[Solved] Kosa Grizzly MTS 34 Cutter Disassembly Guide: Broken Pull Line Replacement & Compatible Parts
decicom 11940 3
  • #1 16485722
    decicom
    I have been a user of a scythe as in the title for 12 years, probably. Today my pull line broke. I unscrewed it and? It can be dismantled somehow, because I do not know how to wind a new line. The cutter looks like this:
    There is a "screw" in the center of the circle for a Phillips screwdriver, but it does not twist.
    I know the scythe is old, but the engine itself works quite well and I have invested a bit in it over the years: a seatpost with a new shaft, a few angular gears. In addition, I run it every time and cut it for several hours at a time, with a break for refueling.
    PS
    A few years ago I had a problem with it, it didn't smoke, it walked unevenly, etc. A friend fitted the ignition coil from the 300cc Linhai 4x4 Chinese Quad Bike. Since then, I have not had the slightest problem with firing, extinguishing, etc. Even after winter, I start as if it would work yesterday. I am writing, it may be useful to someone.
    And after a few cheesy heads, I put a Husqvarna head into the line. I added a comfortable Stihl harness and I have been doing it until today.
    If someone is able to help me, tell me something - I will be grateful.
  • #2 16485894
    E8600
    Help: 529
    Rate: 2520
    Nothing needs to be disassembled to replace the cable. You just cut the old one and measure the length, buy a new one, make a knot, thread it through the eyelet on one side, then through the shredder housing, at the very end through the pull handle and make a second knot. If you have everything braided well, you stretch the spring and wrap it with string, and it's ok. Here's a preview video.
    [youtube]https://www.youtube.com/watch?v=r6yvNMDZvrg [/youtube]
  • #3 16486437
    decicom
    Thanks, new line set up in the morning, Grizzly goes on.
    But I am still bothering with the screw inside, clearly for the screwdriver, but there is no option to unscrew it.
  • #4 16486517
    E8600
    Help: 529
    Rate: 2520
    It probably has some protection or it's just a bolt in appearance. Better not to combine it, because if the spring fires, you will only get tired of rolling it up again.
