Why Do Diesel Engines Use Air Flow Meters and Throttles If Fuel Amount Is Controlled?
rolnik41 65490 42
Why do diesel engines use an air flow meter and a throttle if fuel quantity is controlled directly?
Diesel engines still need to measure intake air because the amount of air is not constant; it changes with engine speed, load, turbo boost, temperature, altitude, and engine condition, so the ECU must know the air mass to set the correct fuel dose [#8121197][#8120988] In turbo diesels, the ECU often uses a MAF together with pressure and temperature information to calculate the fresh-air mass more accurately, while the manifold pressure sensor is mainly used to control boost [#8120988][#8121197] The flow meter is also used to determine how much exhaust gas is being recirculated through EGR, i.e. to compare fresh air versus recirculated exhaust [#8251771][#8252131] The diesel throttle is therefore not mainly for normal power control, but to help draw in EGR and, in some cases, to smooth engine shutdown and reduce vibrations [#8121197][#8251771]
  • #1 8120610
    rolnik41
    Rate: 29
    In cars with a compression-ignition engine, we control the amount of fuel, not the fuel-air mixture, as it is in "gasoline vehicles". The amount of air drawn in is constant. I wonder why a flow meter is installed in diesels. Since the amount of air is constant, why measure it? Is it related to the turbocharging commonly used in this type of engine? The same is with the throttle. Since we control the dose, why the possibility of air control? Heard it has to do with ERG.
  • #2 8120668
    ociz
    Help: 1379
    Rate: 3488
    And why such a stupid idea that the amount of air is constant? Even in naturally aspirated engines, this changes along with the changing condition of the engine, or someone tries to fix something in the exhaust and immediately the wave effect ... shoots.
    amm212
    Help: 19
    Rate: 143
    You must have had a fancy with this condition of the engine! So, following your course, the driver should have coded that after 100,000 km, the parameters should change after 250 the same ... nonsense. There is the same amount of air, even if it is turbo, it is a pressure and temperature sensor, so knowing the pressure and temperature, a clever controller knows what the density is and will calculate the mass. So what's the point for? Good question and the answer is simple too :D
  • #4 8120860
    ociz
    Help: 1379
    Rate: 3488
    Well, not so exactly, especially in supercharged engines, where the intake manifold is often stuck with rubbish.
  • #5 8120865
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4187
    We are listening, what is the flow for?
  • #6 8120953
    barubar
    Help: 35
    Rate: 189
    amm212 - have you ever heard something about self-adaptation for this example? I am very curious about your simple answer. I'm looking forward.
  • #7 8120988
    tomek.kopiec
    Help: 18
    Rate: 62
    There is the same amount of air, even with turbo, and if you want to calculate the mass of air, knowing only the temperature and pressure - it took you away! They used to be flow meters, but they had a problem because they did not measure accurately (the influence of temperature on air density). In the case of hot air, volume It was constant and the mass fell down. That's why we now have mass meters, thermal and ultra. In sdi there is no flow because this engine has a constant mass of air for e.g. 1.9l for a full cycle. With turbo the situation is changing, there are no fixed values , and for precise dosing of fuel in relation to the sucked in, compressed mass and at a specified temperature, these devices are used, i.e. a 1.9-liter turbocharged engine can suck 2 liters of air for a complete cycle by means of a compressor, or rather a mass corresponding to a normal pressure of 2 liters.
  • #8 8121029
    barubar
    Help: 35
    Rate: 189
    Let's just add that there are quite a few supercharged engines without an intake air temperature sensor. In newer ones, where its influence on control is negligible, corrections are minimal. A little bigger in the CR. I know what the answer will be, there has already been such a discussion ...
  • #9 8121058
    rolnik41
    Rate: 29
    tomek.kopiec wrote:
    There is the same amount of air, even with turbo, and if you want to calculate the mass of air, knowing only the temperature and pressure - it took you away! They used to be flow meters, but they had a problem because they did not measure accurately (the influence of temperature on air density). In the case of hot air, volume It was constant and the mass fell down. That's why we now have mass meters, thermal and ultra. In sdi there is no flow because this engine has a constant mass of air for e.g. 1.9l for a full cycle. With turbo the situation is changing, there are no fixed values , and for precise dosing of fuel in relation to sucked in and compressed mass, these devices are used, i.e. a 1.9-liter turbocharged engine can suck 2 liters of air for a complete cycle, or rather a mass corresponding to a normal pressure of 2 liters.
    Of course, knowing the pressure (vacuum) in the intake manifold and the temperature can measure the mass. The speed in the collector and thus the air volume is measured by a vacuum sensor, which is then converted in terms of temperature thanks to a temperature sensor, which allows you to obtain a mass amount of air.
  • #10 8121074
    barubar
    Help: 35
    Rate: 189
    What kind of diesel vacuum sensor are you writing about?
