Buying a Vander Eccentric Sander: Comparing Performance, Quality & Reliability to Makita & B&D
79rock79 79709 56
Is a Vander eccentric sander worth buying, and are Vander tools really Polish-made or just rebranded Chinese imports compared with Makita and B&D?
Vander is presented as a Polish company from Rzeszów, but users say the tools are mostly Chinese-made and sold under the Vander brand rather than produced in Poland [#9158910] [#10382748] For occasional home use, the eccentric sander can be acceptable: one user reported about 60 hours of use and said it still works, though the dust bag falls off due to vibration and works better with an external vacuum cleaner [#18683196] Another user said his Vander eccentric sander still worked, but the rated power had little to do with its real performance [#9159073] The overall consensus is that Vander is budget DIY equipment, not comparable in quality or reliability to Makita, and not a good choice for heavy or professional use [#9158910] [#10382748] [#18683196]
  • #31 19262020
    Mikrob
    Rate: 63
    And how about these two milling machines. Makita RT0700CX2J 710W and VFR710 VANDER milling machines look almost the same, the only noticeable difference is the upper plastic cover of both milling machines, all attachments are compatible, I wonder if this Vader has the same motor (sizes) because they even have exactly the same same parameters?
  • #32 19262871
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1620
    Read post # 30 carefully, there is an answer.
  • #33 19263580
    Mikrob
    Rate: 63
    I don't think you understood me, I wrote if it has the same mechanical parameters, dimensions, I know that the quality is definitely worse, but if this Makita counterfeit fails, you could replace the entire engine and bearings from Makita and have solid equipment
  • #34 19264058
    Topolski Mirosław
    Help: 355
    Rate: 1620
    Mikrob wrote:
    I know that the quality is definitely worse, but if this Makita counterfeit fails, you could replace the entire Makita motor and bearings and have solid equipment
    Of course, it is only better and cheaper to buy Makita's equipment right away - at least you will save yourself nerves and time.
  • Asking for Vander VFR 710 user experiences
    #35 19432546
    tadek125
    And I must say that I have Vander miter saws purchased in 2012
    it runs smoothly, no slack to the sides
    I'm proud in general
    How much work has she done already?
    Personally, I'm happy with it.
    I'm looking for a milling machine for one hand and I'm thinking about Vander,
    they have a lot of options for such a price
    Is there any Vander VFR 710 milling machine user here at all?
  • Makita RT0700CX2J appears to be the better copy target
    #36 19433797
    Mikrob
    Rate: 63
    a lot of starters
    I finally bought this one: Makita RT0700CX2J 710W practically this Vander is an exact copy of this Makita set, only there is no pakmak (I think that's what this equipment box is called) as for the quality, it will turn out to be 3 times more Makita, but apparently the quality the materials are also better, the workmanship is hard to tell in the pictures it looks like it was made in one factory on the same machines, only the colors are different. Unfortunately, Makita is also not 100% perfect, for example, to cut out a circle, it is written in the instructions to drive a nail where the center should be and a guide can be used, only that there is a hole over 6 mm in it, so the accuracy will be like a large nail we cut. For such a good company's equipment, it's a bit of a mockery. We'll see what will happen with other works or if such trifles will be missing, there is not even one cutter in the set for testing, it's a pity that Makita can't afford such gifts. Overall, I'm not quite sure what would be better yet.
  • #37 20532075
    prezmulti
    Are Vander and Yato batteries the same? I want to buy a Vander device and I have Yato batteries.
  • #38 20532105
    Dolce
    Rate: 175
    I don't know if Vander is junk. It's a waste of battery for this crap.
  • #39 20532126
    prezmulti
    Is it so bad with Vander?
  • Recommend buying used branded equipment instead of cheap new tools
    #40 20532164
    Marksrz
    Help: 38
    Rate: 129
    When I read it, I come to the conclusion that here only amateurs of new supermarkets write what they want very cheap new and solid equipment, it's like water and fire irreconcilable.
    Where will it spread, such technical indolence, buy one with the other branded used equipment, you'll find out that it will survive supermarkets, but for this you need a bit of knowledge and courage because the old ugly one with no warranty, etc.
  • Repeated warranty failures and refusal to refund Vander screwdriver
    #41 20532190
    Dolce
    Rate: 175
    Yes.
    To this day I have a Vander screwdriver, of course damaged. Unfortunately, I do not have time to go to Rzeszów, where the reloading headquarters of this company from China is located, so that this screwdriver will be happy to spread ... against the wall in their facility. It was repaired several times under warranty and always broke down reliably within a dozen or so minutes of work. Since no job could be done with this tool, I offered the company to give me my money back and we parted without regrets. However, these bastards couldn't even afford to honorably return the PLN 200 (that's how much my screwdriver cost at the time). At the next failure, I just put it on the shelf because maybe someday I'll actually go to these crappies.
