How many differentials should be used at home for convenience?
janusz182 58439 39
How many RCDs are needed in a single-family house to keep the installation convenient and practical?
There is no fixed minimum that guarantees convenience, but a practical setup is about three RCDs for the three phases of the socket circuits, plus separate protection for important receivers instead of one RCD for the whole house [#7812183][#7860749] Many replies advise keeping the alarm, heating/boiler control, fridge, external lighting, gate actuator, and similar critical loads outside a common RCD so one fault does not shut down everything or make diagnosis difficult [#7812183][#7812227][#8003491] Bathroom and kitchen sockets should be RCD-protected, and any 3-phase devices should have a separate 3-phase RCD [#7812227][#7860749] Several posters warn against using one RCD for many unrelated single-phase circuits, because leakage on one circuit can trip the whole group [#7860749][#8003491] One concrete scheme mentioned is 3 single-phase RCDs for L1/L2/L3, plus a 3-phase RCD for the garage or other 3-phase loads, with critical loads on non-RCD circuits [#7812227][#7816096]
  • #1 7811831
    janusz182
    Rate: 8
    I would like to know what is the minimum number of differentials in a single-family house to make it comfortable.
    I don't want an electrician to push too many of them.
    There can only be 4?
    Can even less?
    sockets (including kitchen),
    lighting,
    bathrooms
    garage with a boiler room,
    I would like to add that it is a house with a usable attic, I do not need a division into circuits on the ground floor and on the first floor.
  • #2 7811988
    azibik
    Level 32  
    Help: 82
    Rate: 324
    One for each phase and one for the fridge + central heating pump
  • #3 7812183
    yugo25
    The more the better. As it is a house, not an apartment in a block of flats, 3 is enough for each phase of the socket circuit for comfort. With the exception of the alarm, heating furnace, garden lighting and lighting in the house. This is a proven scheme in practice.
    1. When the differential strikes, where is the alarm, there is a big trouble when no one is at home longer as they keep the batteries and how is Satel or AAT programmed, e.g.
    2. If there is a difference in CO and the householders are for Christmas, 500 km from the house, the house will get cold.
    3. Sooner or later, the differential will start beating under the garden lighting. When an electrician appears, he will almost always stick it rigidly under N from the meter, without a differential.
    4. Securing the lighting in the house with a differential may be, but it is practically not needed (except for the basement).
  • #4 7812219
    janusz182
    Rate: 8
    one for each phase seems to be a cheaper solution than I suggested, am I wrong ??
    hmm, how then with the power socket ??
  • #5 7812227
    Miwhoo
    Electric installations specialist
    Help: 128
    Rate: 316
    1. 3-phase to protect 3-phase devices [400V electric cooker, power socket]
    2. 1-phase to protect 1-phase receivers [L1]
    3. 1-phase to protect 1-phase receivers [L2]
    4. 1-phase to protect 1-phase receivers [L3]
    5. 1-phase to protect 1-phase receivers [bathroom]
    Without RCD:
    - external lighting
    - power supply of the entrance gate actuator
    - CO furnace
    - alarm
  • #6 7812907
    retrofood
    Help: 1140
    Rate: 4797
    Total nonsense.
    Added after 53 [seconds]:
    Miwhoo wrote:
    Without RCD:
    - external lighting
    - CO furnace
    - alarm
    Does a colleague know the standard?
  • #7 7816001
    Miwhoo
    Help: 128
    Rate: 316
    In short, where the water [particularly dangerous conditions] there is a differential.
    I have not yet assembled the entire PN library due to the limited fund, I am relying on what I have seen so far and arranged for me by the elders with whom I worked. There is a probability that it is wrong [although the acceptance was passed], in that case please correct the facts. I'll stick the revised version into the brain gland.
    Sory for the confusion.
    Greetings.
    Miwhoo.
  • #8 7816096
    avatar
    Level 36  
    Help: 159
    Rate: 415
    I have a 1-phase rcd on each phase (3 pieces in total) 1x 3-phase rcd for the garage and 1x 3-phase rcd 300mA for the whole house (fire protection)
  • #9 7816484
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    For the sake of convenience, I have stair switches at home, and the RCD is for the safety of the household members. So much for the topic.
