Mechanical Unlocking of Locked Passat B5 99r Estate Rear Left Door: Procedures?
waniuszka 123703 10
How can I mechanically unlock a stuck rear left Passat B5 door lock from inside when the actuator no longer responds?
Fold back the plastic motor cover, access the actuator, and turn the motor/gear by hand with thin tools until the lock releases; this may require sacrificing the lock and small parts can fall out [#7776818][#7780475] A better method is to apply 12 V directly to the motor after folding back that cover, which can open the lock without sending it to scrap if the motor is still healthy [#16404427] Another practical approach is to identify the two wires going to the lock motor, cut them so the comfort module is not damaged, and feed 12 V from an external power supply directly to the lock [#17033003] If the door can still be actuated electrically, one user also suggested holding the inner handle open, locking the car with the remote, then unlocking it and releasing the handle so the pin stays up and the door can be opened [#7772509]
  • #1 7766547
    waniuszka
    Rate: 34
    One day in my Passat B5 99r estate (central with a key), after closing all the doors, the rear left door stopped responding. The door is locked and there is no way to open it from outside or inside.
    I read on the forum how to get to the door from the inside. I have already removed the upholstery and the sheet metal. Now I have access to the lock, but I don't know how to unlock it mechanically. I am writing mechanically because the lock does not react to electrics. I connected to the black-blue and black-green 12V (the wires going to the lock actuator) - no reaction. My diagnosis is the lock broken. I can replace it only after opening the door.
    But how to open them?
    Is there any way to undermine something to let the lock release?
    Please help... :cry:
  • #2 7766714
    yogi009
    Help: 848
    Rate: 2654
    And is the actuator lever visible there?
  • #3 7767270
    waniuszka
    Rate: 34
    This is more or less what it looks like.
    on another forum I found another better photo of the lock, in which you can see the individual parts better
  • #4 7767302
    carrier
    Car alarms specialist
    Help: 511
    Rate: 1054
    in general, it is not that simple, it would be best to disassemble the actuator, but the problem is that it is screwed on from the other side.
    As for the damage to the actuator itself, check the cables from the comfort module under the driver's rug, they often rot at a distance of about 40-50 cm from the module, also take the controller out on the table and see how it feels inside, it's best if you have a vag to help
  • #5 7767404
    waniuszka
    Rate: 34
    The actuator is energized and receiving pulses. I checked with a meter in black, green and blue - there is a current when opening or closing.
    In my opinion, it's a mechanical failure.
    How to release the mechanism or actuator?
  • #6 7772509
    spil
    Rate: 14
    try this way
    1.you close the door with the remote control
    2.you hold the inner handle in the open position (so that the pin comes up)
    3. you open the door with the remote control
    4. you let go of the handle (inside) and the pin should stay up and the door can be opened from inside and outside.
  • #7 7776818
    invector
    Help: 24
    Rate: 103
    It can be unlocked but at the cost of the lock. Unscrew the plastic cover that covers the motor. It will not come off completely, you will have to fold it back, then you will have access to it. Start turning it by hand, or rather with thin tools (I don't remember which way) until the lock releases. The problem is that when turning the motor, it bounces and you have to hold it skillfully. Of course, some small elements fall out of your interior, so it would be a good idea to get a second lock and replace it in one go.
  • #8 7780475
    mortalbird
    Help: 11
    Rate: 131
    Hello, it is exactly as described by the invector, there is no other way I had the same problem you disassemble the door you get to the actuator you unscrew it slightly bend it and turn the wheel to the left (I think) while the central lock is already scrapped, you will close and open only from the bolt.
    if you need such a lock, I have something like it, let me know it promptly
  • #9 7797437
    waniuszka
    Rate: 34
    I did as you advised. the old castle went into the basket. I bought a new one on the Allegro for PLN 85. two days and I have everything put together. everything is back to normal.
    thanks for the help
  • #10 16404427
    getekgregor
    A better method is to fold back the plastic motor cover and apply 12V directly to it. For me, this way saved the castle, nothing spilled out of it and it did not go to scrap. Just after this operation, it opened and, after a light inspection, it started working properly.
  • #11 17033003
    mrucze
    Help: 34
    Rate: 85
    Hello. I make these locks quite often Golf Passats, etc. The biggest inconvenience is the need to remove the upholstery with the door closed, but it can be done without leaving any traces of damage. Then I take a bunch of cables going on the sheet to the lock and look for a pair that goes to the motor. I cut these cables so as not to damage the electronics of the comfort module and I put 12V on the lock from the external power supply. Of course, this method will not work if the motor is damaged But so far I have opened many cars and I have not had such a case
The discussion revolves around the mechanical unlocking of a locked rear left door on a 1999 Volkswagen Passat B5 estate. The user reports that the door is unresponsive to both manual and electrical unlocking methods, leading to the diagnosis of a potential mechanical failure of the lock. Various solutions are proposed, including checking the actuator lever visibility, inspecting wiring for damage, and directly manipulating the lock mechanism. One suggested method involves removing the plastic cover of the motor and manually turning it to release the lock. Another approach is to apply 12V directly to the lock motor to unlock it without damaging the actuator. Ultimately, the user successfully replaced the lock after following the advice provided in the forum.