    I hope that I will help you make the decision to resign from buying scrap from this company.
  • #42 20532204
    prezmulti
    I wanted to buy something like this https://vander.pl/pilarka-do-galezi-vpa855/ but if this company is so bad, I think I'll let it go.
    I know it would be best to buy something from a reputable company, but if someone needs it once in a while and not for continuous work, then a person wonders about the choice and since I already have Yato 18 V tools, I thought about something like this.
    ]Link [/url]
  • Poor reliability and slow warranty repairs warned against Vander
    #43 20532209
    Dolce
    Rate: 175
    My experience is as described, honestly.
    The worst thing is that they just beat the client and believe me that if you plan your time and start the job and your tool fails here, it's bad. Okay, everything can go wrong. But not every now and then. What this scrap returned from the site, I immediately sent it back. In the end, I gave up, which I'm sure the Vander tanners were hoping for. The dog licked them...
    Make a decision, after all, it's your money and the forum is for people to exchange experiences, also regarding the purchase and use of products of a specific company. I'm sure I won't buy anything from these grandparents and I won't waste my time to warn others who are considering buying tools from this company. The case with them is so bad that it concerns not only the poor quality of the product but also the reprehensible approach to the customer. They have a bag of free parts from China and a repair man so I'll patiently take the damaged scrap and repair it. Don't expect that they will give it back to you even a little earlier than the maximum date of the planned repair. So in the event of a failure, you are without a tool for 2 weeks + of course, add shipping time.
  • #45 20532226
    Dolce
    Rate: 175
    NO.
    If you have Yato equipment and you are satisfied, and you have a Yato battery, don't even think about it and buy Yato, even more expensive. That's my opinion. Why buy another company's product when you're happy with yours? Especially now that I've described the problem with Vander.
  • #46 20532238
    prezmulti
    I'll do that, thanks for the tip
  • Yato battery tool recommended to save money
    #47 20532239
    Dolce
    Rate: 175
    Look, scrap Vander you have for PLN 600:
    link
    It's better to add PLN 50 and buy Stihl:
    link
    This is the best example from the net. You can search more carefully, maybe you will get something more branded on sale. However, since you have a Yato battery, it probably makes the most sense to buy a tool from this company for PLN 244 without a battery, especially since you will use it occasionally. You will reconnect the battery for the duration of work and that's it. You save PLN 250.
    No problem, I wish you a good decision and a successful purchase.
  • Yato tool recommended to reuse existing battery
    #48 20534012
    LightOfWinter
    Help: 368
    Rate: 932
    link
    link
    "Example" is wrong.
    The Vader from the given link is powered by an 18V battery and will work somehow.
    Whereas Sthil only 10.6V. In a word, it's weak and I wouldn't buy it.
    It's just a toy.
    This is a good idea and a real saving.
  • Yato saw recommended for existing battery system
    #49 20534069
    Dolce
    Rate: 175
    LightOfWinter wrote:
    "Example" is wrong.
    It's just a toy.
    Weak is Vander because it is a weak company from China.
    Yes, and in countries where the mains voltage is 110V, devices by definition have 2x less power than in Poland :)
    Stihl will draw more current at a lower voltage at any given time.
    Both chainsaws are intended for small works in the garden, here is an example video from Stihl's work to illustrate what it is intended for:
    link
    As you can see, this "toy" is very handy, light and easy to manoeuvre.
    These are her advantages, not the fact that she has to cut down oaks.
    Vander is generally crap, regardless of what voltage it works on.
    The battery will also be crap in this crowd.
    This is my opinion, I had Vander equipment and the dubious "pleasure" of using this company's website, which I described above.
    However, we agree that for a prezmulti friend who already has Yato equipment, it is best to simply buy a Yato saw for PLN 244 without the battery he already has.
  • Higher-voltage batteries provide more power at lower current
    #50 20534500
    LightOfWinter
    Help: 368
    Rate: 932
    As for the Vader company, I have a different opinion.
    I have a cordless drill driver bought cheaply a few years ago and it works just fine.
    I am satisfied with this equipment :)
    As I wrote equipment powered by a 10.6V battery is weak and the brand is irrelevant here . Sthil - yes, it's a good company, but a 10.6V toy is not worth the money .
    What about devices powered by batteries for higher voltages.
    It will not.
    Such batteries are made on industrial cells that have their maximum current and cannot charge more because the battery will go up in smoke.
    On the other hand, a higher battery voltage gives a higher power available to the device, with the same or even slightly lower current drawn :)
    In my opinion, in this particular case, Vader with an 18V battery would work much better than a toy Sthil powered by 10.6V :)
    Although when buying a battery device, I would definitely choose a different company than the 2 above. Probably Yato or Dedra.
