CANDY ACS80 washing machine error E03 after vacation—possible sensor or drainage issue?
_bikerrr_ 126884 3
  • #1 8442555
    _bikerrr_
    Rate: 10
    Hello everyone
    I have a problem with the washing machine - after returning from vacation - my wife started the washing machine and after some time he fired the E03 error. The washing machine does not spill water - this is how it is explained according to the instructions.
    However, the pump works, it pours water as usual, but when it is finished, it crashes an error, as if a sensor could see that the water was not poured out ......... Is it possible and if so, where to look for such a sensor ???? How to replace it, clean it ...?
    Or maybe the reason is completely different?
    I am asking for help - best regards
  • #2 8446037
    Mirek321
    Help: 54
    Rate: 275
    Hello, it may be a clogged hydrostatic stub in the lower part of the washing machine connected with a hose up to the round box with wires
  • #3 8454606
    machefi
    Home appliances specialist
    Help: 763
    Rate: 1487
    Maybe the water is not pouring it out quickly enough. Water should leave the machine within 30-40 seconds. otherwise the electronics will interpret it as damage to the pump. Check the filter and if there are no socks in the hoses. Greetings.
  • #4 8825966
    ww1968
    Rate: 25
    I want to thank you for placing the socks one floor above in the drainage point of the washing machine. "Sock" or a clogged hose - saved me from repair.
    thank you
    WW
