Navigation MFD2 DVD Firmware: All Versions (28, 30, 47, 49, 50) - European & American Editions
zaniak 212598 123
  • #1 7618386
    zaniak
    Rate: 24
    All versions of the navigation firmware MFD2 DVD (28, 30, 47, 49.50)
    Note: Soft has not been checked ,
    according to soft descriptions 28, 30 are European versions, 47, 49, 50 American
    • Firmware_MFD2_DVD.rar (30 MB) You must be logged in to download this attachment.
  • #2 7722999
    zaniak
    Rate: 24
    You are wrong - this is the original navigation software (factory).
    MFD DVD Polish menu
    • Volkswagen MFD 2 DVD-język polski.rar (5.55 MB) You must be logged in to download this attachment.
  • #3 7725288
    sippl
    We will see what will come out of it, I will play this soft and tomorrow I will write about the effects.
    best regards
    Added after 2 [hours] 40 [minutes]:
    I'm currently uploading.
    There were a lot of problems with recording this downloaded file, you need to run it as a disc image, preferably in a program that creates a virtual disk and burn only the larger file.
    It is not a soft that only plays Polish, from what I can see it is an upgrade. My mfd2 dvd version was from 2005, it is from May 2007.
    So far, it has been taking an hour and all drivers for sound, graphics, GPS connections, etc. are loaded.
    Progress is, what effect I will write in the next post and attach photos
    It is not a soft that plays not only Polish language, from what I can see it is an upgrade. My mfd2 dvd version was from 2005, it is from May 2007.
    Added after 30 [minutes]:
    I'm done, the new upgrade from 2007 has been successfully uploaded, the Polish language menu works, of course, in Polish, although there are probably autostore and scan fader phrases, balance, at first glance, the rest is in Polish. In general, navigating in Polish, radio not necessarily. But it works, the sound seems better and the contrast as well, but it's just a subjective feeling
    I recommend it, although it's hard to get it properly on a dvd
  • #4 7834397
    Patricko
    Could someone tell you more or less how to upload it?
    My mind tells me that, for example, burn a crack to a CD (burn the image, of course) and then just put it in the navigation and follow the instructions in PDF?
    I have a Passat B6 from 2007 with MFD2 DVD navigation and I only have German there, even to English cannot be changed. Apparently, you just need to insert a navigation disc to change the language, but I haven't tried it yet.
    And these firmware files there are several packages, these 28.30 and 47.49.50.
    The car is from Germany, will it be soft one of these 28, and in the US version one of these 47 or higher?
    And what is better to upload? The latest firmware or a crack? Does it not matter? Is the latest firmware first, then crack?
    I will be grateful for a little hint.
    Best regards.
  • #5 7835372
    zaniak
    Rate: 24
    Wolisz po angielsku wgraj angielskie menu, wolisz po polsku - polskie
    http://chomikuj.pl/zaniak/Motoryzacja/Nawigacje+samochodowe-+wejd*c5*ba+tu+i+rozpoznaj+swoj*c4*85+!!!!!!I/Spolszczenia/VW*2c+Skoda * 2c + Seat / Instalacja + spolszczenia + MFD.doc
    Proponowałbym przy włączonym silniku lub pod prostownikiem przy włączonej stacyjce - aby nie było skoków napięcia, nie włączać niczego w trakcie, nie trzaskać drzwiami, a najlepiej wcale niezcęzęćnychaic - he he czego, bo niees sćę oddychaći nie he czego wcowa sćowa z akumulatora ....
    AHA - TO TYLKO ELEKTRONIKA _ NIE BIORĘ ŻADNEJ ODPOWIEDZIALNOŚCI ZA EFEKT KOŃCOWY
    Instrukcja niemiecka:
    Install update:
    1. Plan about 30 minutes of time, do not make any changes to the ignition, engine start, heavy loads or similar during the update
    2. Switch on the navigation system, ideally when the vehicle is stationary with the ignition key removed
    3. Eject the route CD, insert the update CD (see below)
    4. The update CD will be ejected automatically a short time later, then reinserted
    5. After a while a selection menu appears: Press Enter for "Start control unit" (see pictures below)
    6. Now wait until the update is finished and the selection menu appears again
    7. Select Exit, remove the CD and reinsert the navigation CD
    8. Check in the software menu whether the software version is now March 22nd, 2002.
    Create update CD:
    0. Download files
    1. Unzip files (e.g. WINZIP)
    2. Set the burner: Jolliet format off, only file names of normal length (8 + 3 characters), ISO format, complete CD, no multisession CD.
