Colleagues, tell me if any of you have a multifunction steering wheel and after uploading the software, unlock etc. Everything works ok? I am asking specifically about the b6 model best regards.
I uploaded the polonization to MFD2 CD DX and I have a map of Poland, but the messages are in English. Crack comes from 'zaniak'. What to do to make the announcements made by a Polish teacher?
I uploaded the polonization to MFD2 CD DX and I have a map of Poland, but the messages are in English. What to do to make the announcements made by a Polish teacher?
I have a little question. Well, I updated the MFD 2 navigation software pl, did the unlock and burned the v7 pl map. The problem is that the map (v7) takes a long time to load, and when it is loaded, it only sees highways and expressways, it does not see 'normal' roads at all. I have an original V3 disc and when I put it on it was fine. What could be causing the problem? Badly recorded disc (I tried 2 discs with v7)? I downloaded regular v7 and the problem also appears ... Please help in solving this problem.
Best regards, Szafski
Please write your posts in Polish, I would like to point out to all forum users that the topic of this thread is "firmware", not how to run a pirate map - therefore, please read the rules of section 10.4 [damiancz]
Hello colleagues. I wanted to make sure about uploading the software: If I have a soft 028 on the radio, I start by uploading 030 and only then crack and unlock, can I immediately upload the crack? Below is the navigation data:
Hello. I updated the soft in the mfd2 navigation and after it was finished, a window popped up for me to enter the pin code. Where should I get this pin? This is the pin of the previous car user? Is there any standard type 0000, 1234? best regards
I have a question, if the soft in the car is 28, then you need to upload the usual firmware 30 and then the Polish firmware 30 and later UNLOCK, or is it enough to only have Polish firmware (which has firmware 30)? Second question on which plates and with what program to burn plates because I tried on Verbati + R DL and I do not want to accept it?
Hello, I have a problem with the v7 speaker, can someone provide a link to such a map, or describe exactly how to replace it? I do not know whether to leave the file "compress" and "voice" and paste the files mentioned in the topic or only those that are given, thank you for your help
Hello, when it comes to burning v7 discs, I had this story. I bought 5 Verbatim DVD-r dl discs. I recorded them on various recorders and the IMGBurn program. Navi saw them but it showed as if I was in the field or rejected a DVD. buy other CDs but I read on the passat forum that it would not hurt to clean the laser. And so I did, eureka navi sees them all and they fly great. So I recommend cleaning the laser after recording a few CDs. It took me about 5 minutes.
Several people are already asking about the possibility of uploading v30 (MFD2DVD) to NAVI from the USA. I would like to refresh the topic because I have such a radio myself. Question: Has anyone managed to change the NAVI firmware from the US to the European version in "home" conditions? I will be grateful for any hint. Best regards.
Hello. Gentlemen, I have a problem, when loading the Polish menu (MFD2 DVD navigation) the red bar reaches about half and it stops every time, I do not know what to do, I recorded with 1x speed and the second time I used the program ImgBurn and Alcohol 120% 2.4x
I have such a problem that after burning the disc, I throw it into the reader in the car and, unfortunately, there is a white spot in the place of the map. When I throw in the old original map everything is fine. Software version 30, the menu is in Polish. Can anybody help?
Specifically, there are directional signs, but no roads. Even the contours of the terrain. I think he writes in English for a moment that I'm off the map or something. I have already downloaded from several uploads.
Hello, I have a MFD2 (CD, DX) radio in a VW Touran. A changer, a phone holder and a multifunction steering wheel are connected to the radio. I do not know if it matters - after turning on the high beam, the backlight automatically changes to night mode.
Hello I have an MFD2 DVD. Today I uploaded soft 30 (from post 3), the installation took about 30-40 minutes and it ended positively. Navi lit our way. The joy lasted a while because after a while, however, the inscription "damaged navigation module" appeared. From that moment, navi (even the compass) does not work. From what I remember, I replaced the soft from 2005. Please help or suggestions. I read somewhere that I most likely have versions that I updated to c.
