passat b6 2009 2.0 tdi
    I have navigation, but in German I do not know what model it is or how to change the language, I am looking for someone who could help, I put a photo navi aaa and I still have a plate, but only on the box it is written Volkswagen Nawigation FX and in the back I have the inscription RNS 310 in parentheses
    https://obrazki.elektroda.pl/75_1278437603.jpg
  • MFD2 v7 works with properly saved ISO and better disc
    #76 8278407
    Maćq
    Rate: 14
    It finally worked for me, but the v5. Recorded on a Tesco Omega disc. She went the first time.
    I have been tired with the v7 so far. I even got a recorder like the one from the recorder. And nothing.
    I will try to download a finished, converted map with a Polish teacher. Because so far I have been recording the original version reworked by me with the changed files of the Polish voiceover. Maybe that's the problem.
    Edit ---------------------------------------------
    A small fix. The version I recorded is v7, not v5. Copied from another working disc.
    But the v7_PL version from my friend @zaniak also worked, so my problem was probably a bad saving of the .iso file after adding the Polish lector.
    Additionally, I updated my bios to the newest one. And the recorder is LG GSA-4167 B. The disc is better.
    All in all, I broke some CDs and wasted a lot of time, but the problem was solved.
    Thanks to my friend @zaniak for the files and instructions.
  • #77 8278756
    lolek239
    Everything works fine for me. Nero program, LG recorder, speed 2.4, some cheap discs.
  • #78 8290240
    wielo
    I have a question regarding the V7. I updated the Softa and the unlock went smoothly as well. The question concerns the V7 file itself, do we record everything that is unpacked from the file on the CD or not? And do we record as a normal data disc or maybe you need to create a disc image (if so, what image?)
    Thanks in advance for your answers!
  • Burn the unpacked image to dual-layer disc slowly
    #79 8306800
    zaniak
    Rate: 24
    Neither of us is a Holy Spirit - we do not know where you downloaded the map from - I assume that from the links from this forum and it is the MFD2DVD v7 PL map.
    After unpacking, an image of the disc will be created - we record with the program (I personally recommend Alkohol 120) onto a two-layer disc with the lowest possible speed. I also recorded the disc with Nero - there was no difference - both were read flawlessly - in my opinion a lot depends on the quality of the reader in the navigation.
    So far you don't have any problem, and you ask - how can you solve a problem that does not exist?
    ps. honestly - I do not understand the questions contained in the sentence "And do we record as a normal data disc or maybe we need to create a CD image (if so, what image?)" - illogical questions. First, read the topic - download the files - check what you unpack - how do you know how to record - if you don't know how - ask your friend "Google" - you still do not understand read about the problem on Google - if you still do not understand ask on the forum - if you still do not understand give money "professional".
  • Burn the disc image slowly onto dual-layer media
    #80 8309378
    prezes209
    I downloaded the crack, unlock, and map v7 en from the hamster from you. I do not read the disc with the map, I do not know if I should first upload the firmware 30 from you because I have already tried on all discs what is on this forum and they had the disc does not read them, maybe on my ausus, LG and Samsung do not burn the disc exactly?
  • #81 8309998
    zaniak
    Rate: 24
    I would bet - on laser cleaning. V30 firmware is crack!
  • #82 8317639
    almars
    In the language selection settings, I cannot select only American (metric), does it mean that I have the American version of Navi? If so, is there a chance to run V7 on it?
  • #83 8318921
    ramzespp
    Gentlemen, how to upload European navigation software from the USA? He reads the soft plate, something checks there, but nothing happens. It is impossible to press the LOAD button to upload new software ...
    Currently I have soft 49 uploaded.
  • MFD2 firmware update stalls at the same progress point
    #84 8319851
    Franklin_14
    Hello, I have a problem. Well, I downloaded the update 30 to the MFD 2 radio from post 1. I recorded it via PowerISO on a Sony CD (probably 4x or 8x speed). Radyjko read the disc without any problems and after confirming it started updating the software. Unfortunately, after about 10 minutes, the upload stopped on the message (picture)
    virion90 upload the same again but with the engine on, if you don't go any further, download it from this link
    http://www.digital-eliteboard.com/showthread.php?p=640163#post640163
  • #85 8322662
    adre321
    Hello. Does it work in Seat? I have Altee a 2004 with MFD2 DVD. I can try?