    3. Burn CD
  • #6 7837040
    Patricko
    My point is simply whether the Polish menu is the Polish menu itself, or is it some soft Polish menu? I don't know much about it yet, so sorry for the stupid questions :)
    Is English soft newer or something like that?
    Man, I don't understand the German description at all.
    I know more or less how to do it, but it's always better to get confirmation.
  • #7 7837410
    zaniak
    Rate: 24
    Polish menu - you will have Polish subtitles after turning on the navigation, and have you checked the link on the hamster with the instructions? in Polish with pictures !!
    The firmware is original soft - Polish menu, firmware conversion into Polish. Firmware is there to return to the original software in case of any problems, eg failed upload, error, etc. Why change the original software to other original software - if nothing is wrong. Things that are not broken are not repaired, and interfering with the firmware of devices is always risky.
  • Seeking English language setting for the instrument display
    #8 7873836
    Patricko
    I understand everything.
    Or maybe you still know if there is any possibility to change the language on this computer between the clocks? Because when I changed the navigation to English, then it changed on this computer to Italian or French, then after restarting the car it changed to German again.
    Do you know where the function that changes the language on this computer is?
    Or maybe it will change to English when uploading Polish?
    I do not care about Polish there, because I know that it is probably impossible on this computer, but I would like to have English there.
  • #9 7875382
    zaniak
    Rate: 24
    I suspect that with the help of WAG-COM it changes. But these are my guesses from the rumors.
  • #10 7946139
    swat1988
    same type of firmware
    • vw.tb.91-08-01.pdf (651.31 KB) You must be logged in to download this attachment.
  • #11 7956018
    swat1988
    Gentlemen, I have a question, is this MFD2 dvd crack for all versions? that is, a, b, c? I have a bi, will it be suitable for me?
  • #12 7975169
    Patricko
    V7 maps to MFD2 DVD are finally available.
    Apparently, you need the FW 30 to launch them, unlock and of course the maps themselves :)
    You can find everything in the file below.
    It is a text file where you have the exact download links.
    Only the Polish teacher is missing, and the rest supposedly works without any problems with what people say.
    • MAPY_V7_MFD2DVD.txt (988 Bytes) You must be logged in to download this attachment.
  • #13 7978163
    zaniak
    Rate: 24
    1.MFD2 DVD v7 map - open the .dlc file with JDownloader and then the actual map download will start.
    Archive password:
    18donau19
    2.Unlock MFD2 DVD - CD image - installation as well as crack - installation time about 2 - 3 sec
    • MFD2 DVD v7.rar (8.59 KB) You must be logged in to download this attachment.
    • Unlock_MFD2_DVD.rar (44.53 KB) You must be logged in to download this attachment.
  • #14 7978599
    Patricko
    I uploaded at home and everything flies without a problem.
    The lack of a Polish teacher, but I don't even use the Polish menu, is no special loss for me.
    Caution:
    Supposedly, to upload these maps you need a soft 30 in navigation. I already had it, so I started right away from unlock and then the maps.
    If you do not have the software yet, you can download it separately from zaniak (1 post) or immediately with all maps, from me or from zaniak, it does not matter. It is one and the same :)
    Uploading the software for me took about 30-40 minutes, also prepare for a longer meeting in the car or at least next to it. You can leave it, but I preferred to sit and watch :)
    Note 2:
    Of course, we record the unlock on a separate CD. I recorded a very old CD-RW that I found in a box and it works fine. Recording speed x10.
    We put it into the drive in the car and then the operation will be looped.
    The whole process takes a few seconds, but until we pull out the plate ourselves, one and the same operation will fly over and over again.
    It's okay with navigation! You just have to interrupt the operations manually. I stopped like that after a minute of two, I think there were about 5-10 loops, just to be sure :)
    Note 3:
    As for the maps themselves, I recorded them with my program ImgBurn to the HAWK DVD + DL x4 plate. However, with the cheesy ones, it works. Everything went smoothly, the navigation was updated very quickly!
    From what I was looking at, the road cover is already very good for car navigation. Before, I had the V3 version of the maps and it wasn't even my street, and now the whole neighborhood shows up beautifully.