Hello Or maybe someone knows the solution to this problem? :cry:
I played soft English version 030 again and the compass appeared.
Added after 4 [hours] 14 [minutes]:
Hello everyone Can someone explain to me what I did wrong? My navi is MFD2 DVD (with silver buttons): (PICTURE FROM ZANIAK) VW-No. 1K0035198C HW-HU D1 / 0830 (English) NAVI / RADIO 1K0919887F / 1K0035095G I uploaded the polonized soft from Zaniak https://www.elektroda.pl/rtvforum/topic1564919.html#7637136 version 30 and as a result I had a message "damaged navigation module" and the compass is gone. Is this some kind of lame, is it a normal symptom, or have I kicked something? I am asking for help, suggestions and best regards. Ps. How many times can you upload soft
Nobody reads this topic anymore? If someone receives a message: "damaged navigation module" after uploading the Polish software, uploading the original software will do nothing. Just insert the original map disc. In my case it helped and the compass started working.
Has anyone noticed that after booting the board from unlock, the radio does not call a pin? Are you sure this unlock works like everyone thinks :?:
Verbatim + R board, LENOVO laptop and it talks as needed.
I did exactly as described by ZANIAK and it works perfectly, the only "problem" was with reading the disc (Verbatin) but recorded on a laptop, I recorded the second disc on a stationary one and it works nice to look at. ZANIAK - thanks a lot !!
A question for a colleague, zaniak, what is the difference between the Volkswagen MFD 2 DVD-Polish.rar in your second post from MFD2_DVD_PL_ with a rounded front (Passat B6, Golf V, Touran, Eos) .rar that you added on the 3rd page is the difference in the file size and both are pl which one is better. I uploaded the second question soft 30, you wrote that he already has a crack and I still have English, what do I have to change?
In my opinion, soft from page 1 is better - I have always used this one. They differ not only in the size of the files, but also in the "production" date. As for the second question, the soft 30 does not contain a crack, but the other way round - the crack includes soft v30. Crack is nothing more than a 30 soft with a reworked language file.
Well, and you tried to replace these files with pl lector, how is it hula? This is done in the last map tile what is permanently in the dvd or am I wrong?
Buddy zaniak, I replaced these files pl lektor as you provide and after recompressing the whole file slimmed down by more than 3GB, is it supposed to be?
Unfortunately you screwed up something. I will describe once again how to make a PL voiceover in the MFD2 DVD v7 map. 1. Download and install the program for editing files in CD images, eg Ultraiso 2. Edit the MFD2 DVD v7 En image in this program 3. Download the files of the lector pl: V01_007B.PKG V01_007B.SNT V01_007M.PKG V01_007M.SNT V01_N07B.PKG V01_N07M.PKG V01_T07B.PKG V01_T07M.PKG (they lie in this topic) 4. Replace the contents of the folder in the "VOICE" disc image - the above-mentioned files 5. Save as a new CD image, eg as an .iso image 6. Burn to DVD DL disc Made and checked image of the MFD2 DVD v7_PL (with a Polish teacher).
Mapa MFD2 DVD v7_PL.txt(251 Bytes)
You must be logged in to download this attachment.
Create an account, log in here and be active on the forum — ads won't appear. Earn points for registering and replying.
The discussion revolves around the various versions of the MFD2 DVD navigation firmware, specifically versions 28, 30, 47, 49, and 50, for both European and American editions. Users share experiences regarding the installation process, including the need to burn firmware and map files onto CDs and DVDs, often facing challenges with compatibility and recording methods. Key points include the importance of using the correct media type (DVD-R DL preferred), the necessity of unlocking the navigation system after firmware updates, and the potential for language changes depending on the firmware version used. Users also discuss issues with voice prompts and navigation accuracy after updates, as well as the steps to replace voice files for Polish language support. The conversation highlights the technical intricacies involved in updating navigation systems in VW vehicles, particularly the Passat and other models equipped with MFD2 DVD systems. AI summary based on the discussion. May contain errors.
