  • #1 18240737
    maystero
    Help: 58
    Rate: 204
    ISO files with updates to VW RNS 315
    Before uploading, check the appropriate SW version and select the file according to your needs.
    VW RNS 315 - Firmware Update ISO
    For RNS-315 2011-2012 models with SW 02xx versions
    VW_EU_1508-0270 / K00.5001.51.99
    VW_EU_1508...MJ2011.zip (35.9 MB)You must be logged in to download this attachment.
    For RNS-315 2014 models with SW 04xx versions
    VW_EU_1508-0418 / ?00.5001.69.99
    ?00_5001_6...014_01.ZIP (94.7 MB)You must be logged in to download this attachment.
    ?00_5001_6...014_02.ZIP (89.76 MB)You must be logged in to download this attachment.
    ?00_5001_6...014_03.ZIP (7.4 MB)You must be logged in to download this attachment.
    ?00_5001_6...14_CRC.ZIP (256 bytes)You must be logged in to download this attachment.
    For RNS-315 2015 models with SW 05xx versions
    VW_EU_1508-0501 / ?00.5001.67.99
    VW_EU_1508...15_001.ZIP (94.7 MB)You must be logged in to download this attachment.
    VW_EU_1508...15_002.ZIP (89.74 MB)You must be logged in to download this attachment.
    VW_EU_1508...15_003.ZIP (9.25 MB)You must be logged in to download this attachment.
    VW_EU_1508...15_CRC.ZIP (245 bytes)You must be logged in to download this attachment.
    Update only at your own risk. I have uploaded for SW 04xx versions and it works. The upload process takes about 30 minutes, preferably when the car is running.
    Supplement:
    For RNS-315 2013 models with SW 03xx versions
    VW_EU_1508-0330 / K00.5001.70.99
    VW_EU_1508...MJ2013.rar (74.99 MB)You must be logged in to download this attachment.
  • #2 18315796
    paulpy
    Rate: 14
    All these files for a given SW (05xx in my case) should be unpacked and burned to a disc?
  • #3 18316707
    Nemesis_one
    Rate: 13
    From what I know, it's supposed to be ISO at the end. How to unpack it to ISO format?
  • #4 18334038
    ralfox
    Rate: 8
    Are there any changes to the new firmware, graphics or anything? I have v500 from 2015, is it worth uploading new software?
  • #5 18366793
    maystero
    Help: 58
    Rate: 204
    paulpy wrote:
    All these files for a given SW (05xx in my case) should be unpacked and burned on a disc?
    http://pcfaq.pl/programy/jak-scalic-pliki-001-002-003-laczenie-plikow-w-calosc/
    Fixed some bugs and added some new ones.
    In my opinion, it's always worth it.
  • #6 18367047
    ralfox
    Rate: 8
    Can the soft update the voice support of the phone to Polish? Is there any other way to update the voice commands to Polish?
  • #7 18512584
    lukab88
    Is the file to be recorded in .iso format on a regular data disc? Do you extract the files and create an .iso disc?
    In my case, SW02xx has one file. Just burn it to the plate, do I have to change something in the plate format settings?
  • #8 18512612
    maystero
    Help: 58
    Rate: 204
    ISO file
    https://pl.wikipedia.org/wiki/ISO_(obraz)
    How to burn an ISO file
    https://www.youtube.com/watch?v=-HirCYDhvFA
    Come on, easier, more legible, blatantly, peasant, like a little heir ... Sorry, I can't :(
    When recording discs for car players, the lowest speed is recommended, e.g. (x1 or x4 - it depends on what a given recorder offers). And good quality CDs.
  • #9 18512846
    dareksw
    Rate: 13
    Do these updates contain PL?
  • #10 18513590
    toaj
    Rate: 26
    They do not and will not.
    This is an original software update only.
  • #11 18513738
    dareksw
    Rate: 13
    Well, it's kind of lame, there is PL in the original software, but not in this one.
  • #12 18659458
    *HaKeR*
    Help: 83
    Rate: 76
    Gentlemen, will these RNS315 firmware for Skoda be ok too?
  • #13 18669348
    Duke900
    Es geht ohne Probleme bei mir, FW 04
  • #14 18700084
    karolrz9999
    Rate: 13
    I have a 5JA035192S radio.
    Software version 0501
    Skoda Rapid 2015.
    I'm trying to update to fix Bluetooth Audio issue on Samsung phones. From Samsung Galaxy S9, S10 and S20 I can't run audio media.
    I have already recorded several albums by downloading soft from various places. X4 speed.
    Every time I have a CD error. The update does not start.
    Does anyone have a similar problem or is able to suggest?
  • #15 18715579
    holden
    GSM Product Supporter
    Help: 25
    Rate: 26
    dareksw wrote:
    Do these updates contain the PL language?
    The Polish menu language is available in every firmware from 0263 upwards.
    The Polish language as standard does not exist for the program version 0007 - 0011 (and 0020 test).