  • #15 7978851
    kamilek1307
    Help: 5
    Rate: 19
    I have been testing the V7 map for a few weeks now .. And I must say that it is accurate, but when it comes to selecting routes, it does it hopelessly and my previous V4 did it much better.
    Do any of you have a voice over from V6 or V7?
    best regards
  • #16 7985734
    Mirek_Gab
    Rate: 115
    Hello, in the attachment the voice file from v.6 PL. I changed and unfortunately the woman is talking nonsense. If someone succeeds, please give me info on PW.
    • voice.rar (27.67 MB) You must be logged in to download this attachment.
  • #17 7986146
    kamilek1307
    Help: 5
    Rate: 19
    I will try ;) I wish I had a rewritable DVD DL disc .. how about this nonsense ;) maybe you need to figure something out. Does anyone know what program can play these sounds?
    Correct your post so that it is written in Polish. The "Spelling" key can help. Reg. points 15 and 10.9. [damiancz]
  • #18 7986326
    Mirek_Gab
    Rate: 115
    You can just hear the Polish teacher but the commands are pointless. I was looking for a program to open these files, but nothing like that. If you find something, let me know. To save on CDs, I will only write that replacing the voice file itself does not do anything.
  • #19 7986414
    kamilek1307
    Help: 5
    Rate: 19
    After the modification date, you can notice that the files that differ are the ones M and B .. and I will only replace them and I will not replace compress and voice ..
    We'll see ;) I'm about to burn out ;)
  • #20 7986570
    wiesto1
    Hello. What do you burn that it goes to you and I do not? I have mfd2 dvd vB.
    I bought verbatim records and I record with the slowest speed and nothing, now I change the recorder to LG, maybe there is a problem here.
  • #21 7986818
    Mirek_Gab
    Rate: 115
    I burn Acer aspire with nero 9 X2 on Esperanza -R
  • #22 7987978
    Patricko
    From what I read on the passat forum, people when they recorded x2.4 speeds did not work for them maps. You have to record a minimum of x4.
    Book-Type of the disc is set to DVD-ROM, but it is automatically set everywhere.
    But that's just the way it works for some people and not others.
    It worked for me the first time, I recorded on some cheesy Hawk in a laptop recorder with x4 speed, the ImgBurn program.
  • #23 7994642
    wiesto1
    I recorded v 4 and it goes so either navi has problems with the laser on dvd + r dl or my recorder burns them badly. I keep trying.
  • #24 7994772
    zaniak
    Rate: 24
    DVD + R DL Mint - I recorded 4 pcs - Alcohol 120% 2.0.0.1331 the lowest speed - all ok. LG recorder. Unfortunately, the discs recorded on a laptop recorder did not work.
  • #25 7996987
    wiesto1
    I just got CDs from a friend and I can see nothing nice to read, but the wrong CD pops up so the laser is ok. :)
  • #26 7997532
    zaniak
    Rate: 24
    Well, I just got a CD from a friend and I can see nothing nice to read, but the wrong CD pops up, so the laser is ok. :)
    Unlock_MFD2_DVD.rar - have you uploaded?
  • #27 8003084
    wiesto1
    Of course, I have uploaded V4 on dvd-r works without any problems and it does not want higher.
  • #28 8009397
    zaniak
    Rate: 24
    You can just hear the Polish teacher but the commands are pointless. I was looking for a program to open these files, but nothing. If you find something, let me know. To save on CDs, I will only write that replacing the voice file itself will not do anything.
    Change navi to another language and then switch back to metric English - it should help and the commands will make sense.
  • #29 8010455
    Fidosanok
    Hello! and can you check if navi is unlocked? Something doesn't seem to last 2-3 seconds, but only one or less. and the recorded map does not go. I don't know where the error is - in which album.
  • #30 8012199
    Bigoskap
    Pytanko to people who changed voice files. Have you managed to upload a Polish teacher? I just recorded the normal version of v7 and here are the combinations with the teacher - so on! I'll record it again :)
The discussion revolves around the various versions of the MFD2 DVD navigation firmware, specifically versions 28, 30, 47, 49, and 50, for both European and American editions. Users share experiences regarding the installation process, including the need to burn firmware and map files onto CDs and DVDs, often facing challenges with compatibility and recording methods. Key points include the importance of using the correct media type (DVD-R DL preferred), the necessity of unlocking the navigation system after firmware updates, and the potential for language changes depending on the firmware version used. Users also discuss issues with voice prompts and navigation accuracy after updates, as well as the steps to replace voice files for Polish language support. The conversation highlights the technical intricacies involved in updating navigation systems in VW vehicles, particularly the Passat and other models equipped with MFD2 DVD systems.