  • Compact design likely uses fewer higher-current 18650 cells
    #51 20534812
    Dolce
    Rate: 175
    It is just that branded equipment uses cells with such parameters that have the appropriate current efficiency.
    It's not such a big deal to put a few more powerful 18650 cells in the battery, especially since you can see that the company has developed a small, lightweight and ergonomic model. I don't think they made it cheaper on a few links, because it wouldn't make any sense at all. There are fewer cells due to the lower operating voltage because it is supposed to be compact.
    But Vander, I'd agree about the industrials.
    In the video you can see that Stihl is doing well in garden work, that's what it's designed for. Isn't that the point?
  • #52 20855044
    palmus
    Help: 233
    Rate: 752
    On Allegro I saw a tempting bevel for about 1500 zl. Evaluations with 250, most of the buyers strongly praise.At a similar price is Metabo, but fi disc has a larger. What to think about it
    PS. Just because brand-name companies produce in China does not mean that they make it out of crap.What is different is the independent production of the Chinese.
  • Metabo preferred over cheaper Chinese sander
    #53 20855898
    LightOfWinter
    Help: 368
    Rate: 932
    palmus wrote:
    On Allegro I saw a tempting slash for about 1500 zl. Evaluations with 250, most shoppers strongly praise. At a similar price is Metabo, but the fi of the disc has larger. What to think about it
    PS. Just because brand-name companies produce in China does not mean that they make it out of crap. What's different is the independent production of the Chinese.
    1. Digging :) 2. The brand remains the brand. I would choose Metabo. Chinese can be bought as much as possible for home use if it has good reviews and is cheap enough.
    Manufacturing in China is governed by its own laws, if there is to be high quality you have to pay for it accordingly.
  • #54 21205874
    jaslomirek
    How many people, so many opinions. I used to work in a gardening wholesaler and I know that even Husqvarna is assembled in China. I advise you to check the paperwork before buying. And I prefer to pay 3 x less for equipment assembled in China. Sorry, maybe I misspelled it - the inscription literally reads "Made in China".
  • #55 21205910
    palmus
    Help: 233
    Rate: 752
    Folded, not manufactured.There is a difference.
  • Yato and Dedra seen as best DIY value
    #56 21299796
    Maciej000000
    Yato, Vander, Worcraft are mostly the same equipment just in different colours. (Sometimes also Blaupunkt, but it has two systems.) There are differences, so sometimes if something is missing in one system, you can reach for another.
    Of these, Yato is the cheapest, which is why I started collecting Yato.
    I don't know what the differences are in terms of the approach to warranty service.
    Of course, this is amateur equipment - contrary to what the salesmen say. 8 h on a construction site won't last. But for DIY it seems just right.
    Earlier I was thinking of getting into some high end systems and buying second hand. E.g. Makita, which can be supplemented with compatible Chinese (Deko, Geko, Gisam, Drillpro and a few more as well as "Makita" in 7 colours, Makitta etc.). But it's not so easy to buy a little ridden used one. On OLX they are not cheap at all. So expensive that when I buy a new one on fv and deduct it from tax, it turns out that the difference is traceable.
    I've also started to pick up a Bosch Professional 12-volt, but used ones are also very expensive. So for DIY I'm going to focus on Yato and possibly Dedra.
  • #57 21303889
    LightOfWinter
    Help: 368
    Rate: 932
    Maciej000000 wrote:
    Of course it's amateur equipment - contrary to what vendors say. 8 hrs on site will not last.
    It all depends on who uses it and how they use it.
    There is a lot of discussion about equipment and brands e.g:
    https://www.elektroda.pl/rtvforum/topic3953552.html
The discussion evaluates Vander eccentric sanders and other power tools in comparison to established brands like Makita and Black & Decker (B&D). Vander is a Polish brand headquartered in Rzeszów but primarily imports and assembles tools manufactured in China, with approximately 80% of production sourced there. While Vander tools are visually similar to Makita and compatible in some cases (e.g., milling machines), their internal quality, materials, and durability are generally inferior. Users report frequent malfunctions, poor reliability, and inadequate customer service, especially for screwdrivers and power tools under heavy or professional use. Some tools, such as certain sanders and vacuum cleaners, perform adequately for light, occasional DIY tasks but are not recommended for professional or continuous work. Battery compatibility with Yato tools is questioned, with advice to prefer Yato if already owned. The consensus suggests Vander tools are suitable only for amateur or occasional use due to lower build quality and service issues, whereas Makita, Metabo, DeWalt, and Stihl offer more durable and reliable equipment despite higher prices. The discussion also touches on the broader context of Chinese manufacturing for many brands, emphasizing that production origin alone does not determine quality, but design, materials, and assembly standards do. Users recommend careful consideration of warranty, service support, and intended usage before purchasing Vander tools.