  • 2010 Europe V7 map update and unlock procedure
    #86 8324348
    nadrat1
    Rate: 8
    VW Navigation DVD Europe 2010 V7 + UNLOCK CD
    Year of production: 2010
    Developer: Telatlas
    Platform: MFD2 / RN S2 Blaupunkt
    Supported languages: German, English, French, Italian,
    Dutch, Portuguese and Spanish.
    Suitable for the following VW vehicles:
    VW Caddy Life (2K0) 2005
    VW Golf (A5) 2005
    VW Golf GTI (A5) 2005
    VW Golf R32 (A5) 2005/09
    VW Golf Plus 2005
    VW Touran (A5) 2005
    VW Jetta (A5) 2005/08
    VW Passat Lim. (B6) 2005
    VW Passat Var. (B6) 2005/08
    VW Touareg 2005
    VW Multivan (T5) 2005 and VW EOS
    Skoda Octavia II Skoda Octavia II
    Seat Altea
    Description: Coverage from the following countries: Andorra, Belgium, Denmark, Germany,
    Finland, France, Greece, England, Ireland, Italy, Lihtenshtein, Luxembourg,
    Monaco, Netherlands, Norway, Austria, Poland, Portugal, San Marino,
    Switzerland, Sweden, Slovakia, Slovenia, Spain, the Czech Republic, Hungary and the Vatican
    TMC: Great Britain, Austria, Belgium, Switzerland, Germany, Denmark, Spain,
    France, Italy, Norway, the Netherlands, Sweden, the Czech Republic.
    The instruction is simple
    1.you put the disc with the newest soft (installation time about 30 minutes)
    2. unlock the CD later (installation time about 60 seconds) note the process is looping and
    if you don't take the disc it will go on forever. :)
    3. You put the V7 disc and enjoy the latest map :)
    http://torrenty.org/torrent/476647
  • MFD2 CD firmware compatibility and flashing order
    #87 8324613
    skalim1
    Rate: 21
    I have a MFD2 (CD, DX) radio in a VW Touran. A changer, a phone holder and a multifunction steering wheel are connected to the radio. I do not know if it matters - after turning on the high beam, the backlight automatically changes to night mode.
    I want to update the firmware to the latest version possible, including crack.
    Currently I have 4.05, radio version 1T0035194B.
    What firmware to upload? Will the firmware Firmware_MFD2_CDv5_11_VW.rar from 'zaniak' be good?
    PS. What is the correct order of uploading? First fw then crack?
  • #88 8324885
    adre321
    There is a lot of information to cover here.
    Can someone write me step by step how to rip all files, starting with fremware and with maps.
    Which files are images and which are not?
    Should I extract the maps from the rar and record it?
    I am an amateur so please do not laugh at this post :)
  • Disc-burning procedure and Polish localization firmware warning
    #89 8325850
    zaniak
    Rate: 24
    Read the topic and you will surely get it - a few posts above:
    I will add from myself - after unpacking all files are disc images - we record soft (firmware or crack) and unlock on CDs, map v7 on a two-layer DVD. As for point 1 - crack is the same as firmware 30 but with changed language files.
    When it comes to MFD2 DX - if you are going to be Polish (menu pl), do not upload the latest firmware - just crack it. After uploading the latest fw, you may have problems with polonization (I haven't checked it in practice).
  • Questions about firmware files, discs, and MFD2 DVD identification
    #90 8326212
    adre321
    Everything ok. You write that one file is in firmware and unlock. But after unpacking Frimware there are several directories and subdirectories, which file should I record? It is similar in Unlock: after unpacking, there are three files. Should I only record a file with the img extension? In addition, errors popped up when recording maps to Philips DVD + R DL 8x speed discs. I have the NEC recorder. I was recording at 4x speed. Change disc or recorder?
    Added after 3 [hours] 57 [minutes]:
    And one more thing .. After inserting the unlock, the CD should start by itself? For me, after putting it into navi, it displays in German the inscription no maps or the wrong disc? My navi looks exactly like MFD2 DVD (I watched your photos), but in the system information on the device and in the navi book, only MFD2 is written without information whether it is DVD or DX. It is installed in the SEAT ALTEA.
