Difference Between 2GB 2Rx8 and 2GB 1Rx8 RAM for Laptop: Understanding Memory Modules
Rzeznik533 69286 7
  • #1 9195103
    Rzeznik533
    Rate: 11
    Hello, I want to change the memory of the RAM in my laptop and I noticed that there are two types of memory:
    2gb 2Rx8
    2bg 1Rx8
    Can anyone explain to me what the difference is and which ones are better, but the easiest way to explain it
  • #2 9195565
    among
    Help: 146
    Rate: 99
    "NR x M" represents "N" banks of SDRAM chips with a data bus width of "M bits". Thus, the 2Rx8 module has two banks of 8 8-bit chips, and the 1Rx8 has one bank of 8 8-bit chips.
  • #3 9195576
    irondick
    Help: 112
    Rate: 131
    Tjaa, and a laptop from 80 or 82? On DDR1 or on DDR2? Production of DDR or Germany? ;-)
    Buddy, give the basic information nicely, then someone will answer sensibly!
  • #4 9195654
    Rzeznik533
    Rate: 11
    Ok, I already know something, but it doesn't tell me much, write me which ones are faster or better.
    Somehow a colleague above was able to give me an answer, but if I already tell you that it is about ddr3, the laptop is 4 months old
    Added after 6 [minutes]:
  • #5 9195667
    among
    Help: 146
    Rate: 99
    The fewer chips the better.
  • #6 9195672
    Rzeznik533
    Rate: 11
    This is the Memory that I want to buy and I am interested in the notes marked in the squares because I do not really know what they mean ??? I'm going to buy two dice that are different and the difference is that one die has the designation 1010 and the other 1024 ???
    Added after 5 [minutes]:
    Why do they work faster or break better
  • #7 9195690
  • #8 9195700
    Rzeznik533
    Rate: 11
    vogelek23 wrote:
    Rzeznik533 wrote:
    the difference is that one bone has the designation 1010 and the other 1024
    This is the date of manufacture (so-called Date Code).
    1010 means 2010 and week 10 (production March 8-14, 2010).
    1024 is 2010 and week 24 (production June 14-20, 2010).
    Thank you very much for your answer, I will be returning to this designation when buying a memory
    Now I know why these 1Rx8 are better, please tell me why they are better faster / more durable because it also matters because they are more available and I do not know if it is worth looking for 1Rx8
The discussion centers on the differences between 2GB 2Rx8 and 2GB 1Rx8 RAM modules for laptops. The key distinction lies in the configuration of memory chips: 2Rx8 has two banks of 8 chips, while 1Rx8 has one bank of 8 chips. Generally, 1Rx8 modules are considered better due to fewer chips, which can lead to improved performance and reliability. The conversation also touches on the importance of the manufacturing date codes (e.g., 1010 for week 10 of 2010) and their relevance when purchasing RAM. Users express interest in understanding which RAM type is faster and more durable, with a consensus leaning towards 1Rx8 as the preferable option.