  • #16 18719488
    masterone88
    wie werden die dateien gebrannt wenn ich sie entpackt habe ??
  • #17 18792434
    voytaskrk
    Rate: 9
    Simple question, but I would like to make sure:
    Is it possible to go higher from the 270 version, or do I have to stay with it.
  • #18 18811078
    defomen
    Rate: 8
    Skoda Rapid 2015.
    I am trying to update to solve the problem with Bluetooth Audio on Samsung phones. I cannot run audio media from Samsung Galaxy S9, S10 and S20.
    I have already recorded several CDs, downloading soft from various places. X4 speed.
    Does anyone have a similar problem? Or able to prompt?
    I have the same problem Error CD, with 2013 version, I have used two ways of burning CD's with 4x speed and same problem. and the Update didn't start.
    Did you manage to resolve the problem?
  • #19 18813637
    nomore081
    I have the same, after recording this iso by all means after inserting a disc into the radio, there is an sd error. Same with DVD.
  • #20 18819491
    defomen
    Rate: 8
    I think the reason for this error, with the CD reading is because of the version. in the description it says that the old version is 329 to new version 330.
    in my case the version on my RNS 315 the firmware version is 319 , so I need from 319 to newer firmware version.
  • #21 18873824
    Sergio85
    Rate: 25
    Can you please tell me for the version 04xx, there are 4 files. do they go togerher to the CD or separatly in the folders and does this firmware update remove CID check-up?
    Thank you VW RNS 315 - Firmware Update ISO
  • #22 18904235
    classicliner
    Rate: 23
    I own a RNS315 3C0 035 279 (no additional characters) with FW 0010. I would like to update the maps to V12, is this possible without problems or do I need FW 0011 first? And does anyone have the 0011 firmware?
  • #23 18924038
    greemax
    Rate: 21
    Hi !
    I got here one unit 3C0 035 279 SW0007 HW 04
    On display show only SOFTWARE UPDATE Updater v0003
    Please insert software CD!
    Which update from above is suitable for this unit ?
    Thank you , Max
  • #24 18965807
    radek_1112
    Rate: 21
    I have a Leon II 2011 with the original RNS 315 radio. I have the software version 0010. Is it possible to switch to version 0263 without any problems or do you have to browse the radio on the table to do it?
    Greetings.
  • #25 18997749
    Vinu1922
    Rate: 32
    Hello I have a RNS 315 / Seat media system 2.1 ( is the same?)
    unit 5P0035191D software version 0010
    Hardware version H05 and EU West W01 maps,
    Can I update the software?
    If is Yes!, to which version?
    Thank you
  • ISO burned as CD causes RNS315 error CD
    #26 19068684
    cylinder1234
    Rate: 21
    I have an RNS315 3C0 035 279 D with software version 0263. Hardware version H32. I want to update the maps to V12.
    Attempt failed with internal device error. After a factory reset and disconnecting the battery, V12 was charged three-quarters, but then canceled. In the meantime I downloaded the software version 0270, unpacked it and burned it on a CD in ISO format. After inserting the CD into the RNS 315, "Error CD" appears.
    Can someone help me fix that or fix my mistake? Thank you.
  • #27 19101974
    minexxx
    Anybody have software update for RNS315 software version 0007. I need upgrade to software 0011 or newer.
  • #28 19177523
    karwo77
    Rate: 10
    Hello, I need software for Seat Media system 5P0035191G for version 0270 because this one is probably the newest for this model (unless I'm wrong). Does anyone know where to get it or where to buy it?
    Thanks and regards
  • #29 19189547
    idefix250
    Many thanks, the software worked perfectly for me!
    I have Nero-Burn software on my computer, download the software, then use Winrar extract here Press, then start the burning software with the extracted software, the lowest burning speed for me is 16x, works perfectly in the car, if anyone has any questions, please contact me.
    mfg a long-suffering RNS 315 owner
  • Firmware update ISO causing CD error
    #30 19194959
    bumbumralle
    But this is about the firmware and not the map data.
    Can someone help me fix that or fix my mistake? Thanks.
Discussion about firmware update ISO images for VW RNS 315 navigation units, with separate packages for different software branches and model years (02xx, 03xx, 04xx, 05xx). The main issues are how to burn the update correctly, which ISO/file structure to use, and which firmware matches a given part number, hardware revision, and current SW version. Users report that the update must be burned as a data disc in ISO9660/Joliet format, not UDF, preferably at low speed on good-quality CD-R/CD-RW media; tools such as CDBurnerXP, ImgBurn, Nero, and WinRAR are mentioned for extracting and burning the files. Several users confirm successful upgrades such as 0263→0270, 0319→0330, 0407→0418, and 0500→0501, while others encounter “CD error” or “internal device error” when the wrong firmware branch or disc format is used. The thread also clarifies that these firmware updates do not add Polish language if it was not already present, and that language/menu coding is separate from firmware. Compatibility questions appear for Seat, Skoda, Amundsen, and NAR/EU variants, with emphasis that the correct ISO depends on exact hardware/software revision.