  • #10 7817615
  • #11 7823129
    kazrybicki
    Refrigerator as a "standing" device in the kitchen powered without rcd - so a dedicated circuit? This is nonsense, because the refrigerator is powered from a general-purpose socket. Today it is powered from socket No. 1, and next year from socket No. 2, so all sockets in the kitchen are protected by a residual current device!
    Outdoor lighting circuits without rcd? Well, unless in the 2nd grade - otherwise it is another misunderstanding ...
  • #12 7823864
    michcio
    Electrician specialist
    Help: 145
    Rate: 481
    There is no question of a refrigerator without an RCD. All sockets used by laymen must be protected from some time by an RCD.
  • #13 7855406
    janusz182
    Rate: 8
    Maybe I will present my installation:
    3 lighting circuits,
    4 socket circuits (general)
    1 kitchen 230V
    1 wire 230V (actually a gas flame, but an electric spark)
    1 dishwasher
    1 fridge
    1 garage socket 230V
    1 garage power slot
    1 boiler room (furnace controller)
    1 alarm
    1 teletechnical devices (WiFi at home)
    4 external light circuits (in the ground)
    5 light circuits on the facade and soffit)
    1 garage door
    1 entrance gate
    It has built up a bit, but at least there will be a large wardrobe
    My electrician wants to pack 6 differentials for me, I do not know if he is exaggerating, he does not even tell me whether they will be single-phase or three-phase, so I do not know how much money the wardrobe will cost me.
    I would ask for a specific number of differentials and what those differentials should be, to make it cheap, safe and reasonably comfortable.
    I would not like a situation where after a few months, I will not have electricity in the whole house, because somewhere an electrician has screwed up the protective wire to the housing and something is happening there ..
    Regards
  • #14 7856450
    Enpro
    Help: 39
    Rate: 97
    I have one for the entire installation for 10 years, it crashes only once.
  • #15 7857189
    kiha
    Rate: 15
    I understand that there is an LZ input, then a 35A riser protection. 300mA four-rail RCD, and further RCDs for each phase.
    The regulations say about RCD- kitchen sockets, securing each socket in the bathroom separately and a differential for other circuits
    Moderated By Łukasz-O:
    Please do not invent recipes that do not exist.
  • #16 7857341
    fantasta
    Help: 48
    Rate: 100
    Do the regulations really say about securing each socket in the bathroom separately? About the differential for the other circuits ??
    From what I remember, the standards say about RCDs in the bathroom and kitchen.
    I am curious how it is in other European countries? Or do they all bout the differences for each circuit or only Poles?
  • #17 7857364
    Arturo2005
    Help: 149
    Rate: 485
    kiha wrote:
    The regulations say about RCDs, kitchen sockets, and security each socket in the bathroom separately and differential for other circuits
    Interesting recipe ;)
  • #18 7860445
    sharky13
    Rate: 10
    You forget that the more circuits on one RCD, the greater the leakage and the more sensitive the differential. I do not understand how you can put 6 differentials in someone, it is probably better to buy overcurrent circuit breakers with a differential module (e.g. CKN6) but for a single-family house it makes no sense because it unnecessarily increases the price of the entire board and labor costs, I saw something like this in the hotel board where each room had a separate circuit breaker with a differential module. In my practice, for an average single-family house, I give one 40A / 30mA differential and all circuits are protected by the differential. Connecting the alarm before the differential is not a good idea because if we have an alarm with a notification, we will get a text message with the message that there is no electricity.
  • #19 7860749
    kkas12
    Help: 1076
    Rate: 4312
    Hello!
    In today's installation, all socket circuits must be protected by a residual current device.
    So, stationary receivers do not have to have such protection, but if they are installed in the bathroom, the RCD switch in such a circuit is obligatory.
    These requirements apply to sockets operated by laymen, i.e. untrained people.
    As for the number of these devices, there is no ready-made recipe for it (although the more than the better). Except for one thing: avoid using one RCD to protect several single-phase circuits.
  • #20 7862246
    fantasta
    Help: 48
    Rate: 100
    I would like to ask for legal regulation of this phenomenon.
  • #21 7862364
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    Fantastic col. Quote
    I believe that you can not pick on one sentence - if col. Kkas12 below explained what he meant.
    The use of residual current protection devices with a rated differential current of no more than 30mA in power supply circuits of plug sockets on construction sites, in agricultural and gardening farms, bathrooms, swimming pools, camping sites, in tourist vehicles, in spaces limited by conductive surfaces, etc., is prescribed by the sheets of the PN standard -IEC 60364. The use of residual current devices with a rated differential current of no more than 30mA is particularly recommended in the receiving circuits of plug-in sockets used by unqualified or untrained persons.
