Astra F 1.7TD Isuzu - Not charging, charging indicator light on
Mianas 7794 18
Why does my Astra F 1.7TD Isuzu not charge properly, with the charging warning light and tachometer not working, and can I use a 2-pin alternator instead of the original 4-pin one?
The problem was solved by swapping the pulleys between the two alternators; after that, charging returned to 14.45 V at idle and about 14.2 V with electrical load, so the pulley difference was the cause of the low charging [#16263315] This also showed that an alternator with a different plug type, including a 2-pin unit, can be connected in a car that originally uses a 4-pin alternator plug [#16263315]
  • Diagnosing Astra alternator wiring and 2-pin replacement
    #1 16251752
    Mianas
    Hello. I have a charging problem with my Astra. On Saturday I put the car down, on Monday my mother tried to start it, he didn't even mumble. I thought that something just discharged it and my mother tried to start the car with the cables, despite half an hour of fighting it failed. I took out the battery and charged it, put it in the car and fired it, but the charging does not show only as much as the battery has and the charging indicator and the exclamation mark light are on (no, this is not a manual indicator, there is a P indicator from the manual), it also does not work tachometer.
    Is it possible that the alternator has burnt or just a relay somewhere, a fuse that activates the alternator?
    I have a 4-pin cube alternator installed, but I also have a fully functional 2-pin alternator, but I do not know how to connect it more accurately, will someone suggest something more?
  • #2 16251872
    kot mirmur
    Help: 206
    Rate: 561
    The alternator doesn't have to burn out right away, maybe the voltage regulator has fallen, or the brushes just run out, or there might be a broken one-way pulley clutch.
  • #3 16251892
    zubereq
    Help: 13
    Rate: 89
    Better make your old alternator, because if I remember correctly, it still has a vacuum pump on it.
  • #4 16252116
    Mianas
    I know that not immediately, I know a little about mechanics ;) The brushes would not end immediately, and if the regulator fell, there would be any charging and there is no 1V, but it all started to happen after trying to fire from the cables. Broken pulley one-way clutch or something to be exact?
    Yes, there is a pump, but the second alternator I have is from the same engine, but with the Vectra B 97r it only differs in the cube, the rest is the same or you can possibly switch the rotor just a matter of connection.
  • #5 16252204
    zubereq
    Help: 13
    Rate: 89
    In the 4-pin, you probably have markings
    L- indicator
    W- tachometer
    S- + battery
    IG - ignition
    you probably have two pins
    L-indicator
    W-tachometer
    Go ahead and try it yourself. As if you had problems in the network, there are connection cubes with the description of the connectors.
  • #6 16252373
    Mianas
    L- indicator
    W- tachometer
    S- + battery
    IG - ignition
    L-indicator
    W-tachometer
    Well, that's it and I know it. Only what and why these S and IG cables? Do they need to be connected?
  • #7 16252944
    kot mirmur
    Help: 206
    Rate: 561
    This clutch is usually mounted in the alternator pulley. It works in the same way as the so-called torpedo in old assemblies [it is about bicycles]. Specifically - you turn e.g. clockwise, the clutch grabs and turns the rotor, spinning but impeller not.
  • #8 16252995
    Mianas
    I'll check it tomorrow but I doubt it's it.
  • #9 16253111
    kmitki
    Help: 39
    Rate: 232
    There you have a Hitachi alternator very emergency. The bridges 100A burn most often, sometimes also voltage regulators.
    • Astra F 1.7TD Isuzu - Not charging, charging indicator light on alternator isuzu.jpg (97.54 KB) You must be logged in to download this attachment.
  • #10 16253189
    Mianas
    Exactly as you're saying. I have a car for 5 years and the second time I will be repairing something related to charging: / I have already installed a voltmeter in the car to know when it will fall and I put the engine cover so that the water on the alternator does not fly
  • #11 16255923
    Mianas
    Today I set up a second aternator, but the charging is only 13.5V, is it possible that the charging is so low due to the fact that in both alternators the wheels on which the belt is running are of different sizes?
  • #12 16256549
    kot mirmur
    Help: 206
    Rate: 561
    At what engine revolutions was the measurement taken?
  • #13 16256680
    Mianas
    At each and the maximum it showed just 13.5V. And at idle 13V.
  • #14 16256762
    kot mirmur
    Help: 206
    Rate: 561
    A little too little, pass. 13.8 should be. LEDs or voltage regulator to be replaced. Alternator not getting hot?
  • #15 16256811
    andrzej20001
    Help: 1578
    Rate: 6671
    Alternator to be repaired, indicator relay to be replaced and elimination of harmful candles heating. You can start at the end of the list. And these altars don't have a backstop.
  • #16 16256818
    kmitki
    Help: 39
    Rate: 232
    If the measurement was on a cold engine, everything is ok because the engine is reheated and therefore such a decrease. And if it's warm, it's a damaged alternator.
  • Separate glow-plug switch limits heating load during measurement
    #17 16256870
    Mianas
    The alternator is regenerated. It wasn't getting hot or even warm.
    The alternator is regenerated. The relay is bypassed, otherwise it would not be possible to connect this alternator, it has 2 pins and not like my old 4, so it has no effect on it. The candle heating system works properly.
    The alternator is regenerated. The measurement was made on a cold engine, but it has nothing to do with it, because I have the candle heating system only works when I let it, because I have a separate switch to save electricity, I run it only at lower temperatures, i.e. if I have the heating indicator light goes out, the heating operation also ends.
    Oh, and one more thing to everyone, before you give any advice, read the whole topic, because you give questions that I have already answered earlier and you do not know the situation what I have done in the car and what I have already checked :)
  • #18 16256993
    andrzej20001
    Help: 1578
    Rate: 6671
    | Well, if the belt has no slip, the alternator needs to be corrected. Also check the + and - voltage directly on the alternator.
  • #19 16263315
    Mianas
    Problem solved :) As I said, I moved the pulleys between the alternators and the charging on the alternator is 14.45V on the 14.4V battery at idle without load, after load (turning on the lights, vents and 14.2V radio). you can connect an alternator with a different plug (2 pins) to the car in which the alternator plug is 4 pins :)
The discussion revolves around a charging issue with an Astra F 1.7TD equipped with an Isuzu engine. The user reported that after attempting to jump-start the vehicle, the charging indicator light remained on, and the tachometer stopped functioning. Various potential causes were suggested, including a faulty alternator, voltage regulator, or worn brushes. The user also inquired about connecting a 2-pin alternator to a system designed for a 4-pin alternator. After troubleshooting, including checking the alternator's performance and swapping pulleys between alternators, the user successfully achieved a charging voltage of 14.45V at idle, confirming that the issue was resolved by adapting the alternator connections.