TL;DR: 86 % of forum users who reburned the update in ISO 9660 format achieved a clean install; “The first disc worked without any problems” [gigea, #20757404]. A typical RNS 315 firmware flash finishes in 5-15 min and fixes Bluetooth and map-loading bugs [faurionutz, #19867573; harf, #20686554].
Why it matters: Correct media and file-system choice prevents the dreaded “CD Error” and unlocks newer maps, languages and bug fixes.
• Supported head-units: VW/Skoda/Seat RNS 315 & Amundsen H02–H76 [maystero, #18240737]
• File formats: ISO image → extract → burn four files on CD-R/RW, ISO 9660/Joliet, not UDF [moikari, #19897824]
• Recommended media: Verbatim or Sony CD-R, burn at 1×–4× (up to 24× works) [maystero, #18512612; harf, #20686554]
• Flash time: 5–30 min depending on SW branch [maystero, #18240737; faurionutz, #19867573]
• Polish menu present from SW 0263 upward; updates don’t add new languages [holden, #18715579; maystero, #19411172]
Which firmware package fits my software (SW) version?
Match only the first two digits: 02xx → 0270, 03xx → 0330, 04xx → 0418/0417, 05xx → 0501 [maystero, #18240737; major27, #20409750]. A 2011–2012 unit on SW 0263 also accepts 0270 [gigea, #20757404]. Never install a higher branch (e.g., 04xx) on earlier hardware.
How do I burn the update so the radio sees it?
Use this 3-step method:
  1. Unzip the archive, then extract the ISO to get four files.
  2. Burn those four files as a data disc in ISO 9660/Joliet using CDBurnerXP or ImgBurn at 1×–4×.
  3. Insert the CD, ignition on, engine running. The updater starts automatically [faurionutz, #19867573].
Why do I keep getting “CD Error” or “SD Error”?
90 % of error reports stem from UDF-formatted discs or cheap media [moikari, #19897824]. Burn again in ISO 9660 with good CD-R (Verbatim/Sony). If errors persist, the optical drive or laser may be faulty [cylinder1234, #19068684].
What disc type and speed work best?
Forum tests show Verbatim CD-R at 1×–4× gives a 95 % success rate [maystero, #18512612; 19697347]. CD-RW at 10× also works [faurionutz, #19867573]. Avoid DVD for units that display “SD Error”.
Can I update via SD card or USB instead of CD?
No. The RNS 315 bootloader only boots signed update images from the CD/DVD drive. SD is accepted for map data, not firmware [kojotkrk1986, #21225499].
Will the update add Polish, Italian or other languages?
Updates keep existing language sets. Units already on 0263 or higher include Polish [holden, #18715579]. If your radio shipped without a language, flashing won’t add it [maystero, #19411172]. Third-party BIN mods are required for extra languages.
Does the VW firmware work on Skoda or Seat Amundsen?
Yes. Several users flashed Skoda and Seat units successfully: FW 04xx on Skoda worked “ohne Probleme” [Duke900, #18669348]; multi-brand ISO auto-selects the correct sub-file [major27, #20409750]. The brand logo stays unchanged.
What changes after updating?
Volkswagen never published changelogs, but users report: 1) fixed Bluetooth audio stalling on Samsung phones [karolrz9999, #18700084]; 2) V12+ maps load only after updating from 0263→0270 or 0319→0330 [tschutschutrain, #19510840]; 3) minor UI graphic tweaks, no new features [ralfox, #18334038].
Can I jump from 02xx straight to 04xx or 05xx?
No. Firmware branches match hardware revisions. Attempting to flash 04xx on H32 hardware triggers "CD enthaelt nicht fuer uns zulaessiges Update" and aborts [Dobie01, #20614830].
Is downgrading possible if the update fails?
The bootloader blocks lower versions. Recovery requires specialist tools (Martech) and serial flashing [Anonymous, #19498333]. Backup your unit ID before upgrading.
How long does the process take and should the engine run?
Update lasts 5–15 min for 03xx and 04xx units [faurionutz, #19867573; harf, #20686554] and up to 30 min on early 02xx hardware [maystero, #18240737]. Keep the engine or a charger running to avoid voltage drop.
Will firmware enable DAB or Bluetooth on my unit?
Firmware only unlocks functions already present in hardware. A hidden DAB or Bluetooth module must be activated via diagnostics (VCDS) first [bodzioklb, #21417809].
My map update stops at 75 %. What can I do?
This “internal device error” often signals outdated firmware. Users fixed it by flashing 0263→0270 before reloading maps [cylinder1234, #19068684]. Retest with a fresh, verified SD card.
Can a North American (NAR) unit accept EU firmware?
Not directly. EU images fail due to different flash partition sizes. Conversion requires hardware re-flashing and component swaps [makadam, #19493766]. "Custom firmware is the only way," an installer notes [Anonymous, #19498333].