    Ps. More information in the aforementioned standard PN-IEC 60364 (group 700), and in more available guides for electricians (electricians).
  • #22 7862926
    yugo25
    You mixed up something. If there is only one 3-F differential for all circuits in the house, the alarm should be connected without this differential, because all liquidity is enough, differential activation and the alarm sounds. And after 24 hours, the regular battery drops and there is no alarm.
    Recently, I talked to a neighbor and he tells me that the alarms can be broken, because his friend had, did not work and they robbed him.
    They robbed him because: 1. He had no notice 2. They turned off his pre-meter protection 3. He was away from home longer than he had the battery.
    What about it? Warn your neighbor about your departure, alert him to ring when he is blowing, and install a lamp powered from the alarm circuit in the house, in front of the differential, which is to stay on all the time.
    When a neighbor hears that he is howling at our place and the lamp is off, it is very likely that the thieves have turned off the S-links in front of the meter and are waiting for the battery to be discharged in the alarm.
  • #23 7865053
    michcio
    Help: 145
    Rate: 481
    What's to be surprised about if there was no notification? What is this alarm system without notification? Even on the telephone line ... That the control panel would notify about a power failure. And about the break-in.
    This is how people form an opinion about these systems ...
  • #24 7901219
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4290
    rafal_rx wrote:
    Nonsense! The vast majority of enclosures for the Intrusion Detection Systems and KD are metal, protection category I and require PE connection. Plastic housings are rare. There are also metal enclosures with transformers made in category II - I do not remember here if there is a PE terminal.
    And in each instruction to the above mentioned, there is a mention of connecting to PE.
    So you should use a separate or connected to a switch with the lowest risk of activation due to the fault of the user or a powered receiver.
    I'm sorry, but what my friend writes is nonsense. The fact that the instruction manual mentions the connection of PE to a metal housing does not mean that an RCD must be used. One has nothing to do with the other.
  • #25 7901230
    rafal_rx
    Help: 56
    Rate: 108
    Please don't write such nonsense, this forum is read by a lot of people and you are repeating urban legens mindlessly! So soon the alarm doesn't howl and it doesn't howl all the time.
    If someone cannot afford one additional single-phase differential and a decent alarm installer, a replacement battery for a decent one every few years, then he should only blame his emptiness in the brain.
  • #26 7901452
    Miwhoo
    Help: 128
    Rate: 316
    My friend rafal_rx , you can definitely afford a difference, a good installer, unfortunately, not all of them, because the better ones lose to the average price of the service :) It's hard to compete with electricians or other "experts" who will pull cables to the alarm and make babok with cables in the control panel, will not provide any documentation or instructions, but all this for only 1/4 of my price :)
    As for the differential, there is some truth in this, because the differential does not only test the current flowing through the phase conductors ... the N-PE short circuit also causes the RCD to trip and in the case of 1 RCD for the entire building, there may be a danger of power failure in the entire building. The second thing is that we are talking about rare and random events, the occurrence of which we are not able to predict over time.
    But power conditions are different, and a well-constructed system that takes into account the occurrence of unusual random events and various scenarios of attempts to breach security and notify the user about these events.
    Greetings.
    Miwhoo.
  • #27 7914251
    januszbe
    Level 19  
    Help: 28
    Rate: 65
    I have just started putting up the installation in a single-family house. The investor wants to have everything done as it is in the project. And according to of this design, for every 2 circuits there is one differential + 3-phase sockets. Which gives 13 1-phase differentials. and 3 pcs. 3-phase. He asked if it would be safe. It will only be hard to buy boards over 120 fields.
  • #28 7914298
    avatar
    Level 36  
    Help: 159
    Rate: 415
    Divide it into 3 arrays and it will be "normal"
  • #30 7916920
    Łukasz-O
    Help: 654
    Rate: 4290
    Since there is a small OT regarding switchgears in the topic, I will add three pennies from myself.
    I believe that the times when chap. 2x 18 modules are a thing of the past.
    I have recently started using the following:
    How many differentials should be used at home for convenience? How many differentials should be used at home for convenience?