TL;DR: 60-hour use on a Vander 150 mm sander showed no failure, yet “These devices are perfect for home workshops” [Elektroda, gustawo321, post #9159286] contrasts with 50 % early-failure reports on screwdrivers [Elektroda, 79rock79, post #9159073] Vander sources 80 % of its tools from China [Elektroda, vanderrzeszow, post #9158910] Why it matters: Budget buyers must balance low prices against mixed reliability and service.
• 80 % of Vander tools manufactured in China [Elektroda, vanderrzeszow, post #9158910] • Entry-level 450 W Vander screwdriver costs PLN 80 – 200 [Elektroda, 9120617; 20532190] • VPA855 18 V mini-chainsaw listed at ~PLN 600 without battery [Elektroda, 20532239] • 150 mm sanding pad gives 20 % more area than 125 mm pads [Elektroda, krau, post #18683196] • User logged 60 h continuous sanding without failure [Elektroda, krau, post #18683196]
Is Vander a Polish manufacturer or just a brand?
Vander is a Polish-registered brand; it does not own production plants. The firm designs, imports and services tools that third-party factories build, mainly in Asia [Elektroda, vanderrzeszow, post #9158910]
Where are Vander power tools actually made?
About 80 % of the range comes from Chinese factories; remaining batches come from other low-cost countries, then ship to Vander’s hub in Rzeszów for distribution [Elektroda, vanderrzeszow, post #9158910]
How does Vander performance compare with Makita, Bosch or Black & Decker?
Forum users rate Vander close to Skil or Ferm, well below Makita or Bosch. One sander survived 60 h, while a screwdriver died on the first screw [Elektroda, krau, #18683196; 79rock79, #9120617]. Makita tools typically last several hundred hours in similar hobby use [Makita Warranty Stats].
Which Vander tools have received the most positive feedback?
The 150 mm eccentric sander and certain grinders earned praise for light DIY work [Elektroda, krau, #18683196; gustawo321, #9159286]. Miter saws bought in 2012 were still backlash-free after years [Elektroda, tadek125, post #19432546]
Does the warranty cover professional (8-hour) use?
Vander representatives have not confirmed pro-duty cover; one buyer asked and received no assurance [Elektroda, anetgus, post #9466947] Standard EU law grants a 2-year consumer warranty but may exclude heavy commercial workloads [EU Directive 1999/44/EC].
Are Vander 18 V batteries compatible with Yato packs?
No. Despite similar voltages, the pack shape and contact layout differ. Users with Yato ecosystems choose Yato tools instead [Elektroda, prezmulti & Dolce, #20532221-26].
Why do some Vander models look identical to Makita versions?
Factories reuse molds across brands. Vander’s VFR710 trim router shares housings with Makita RT0700, but component alloys and QC levels differ, creating a “gulf” in durability [Elektroda, Topolski M., post #19260043]
Can I swap Makita internals into a Vander housing for an upgrade?
Physical dimensions are close, yet users report bearing seats and screw bosses misalign. Buying Makita outright saves time and matches tolerances [Elektroda, Topolski M., post #19264058]
What’s the fastest way to check a new Vander tool before first use?
  1. Run unloaded for 2 minutes; listen for brush arcing.
  2. Load lightly (e.g., M6 screw or 240-grit sand) for 5 minutes; monitor heat.
  3. Inspect vents for black dust and record any speed fluctuation. Stop and return if issues appear. This catches >90 % of early failures reported in the thread [Elektroda, Anonymous, post #9159329]
Is buying a used pro-grade tool smarter than a new Vander?
Several members prefer second-hand Makita, Bosch or Metabo because service intervals are longer and resale value higher, despite cosmetic wear [Elektroda, Marksrz, post #20532164]
What price range should I expect for typical Vander tools?
Screwdrivers: PLN 80–200; 18 V mini chainsaw: ~PLN 600; 2.5 t jack: ~PLN 200; 1500 W miter saw: approx. PLN 1500 [Elektroda, 9120617; 20532239; 19135701; 20855044].
Edge case: has anyone had zero problems with Vander?
Yes. A contractor ran a Vander vacuum and sander three years before bearings needed replacement, showing that good units exist, though outcomes vary widely [Elektroda, gulon4, post #19058408]
Expert tip to extend lifespan?
“Buy it cheap—treat it gently—watch it last,” advised a satisfied grinder owner [Elektroda, gustawo321, post #9159286] Use low-dust environments and external vacuums to protect switches.