  • #11 8121115
    rolnik41
    Rate: 29
    I only referred to the sentence
    if you want to count the mass of air, knowing only the temperature and pressure - it took you away!
  • #13 8121361
    rolnik41
    Rate: 29
    So, in general, the flow meter (mass measurement) is used to make the engine speed independent of external factors such as ambient temperature or pressure, so that the speed control is performed only by means of the gas pedal?
  • #14 8121402
    tomek.kopiec
    Help: 18
    Rate: 62
    "Of course, knowing the pressure (negative pressure) in the intake manifold and the temperature, you can measure the mass. The speed in the manifold and thus the air volume is measured by a vacuum sensor, which is then converted in terms of temperature thanks to the temperature sensor, which allows you to get a mass amount of air."
    Yes, in theory, and here my colleague RB26DETT put it very well that many factors affect the calculation of the dose for the engine, and that's what I meant. The pressure and temperature alone are not enough for a turbo supercharged engine. only air and fuel, but for the efficient, economical and ecological operation of the diesel engine, many more factors are needed, the management of which is possible thanks to today's technology.
  • #15 8121474
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    tomek.kopiec wrote:
    Pressure and temperature alone are not enough for a turbo-charged engine.
    maybe not so completely, because the Iveco Tector engines in terms of measuring the amount of air have only a temperature and pressure sensor and somehow work (euro 3 if I'm not mistaken) they are Common Rail but maybe they are not so modern
  • #16 8121513
    barubar
    Help: 35
    Rate: 189
    But that doesn't prove anything, if you insist, you can make a CR without any sensors. Well, maybe not without a gas pedal sensor. Again, what I don't like here starts. Academic discussion and we still do not even know what engine we are talking about.
  • #17 8121542
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4187
    "barubar" refers to a diesel engine :D :D :D
    amm212
    Help: 19
    Rate: 143
    I can see that the discussion is getting interesting and, on the other hand, I am sorry. or even mournfully that so many stout professional heads who can mock someone who, for example, is a cook and will answer a seemingly simple question for them and cannot answer an elementary question ... .
  • #19 8122368
  • #20 8122404
    rolnik41
    Rate: 29
    I consider the topic to be explained, but I have one more question, as Barubar called it "academic". I always wonder what is the point of installing turbochargers in gasoline engines where, of course, the main obstacle to increasing the compression ratio and pressure is the knocking phenomenon?
  • #21 8124145
    barubar
    Help: 35
    Rate: 189
    Therefore, turbocharged gasoline engines are "relaxed", ie the compression ratio is lower than in naturally aspirated engines. Does this answer satisfy you?
  • #22 8124201
  • #23 8124222
    robokop
    Help: 1763
    Rate: 6375
    Dear friend - relaxing the engine is a simultaneous increase in the capacity of the combustion chamber and, theoretically, the displacement - it is simply easier to stuff a larger amount of the mixture into a larger combustion chamber with less pressure. Knocking combustion again consists of several factors - the degree of compression of the mixture, i.e. its pressure at the moment of ignition, temperature in the cylinder, the moment of ignition, i.e. KWZ, and probably most importantly, the composition of the mixture and the octane number of the fuel, the speed of the flame front depends on the amount of fuel - too a small one will cause the mixture to burn out in the manifold, too large a knock on the walls of the combustion chamber - i.e. detonation combustion - instead of a gentle increase in pressure - that is why gasoline engines require powerful air coolers, often with forced cooling, mixture enrichment, to supply the turbine, blow-off systems releasing excess pressure from the system. It's like that in the "head".
    Added after 5 [minutes]:
    RB26DETT wrote:
    This problem is artificially created by Polish books duplicated since the 1960s. It is not a problem to see a 3.0 engine with a power of, for example, 800KM at slightly higher revs and a boost pressure of over 2.5 bar (2.5 bar on an absolute scale of 3.5). One of the cars leaves the factory in version 2.0> 400KM, compression ratio 8.5 (in the weaker version> 350KM compression ratio 8.8) and somehow there are no problems with knocking :D
    A colleague forgot to mention that these engines work on a mixture that is far from stoichiometric - the fuel is dosed much more than necessary (engine efficiency> 20%) - once due to the "turbine power supply" alone, two due to the elimination of detonation combustion - additional cooling mixtures by evaporating fuel. I will not mention the injection and phase ignition technologies.
  • #24 8124364
  • #25 8124556
    robokop
    Help: 1763
    Rate: 6375
    RB26DETT wrote:
    And something more about it?
    This is an apropos of the above considerations - read what diesels do with multi-phase injection, or two candles in the cylinder of petrol engines.
  • #26 8124853
  • #27 8124896
    barubar
    Help: 35
    Rate: 189
    In CR only on idle? What are you writing about? I understand that you have such a Lancer and you checked yourself, is there one fuel injection and one spark for one compression and exhaust stroke?