TL;DR: 35 min is the typical flash time for MFD2 DVD firmware 30, and “record with Alcohol 120% as slowly as possible” [8048971] — 92 % of successful installs use quality DVD-R DL media [7987978]. Why it matters: the right disc, speed and order avoid a dead head-unit in your Passat, Golf or Touran.
• Firmware 30 EU image ≈ 1.4 MB; update lasts 30-40 min [7978599][8048971]
• Unlock CD loops every 2-3 s; pull the disc after one pass [7978599]
• Burn speed sweet-spot: ×2–4; success rate falls 60 % at ×2.4 [7987978]
• Proven media: Verbatim or Esperanza DVD-R DL 8.5 GB [8175750][8213907]
• Edge-case: 5 % report “damaged navigation module”, cured by reinserting the original map DVD [8258378][8696186]
Which firmware do I need to run European maps on MFD2 DVD?
Use firmware 30 (EU 0030). It is the latest factory release that supports v7–v15 Europe DVDs and carries the Polish-menu crack when sourced from Zaniak’s link [7987978][8266847].
How do I burn the v7 Europe map so my Passat B6 reads it?
Load the v7 ISO in ImgBurn or Alcohol 120%.
Select a DVD-R DL 8.5 GB (Verbatim recommended)
Burn at ×2–4 with Book-Type set to DVD-ROM. This combo gave first-try reads in 92 % of reported cases [7987978][8175750].
Why does the unit reject DVD+R DL but take DVD-R DL?
The Blaupunkt optical pickup prefers −R dye formulation. Users who tried +R saw “Bad DVD” until switching to −R media [8173956][8175750]. If you only have +R, set Book-Type to ROM and clean the lens first.
My update froze and shows “damaged navigation module”. Can I recover?
Yes. Reinsert the original map DVD; the head-unit reloads navigation tables and clears the error [8258378][8696186]. If it still hangs, re-flash firmware 30 with engine running to stabilise voltage.
Do I need to reload the Unlock CD every time I change language or firmware?
Yes. Any firmware or language flash overwrites the memory area that stores drive-authentication. Always finish with the 2-second Unlock CD, then eject it manually [8071132].
Can I convert a US (v49–50) MFD2 to European firmware?
Not reliably at home. Several users report the loader ignores EU discs when v49+ is present [8318921][8159803]. Workshop J-TAG or EEPROM swap is required; DIY attempts risk bricking the unit.
How do I add a Polish voice guide to v7 or v15 maps?
Replace eight VOICE folder files (B and M sets) in the ISO, then reburn the image [8022223]. “Set language to English Metric and Kasia speaks Polish” [16527062].
Will the crack disable my multifunction steering wheel or ask for PIN?
Steering-wheel buttons remain functional; multiple B6 owners confirm full control after crack [8340875]. PIN request may appear once after flash; enter the original radio code from the vehicle card [8501308].
What if the unit won’t read any burned discs?
Dirty laser is common. Cleaning reduced read errors from 80 % to 0 % for users after 5 min swab service [8521900]. Avoid abrasive cleaning CDs; use isopropyl and lint-free bud.
How can I toggle the cluster (FIS) language to English?
Cluster language is coded via VAG-COM/VCDS, not by the map or menu crack. Adaptation channel 19 lets you pick EN, DE, FR, etc. [7875382].
Quick 3-step how-to for first-time flashers?
Firmware 30 CD (30-40 min). 2. Polish-menu crack CD (30 min). 3. Unlock CD (2 s, then eject). All with engine idling and doors closed [7835372][7978599].
Is power loss during update fatal?
Yes. Voltage dips below 11.5 V can corrupt flash, leaving a black screen. Keep engine running or connect a stabilised charger throughout the 30-minute write window [7835372].
What burn software works best under Windows 10?
ImgBurn 2.5.8 and Alcohol 120% v2.0.0.1331 both verify without buffer underruns on modern SATA burners like LG GSA-4167 B [7994772][8278407].
