EGR Valve Blanking: Effects on Engine Performance, Emissions, and Reliability
Werewolf 149696 15
What are the real effects of blanking the EGR valve on engine performance, emissions, and reliability, and is it harmful or beneficial?
Blanking the EGR usually improves low-rpm response and reduces soot in the intake, but it mainly worsens emissions and can trigger ECU faults or limp mode in newer cars [#9408365][#9404896][#9405146][#9401319] With the EGR closed, exhaust is routed through the turbine, so boost comes up earlier and the car can feel stronger from around 1000 rpm, especially at partial load; maximum power does not really increase because a properly working EGR closes under heavy load anyway [#9408365][#9404896] The trade-off is higher combustion temperature and more NOx, because the EGR is there mainly to lower combustion temperature for environmental reasons, not to protect the engine [#9408365] On cold diesel engines it also helps faster warm-up, so blanking can make winter cold-start running worse [#9407796][#9408365] Several users report that deleting EGR stops soot buildup in the manifold that mixes with oil and can reduce clogging, and older cars sometimes feel better after blanking [#9408365][#9407515] However, many newer cars detect low EGR flow and enter safe mode or store an error like 0400, so full blanking is often not practical on newer engines [#9404896][#9405146][#9401319]
  • #1 9401295
    Werewolf
    Help: 30
    Rate: 350
    There is no question, because opinions are divided regarding the blinding of EGR.
    The fact is that the temperature in the combustion chamber will be higher, but only at idle speed, and the collector will be dirtier.
    People who are blinded as facts present that this is an ecology-only valve, and when blinded, the car will be more dynamic at low revs without damaging the engine.
    I would like to know your opinions and thoughts. Thanks for the answers.
  • #2 9401319
    macvir
    Conditionally unlocked
    Help: 32
    Rate: 262
    a lot of cars after say 2004 will not go with a blinded EGR, so why such a topic?
  • #3 9401346
    Werewolf
    Help: 30
    Rate: 350
    For a very prosaic reason to broaden horizons and to educate oneself.
  • #4 9401501
    mosmati88
    Help: 28
    Rate: 152
    I also have a car with EG. Fiat punto 2 2000 1.9JTD. and I am also wondering whether or not to plug the valve. It is known how diesel likes to smoke sometimes and this soot gets into the manifold. Surely this soot is not healthy for the engine.
  • #6 9401579
    Werewolf
    Help: 30
    Rate: 350
    I meant something like that, I start reading.
    Let the topic stay open for some time, maybe someone will have something else to add.
  • #7 9404896
    kmitki
    Help: 39
    Rate: 232
    I have an omege 2.0 dti 101KM and in my case it is not possible to blindness because the computer is about to enter safe mode and crashes the error 0400 but there is an option in the settings that I reduce the opening of the EGR but only to -20% max. This setting means that the car is much better to collect, there is no turbo lag, you can practically feel the power from 1000 rpm
  • #8 9405146
  • #9 9406016
  • #10 9406416
    macvir
    Help: 32
    Rate: 262
    and if we are talking about EGR, for example Fiats 1.3jtd / cdti have EGR combined with a cooling system (liquid).
    Is it possible to control the EGR in the above-mentioned engine so that it heats up the liquid faster? I mean especially the winter, when the hint of the temperature does not even give a special subtlety.
  • #11 9407515
    Piotr36
    Help: 16
    Rate: 57
    Hello, I have been driving a Mondeo 1.8TD from 1996 for 6 years. It was muddy and sometimes it drowned heavily, after blinding the EGR, the car gained power and does not smoke like it used to - well, unless you hit the floor, like every diesel has to spit it out somewhere. :wink:
    I think that in older cars, EGR only hurts.
    Greetings.
  • #12 9407796
    kidu22
    Help: 150
    Rate: 740
    EGR is replaced or repaired in diesels and not blind.
    Firstly, on a cold engine, the intake air is heated quickly with exhaust gases, secondly, exhaust gases are not corrosive to the eyes and nose, and thirdly, the engine heats up faster.
    Blind the EGR and you will see the cold engine limping right after firing in the winter.
    Now, someone introduce at least 1 plus blinding.
  • #13 9407824
    janusz2008
    Help: 170
    Rate: 515
    There is not a single plus, and in newer years it is impossible.
  • #14 9408365
    gregorianin
    Help: 44
    Rate: 294
    (up to 2 speakers) In winter, when the engine (depending on which one) is very cold (usually below -15), the EGR is closed so that the fuel burns in the best possible conditions, which are difficult anyway, and opens later as it warms up. It causes faster heating in medium temperature ranges, but it is not conducive to ECONOMY because it limits the amount of oxygen in the chamber. Someone will ask what the difference, it is diesel and we always have excess air, even how EGR works - yes, but when we have a lot of inert filler and oxygen mixed between it, combustion can (and usually does) drag on too much.
    An engine with closed EGR will have a higher combustion temperature, which is normal but not harmful. Basically, it is about lowering this temperature not to protect the engine but the environment (NOx compounds precipitate at high temperatures) and only because - when we limit the oxygen, the efficiency suffers, as I mentioned earlier. On the other hand, the closed EGR valve is all exhaust gas directed into the exhaust and through the turbine by the way, it causes higher revolutions of the turbine already at idle speed and when driving at partial loads, it gives a clear increase in dynamics (faster pressure increase) and response to gas due to increased MAF but of course, the maximum power has absolutely no influence because the EGR at such moments closes if it works properly.
    Lack of EGR work means the lack of soot in the manifold, which binds so beautifully with the oil and creates a clogging "korzuszek".
    It is also possible to discuss the positive effect on the operation of the DPF filter engine.
  • #15 9408444
    autoas
    Help: 571
    Rate: 3924
    I propose to throw out the EGRs, catalysts, diesel particulate filters, accelerate the ignition, screw lambda probes into the side pipes, insert all emulators for everything, resistors and cheats and it will be a git ......
  • #16 9408499
    janusz2008
    Help: 170
    Rate: 515
    It's like going back in time and going back to "Trabant", a guaranteed allergy.
The discussion revolves around the pros and cons of blinding the Exhaust Gas Recirculation (EGR) valve in vehicles. Participants express divided opinions on the impact of EGR blinding, noting that while it may enhance engine performance and reduce soot accumulation in the intake manifold, it can also lead to higher combustion temperatures and potential engine management issues, particularly in newer models. Some users report improved power and reduced smoke in older vehicles post-EGR blinding, while others caution against it due to risks of triggering error codes and affecting engine efficiency. The conversation highlights the importance of understanding vehicle-specific EGR functionality and the implications of modifications on engine performance and emissions.