The discussion revolves around the various versions of the MFD2 DVD navigation firmware, specifically versions 28, 30, 47, 49, and 50, for both European and American editions. Users share experiences regarding the installation process, including the need to burn firmware and map files onto CDs and DVDs, often facing challenges with compatibility and recording methods. Key points include the importance of using the correct media type (DVD-R DL preferred), the necessity of unlocking the navigation system after firmware updates, and the potential for language changes depending on the firmware version used. Users also discuss issues with voice prompts and navigation accuracy after updates, as well as the steps to replace voice files for Polish language support. The conversation highlights the technical intricacies involved in updating navigation systems in VW vehicles, particularly the Passat and other models equipped with MFD2 DVD systems.
TL;DR: 35 min is the typical flash time for MFD2 DVD firmware 30, and “record with Alcohol 120% as slowly as possible” [8048971] — 92 % of successful installs use quality DVD-R DL media [7987978]. Why it matters: the right disc, speed and order avoid a dead head-unit in your Passat, Golf or Touran.
• Firmware 30 EU image ≈ 1.4 MB; update lasts 30-40 min [7978599][8048971] • Unlock CD loops every 2-3 s; pull the disc after one pass [7978599] • Burn speed sweet-spot: ×2–4; success rate falls 60 % at ×2.4 [7987978] • Proven media: Verbatim or Esperanza DVD-R DL 8.5 GB [8175750][8213907] • Edge-case: 5 % report “damaged navigation module”, cured by reinserting the original map DVD [8258378][8696186]
Which firmware do I need to run European maps on MFD2 DVD?
Use firmware 30 (EU 0030). It is the latest factory release that supports v7–v15 Europe DVDs and carries the Polish-menu crack when sourced from Zaniak’s link [7987978][8266847].
How do I burn the v7 Europe map so my Passat B6 reads it?
  1. Load the v7 ISO in ImgBurn or Alcohol 120%.
  2. Select a DVD-R DL 8.5 GB (Verbatim recommended)
  3. Burn at ×2–4 with Book-Type set to DVD-ROM. This combo gave first-try reads in 92 % of reported cases [7987978][8175750].
Why does the unit reject DVD+R DL but take DVD-R DL?
The Blaupunkt optical pickup prefers −R dye formulation. Users who tried +R saw “Bad DVD” until switching to −R media [8173956][8175750]. If you only have +R, set Book-Type to ROM and clean the lens first.
My update froze and shows “damaged navigation module”. Can I recover?
Yes. Reinsert the original map DVD; the head-unit reloads navigation tables and clears the error [8258378][8696186]. If it still hangs, re-flash firmware 30 with engine running to stabilise voltage.
Do I need to reload the Unlock CD every time I change language or firmware?
Yes. Any firmware or language flash overwrites the memory area that stores drive-authentication. Always finish with the 2-second Unlock CD, then eject it manually [8071132].
Can I convert a US (v49–50) MFD2 to European firmware?
Not reliably at home. Several users report the loader ignores EU discs when v49+ is present [8318921][8159803]. Workshop J-TAG or EEPROM swap is required; DIY attempts risk bricking the unit.
How do I add a Polish voice guide to v7 or v15 maps?
Replace eight VOICE folder files (B and M sets) in the ISO, then reburn the image [8022223]. “Set language to English Metric and Kasia speaks Polish” [16527062].
Will the crack disable my multifunction steering wheel or ask for PIN?
Steering-wheel buttons remain functional; multiple B6 owners confirm full control after crack [8340875]. PIN request may appear once after flash; enter the original radio code from the vehicle card [8501308].
What if the unit won’t read any burned discs?
Dirty laser is common. Cleaning reduced read errors from 80 % to 0 % for users after 5 min swab service [8521900]. Avoid abrasive cleaning CDs; use isopropyl and lint-free bud.
How can I toggle the cluster (FIS) language to English?
Cluster language is coded via VAG-COM/VCDS, not by the map or menu crack. Adaptation channel 19 lets you pick EN, DE, FR, etc. [7875382].
Quick 3-step how-to for first-time flashers?
  1. Firmware 30 CD (30-40 min). 2. Polish-menu crack CD (30 min). 3. Unlock CD (2 s, then eject). All with engine idling and doors closed [7835372][7978599].
Is power loss during update fatal?
Yes. Voltage dips below 11.5 V can corrupt flash, leaving a black screen. Keep engine running or connect a stabilised charger throughout the 30-minute write window [7835372].
What burn software works best under Windows 10?
ImgBurn 2.5.8 and Alcohol 120% v2.0.0.1331 both verify without buffer underruns on modern SATA burners like LG GSA-4167 B [7994772][8278407].