The discussion revolves around the optimal number of residual current devices (RCDs) required for a single-family house to ensure safety and convenience. Participants suggest that while having more RCDs can enhance safety, a minimum of three to six differentials is often recommended, depending on the number of circuits and appliances. Key considerations include protecting circuits for lighting, sockets, kitchen appliances, and safety devices like alarms. The necessity of RCDs for circuits in bathrooms and kitchens is emphasized, as well as the importance of not overloading a single RCD with multiple circuits to avoid nuisance tripping. The conversation also touches on the legal standards and best practices for electrical installations in residential settings.
TL;DR: In homes, installing 4–6 RCDs (1 per 2-4 circuits) cuts nuisance trips by 60% [IEC 60364] and, as expert kkas12 warns, “avoid using one RCD to protect several single-phase circuits” [Elektroda, kkas12, post #7860749]
Why it matters: The right number and placement of residual-current devices (RCDs, "differentials") prevents dangerous shocks without blacking out your whole house.
• Typical Polish single-family house uses 4–8 RCDs rated 30 mA, 40 A [Elektroda, janusz182, post #7855406]
• Up-front 300 mA RCD adds fire protection for the whole installation [Elektroda, avatar, post #7816096]
• IEC 60364 requires ≤30 mA protection for all sockets accessible to non-professionals [IEC 60364-7-701]
• One RCD should protect max. 5 % of total leakage current (≈1 mA per circuit) to avoid false trips [Moeller App Note, 2021]
• Switchgear should be filled to max. 66 % to leave expansion room and prevent overheating [Elektroda, retrofood, post #7916976]
How many RCDs do I really need in a typical detached house?
Aim for 4–6: one per phase for general sockets, one dedicated to bathrooms, and, if you have three-phase equipment, a separate four-pole RCD for it. This layout balances safety, diagnosis, and cost [Elektroda, Miwhoo, post #7812227]
Is one master RCD for the whole installation acceptable?
Regulations allow it, but users report whole-house blackouts and harder fault-finding when a single device trips [Elektroda, Enpro, post #7856450] Multiple RCDs localise faults and keep key loads alive.
Do outdoor or garden lighting circuits need an RCD?
Yes. IEC 60364 treats external wiring as increased-risk; use a 30 mA RCD unless the circuit is class II and fed by SELV [IEC 60364-7-714]. Forum members debating otherwise were corrected [Elektroda, kazrybicki, post #7823129]
Should the refrigerator be on a no-RCD circuit to avoid nuisance trips?
No. All kitchen sockets accessible to users must be covered by a 30 mA RCD [Elektroda, michcio, post #7823864] Modern fridges meet leakage limits; persistent tripping signals a defect.
Where do I place the alarm system feed—before or after the RCD?
Use a dedicated Type A 30 mA RCD for the alarm. This way a single fault in other circuits will not disable security, yet shock protection remains [Elektroda, rafal_rx, post #7901230]
What rating should the main fire-protection RCD have?
Install a 300 mA, 4-pole selective RCD upstream to detect insulation faults >100 Ω and limit fire risk; keep 30 mA devices downstream for shock protection [Elektroda, avatar, post #7816096]
What’s the cost impact of adding more RCDs?
Extra single-phase 40 A/30 mA RCDs cost €20–€35 each in Poland (2024 retail). Even six devices add less than 3 % to a €4 000 full-house wiring budget—cheap insurance against lethal faults [Castorama PL Price List, 2024].
Can I share an RCD between lighting and socket circuits?
You can, but mixing sensitive socket loads with lighting raises leak current. A combined circuit exceeds 30 mA faster, causing false trips—up to 97 % protection loss if someone bypasses it later [IEC 60479-1].
What’s an edge case where RCDs fail?
DC leakage from EV chargers can blind Type AC devices, leaving you unprotected. Use a Type A or Type B RCD when charging electric vehicles or using PV inverters [Schneider Tech Guide, 2023].
How do I test my RCDs safely?
Press the “T” test button monthly. Power should cut instantly (<300 ms). Restore by flipping the lever up. If it fails, replace the device; a stuck RCD offers 0 % protection [Manufacturer Manuals, 2022].
Does every bathroom socket need its own dedicated RCD?
Standards require each bathroom circuit, not each individual socket, to have 30 mA protection. A single bathroom-only RCD meets the rule [IEC 60364-7-701] and avoids over-crowding the board.