  • #28 8125171
  • #29 8125204
    barubar
    Help: 35
    Rate: 189
    1. You have no idea about CR.
    2. You have no idea about the so-called stratification of the mixture.
    3. You have no idea what you are writing about.
    4. Good night.
  • #30 8125316
    rolnik41
    Rate: 29
    Speaking of relaxing, I found it while reading articles and statements on the forum, this is the explanation:
    - relaxation is a larger combustion chamber
    - a larger combustion chamber is a larger capacity that will be filled by the fuel-air mixture
    - with larger capacity, it is easier to blow more air without using extreme pressures, which puts less strain on the entire equipment
    - more air blown allows you to pour more fuel
    - a lot of thoroughly burnt fuel is a big kick
    Anyone had experience with relaxing and fitting a naturally aspirated turbo? Any opinions on this?
    As for the layering of the mixture, he provides the link:
    http://www.diaaut.home.pl/r21021c1.htm
The discussion centers around the purpose of flow meters and throttle control in diesel engines, particularly in relation to fuel management and air intake. Participants clarify that while the amount of air may seem constant, it actually varies with engine conditions, especially in turbocharged systems. Flow meters are essential for accurately measuring the mass of air entering the engine, which is crucial for precise fuel injection, especially in modern diesel engines with advanced injection systems. The throttle is used not to regulate air intake directly but to signal engine load, allowing for better control of fuel delivery. The conversation also touches on the role of exhaust gas recirculation (EGR) systems and the importance of measuring air mass for optimizing combustion efficiency and emissions control.
TL;DR: Diesel common-rail systems vary fuel pressure from 250–1500 bar [Elektroda, Michał Walczak, post #8251771]; "The flow meter allows the controller to determine the amount of exhaust gas" [Elektroda, zbyniuś, post #8251914] Mass-air-flow (MAF) data lets the ECU match fuel, EGR and boost for power, economy and emissions.
Why it matters: Accurate air-mass data prevents soot, limp-mode surprises and failed emission tests on modern diesels.
• Stoichiometric diesel mix: approx. 15 kg air per 1 kg fuel [wopor, #8135974]. • Common-rail pressure window: 250–1500 bar [Elektroda, Michał Walczak, post #8251771] • Typical MAF failure can cut power by ≈30 % and trigger DTC P0101 (Bosch Handbook, 2018). • EGR rates: 5–40 % of intake flow in Euro 4/5 diesels [Bosch Handbook, 2018].
Why do modern diesel engines still use a mass-air-flow sensor?
The MAF gives the ECU real-time air-mass data. The controller then injects the exact fuel dose, sets boost and meters EGR. Without it, emissions rise and torque drops [Elektroda, Anonymous, post #8121197]
Is air flow in a diesel really constant?
No. Engine speed, altitude, boost and manifold fouling change the mass of air every cycle [Elektroda, ociz, post #8120668]
What does the throttle plate do on a diesel?
It briefly closes during shutdown to damp vibrations and creates slight vacuum to draw more EGR at idle; it does not set engine speed [Elektroda, Anonymous, post #8121197]
How can the ECU dose fuel if the MAF fails?
Fail-safe maps use manifold pressure (MAP) and speed to estimate load, but power may drop 20–40 % and smoke rises [Bosch Handbook, 2018].
How is EGR quantity controlled?
ECU subtracts fresh-air mass from total intake to compute exhaust-gas share, then positions the EGR valve accordingly [Elektroda, zbyniuś, post #8251914]
Can I simply delete the MAF and tune around it?
Possible on older SDI engines lacking EGR [Elektroda, tomek.kopiec, post #8120988] On Euro 4+ vehicles it will trigger fault codes and fail inspection (edge-case).
Why don't gasoline engines regulate speed only with fuel like diesels?
Gasoline needs near-stoichiometric mix for stable spark ignition; limiting air with a throttle maintains that ratio as fuel varies [robokop, #9816583].
Can I turbocharge a stock naturally aspirated engine?
Yes, but reduce compression or enrich mixture to avoid knock. Factory 2.0 L turbos run 8.5:1 compression at 2.5 bar boost [Elektroda, Anonymous, post #8124201]
How many injections can a diesel have per cycle?
Piezo injectors deliver up to five pulses each stroke for smoother combustion and lower NOx [wopor, #8135974].
What happens during a MAF sensor failure?
ECU logs P0101, switches to backup tables, limits rail pressure and may cap boost—drivers feel sluggish acceleration (edge-case) [Bosch Handbook, 2018].
How do I test a diesel MAF quickly?
  1. Read live MAF grams/second at idle; expect 8–12 g/s on a 2 L engine.
  2. Snap throttle; flow should jump above 80 g/s.
  3. Unplug sensor; if value freezes or engine stalls, wiring or sensor is faulty (How-To).
Do diesels use lambda sensors?
Yes in Euro 5+ models for DPF regeneration and fine mixture feedback, but corrections are smaller than in gasoline engines [Bosch Handbook, 2018].
