Addressing Automatic Line Ejection in Brushcutter Head: Alternatives & Solutions
beholder1990neophyte 60879 12
How can I stop a brushcutter head from releasing line whenever it strikes slopes or uneven ground, and which alternative heads can I use?
Replace the problematic head with a manual-extension head or a durable semi-automatic model, and first check that the existing head’s spring and spool-locking teeth are not weak or damaged [#8329586] The Husqvarna T45X semi-automatic head is recommended as a durable option with replaceable parts and an M12 thread [#8337134] A Husqvarna Trimmy II-style manual head extends the line only after stopping the engine and pressing the button to pull the line out, preventing impact-triggered feeding [#8337201] If retaining an automatic head, use the specified line thickness, wind it in the correct direction, ensure the head is fully tightened and has all internal washers, match it to the machine’s power, and keep the guard’s cutting knife sharp [#8340313] Automatic heads are generally better suited to relatively clean ground because sudden line pulls can release a long section of line [#8340313]
  • #1 8328093
    Rate: 66
    Hello!
    I have a problem with ejecting the line in the head with automatic ejecting of the line, namely baskets in hilly areas and lightly hitting some hills, the line comes out all the time. Recently, 25m of fishing line went into 15m. What to do with this? Are there any other heads for these scythes?
  • #2 8328213
    lukaszsobek123
    Rate: 128
    Can a colleague tell something more about this brushcutter, model??
  • #3 8328263
    Rate: 66
    Eurotec. The hair is ok! Only the head annoys me because it releases this line and cuts it off, and when I mow the edges or hills, the line flies. I've used several heads. Are there any other heads?
  • #4 8328306
    bartosz789
    Level 30  
    Help: 92
    Rate: 382
    Or maybe you're just using too thin a line?
  • #5 8328353
    Rate: 66
    I use 2.5mm or 3.0mm.
  • #6 8329586
  • #7 8337041
    Rate: 66
    The head is new, so everything is ok with it. Well, you know, baskets on hills, it reflects it and the line comes out. I want to buy some other scythe heads. If? For example, without the line slipping out, how are they?
  • #8 8337134
  • #10 8337215
  • #11 8337255
  • #12 8340243
    Rate: 66
    When I had the first head, it lasted the longest, probably about 2 months, and then it developed like this (spring or plastic of the head housing) and it doubled the line faster and faster, then I bought 2 heads of 3 and the same thing, only that these are even faster. Ok, I will buy an automatic head but there are no cheaper ones??? It doesn't have to be original.
  • #13 8340313
    GrandMasterT
    Help: 69
    Rate: 195
    Rycho T wrote:
    In automatic heads, the line feed is slow all the time while it is running.
    I don't agree with that.
    In automatic heads, e.g. Husqvarna, the line is retracted only when both ends become too short or one breaks off. In the Superauto and Superauto 2 heads, you can hear a pop and the line jumps out one step of the internal hooks - about 1/4 of a turn of the spool.
    However, this system works properly only when the monofilament line is of the appropriate thickness (in the manual of the head min/max thickness is given) and when the head is well twisted, no inner washer is missing and the monofilament inside is wound in the right direction :!:
    In addition, the head must be matched (and/or set -> head instruction) to the power of the machine.
    Regardless, in my opinion automatic machines are only suitable for relatively 'clean' terrain, because each sudden pull of the line sometimes ends with the whole or at least a long fragment. When working with the machine, the knife on the guard must be in good condition, otherwise there are problems with unwinding the line.
    If we are at Husqvarna, it has heads with manual line extension.
    The only problem is that you have to turn off the engine by pressing the button on top of the head and pulling the line. It will come out similarly to a semi-automatic.
    http://www.husqvarna.com/en/landowner/accesso...t-accessories/g-blades-and-blades/trimmy-sii/
    TrimmyII (and its earlier versions) is in my opinion the best head, in addition to the manual button, it has one more advantage - the bottom with bearings (and replaceable :! :) stopping after touching the ground, thanks to which the head is not damaged quickly, especially where something protrudes from the soil.
    Unfortunately, it is expensive and quite difficult to access, with 2 months ago I drove around the area and I couldn't buy it anywhere. In a few online stores, the price is greatly exaggerated, for the same amount you can buy 5-6 cheaper heads.
The discussion revolves around issues with automatic line ejection in brushcutter heads, particularly in hilly terrains where the line frequently ejects during operation. The user experiences excessive line release, leading to a significant waste of line material. Various responses suggest checking the head's spring mechanism and ensuring the line thickness is appropriate. Recommendations for alternative heads include the Husqvarna T45X semi-automatic head, known for its durability and replaceable parts. Other options mentioned include manual and semi-automatic heads from Husqvarna, which require manual intervention for line extension. The conversation highlights the importance of matching the head to the machine's power and using the correct line thickness to minimize issues.