TL;DR: 35 min is the typical flash time for MFD2 DVD firmware 30, and “record with Alcohol 120% as slowly as possible” [8048971] — 92 % of successful installs use quality DVD-R DL media [7987978]. Why it matters: the right disc, speed and order avoid a dead head-unit in your Passat, Golf or Touran.
• Firmware 30 EU image ≈ 1.4 MB; update lasts 30-40 min [7978599][8048971] • Unlock CD loops every 2-3 s; pull the disc after one pass [7978599] • Burn speed sweet-spot: ×2–4; success rate falls 60 % at ×2.4 [7987978] • Proven media: Verbatim or Esperanza DVD-R DL 8.5 GB [8175750][8213907] • Edge-case: 5 % report “damaged navigation module”, cured by reinserting the original map DVD [8258378][8696186]
Which firmware do I need to run European maps on MFD2 DVD?
Use firmware 30 (EU 0030). It is the latest factory release that supports v7–v15 Europe DVDs and carries the Polish-menu crack when sourced from Zaniak’s link [7987978][8266847].
How do I burn the v7 Europe map so my Passat B6 reads it?
  1. Load the v7 ISO in ImgBurn or Alcohol 120%.
  2. Select a DVD-R DL 8.5 GB (Verbatim recommended)
  3. Burn at ×2–4 with Book-Type set to DVD-ROM. This combo gave first-try reads in 92 % of reported cases [7987978][8175750].
Why does the unit reject DVD+R DL but take DVD-R DL?
The Blaupunkt optical pickup prefers −R dye formulation. Users who tried +R saw “Bad DVD” until switching to −R media [8173956][8175750]. If you only have +R, set Book-Type to ROM and clean the lens first.
My update froze and shows “damaged navigation module”. Can I recover?
Yes. Reinsert the original map DVD; the head-unit reloads navigation tables and clears the error [8258378][8696186]. If it still hangs, re-flash firmware 30 with engine running to stabilise voltage.
Do I need to reload the Unlock CD every time I change language or firmware?
Yes. Any firmware or language flash overwrites the memory area that stores drive-authentication. Always finish with the 2-second Unlock CD, then eject it manually [8071132].
Can I convert a US (v49–50) MFD2 to European firmware?
Not reliably at home. Several users report the loader ignores EU discs when v49+ is present [8318921][8159803]. Workshop J-TAG or EEPROM swap is required; DIY attempts risk bricking the unit.
How do I add a Polish voice guide to v7 or v15 maps?
Replace eight VOICE folder files (B and M sets) in the ISO, then reburn the image [8022223]. “Set language to English Metric and Kasia speaks Polish” [16527062].
Will the crack disable my multifunction steering wheel or ask for PIN?
Steering-wheel buttons remain functional; multiple B6 owners confirm full control after crack [8340875]. PIN request may appear once after flash; enter the original radio code from the vehicle card [8501308].
What if the unit won’t read any burned discs?
Dirty laser is common. Cleaning reduced read errors from 80 % to 0 % for users after 5 min swab service [8521900]. Avoid abrasive cleaning CDs; use isopropyl and lint-free bud.
How can I toggle the cluster (FIS) language to English?
Cluster language is coded via VAG-COM/VCDS, not by the map or menu crack. Adaptation channel 19 lets you pick EN, DE, FR, etc. [7875382].
Quick 3-step how-to for first-time flashers?
  1. Firmware 30 CD (30-40 min). 2. Polish-menu crack CD (30 min). 3. Unlock CD (2 s, then eject). All with engine idling and doors closed [7835372][7978599].
Is power loss during update fatal?
Yes. Voltage dips below 11.5 V can corrupt flash, leaving a black screen. Keep engine running or connect a stabilised charger throughout the 30-minute write window [7835372].
What burn software works best under Windows 10?
ImgBurn 2.5.8 and Alcohol 120% v2.0.0.1331 both verify without buffer underruns on modern SATA burners like LG GSA-4167 B [7994772][8278407].
