no required cd / dvd device driver for windows 7 installation
dzedaj2000 7443 9
How can I install Windows 7 on an HP Envy x360 when the installer does not see the USB flash drive and the laptop has no DVD drive?
You need to add USB 3.0 support to the Windows 7 installation media, because the WinPE image probably does not contain drivers for the laptop’s USB controller [#16275188] The HP Envy x360 appears to have only USB 3.0 ports, so simply changing ports will not help [#16275179] Use the Windows 7 USB 3.0 Creator Utility to prepare the installer, or integrate the USB 3.0 drivers into the setup image as described in the linked guides [#16275534][#16275179] The forum advice is to use the Creator Utility rather than trying to load loose files during setup [#16277158] If you need to do it manually, the driver package must contain the proper INF files for integration [#16275228]
  • #1 16275077
    dzedaj2000
    Rate: 37
    Hello. I currently have windows 10 and I want to go to 7 because the processor and disk usage is 100 and often muli.
    Installs from pendriva because the laptop does not have a drive. The picture of Windows is definitely good because it was installed on other computers. Changing the USB ports also did not give anything. The bios is current and there is no option to change the IDE emulation mode to AHCI.
    I've never had such problems.
    The laptop's model
    HP ENVY x360 - 15-w151nw (ENERGY STAR).
    I read about it but none of the solutions given to my problem resulted in any results. Please help
  • #2 16275179
    Matuzalem
    Help: 1653
    Rate: 1100
    These "other computers" were from USB 3.0 and the system was installed from them? If you do not have information about them and the fact that you did "change USB ports" does not bring much (the specification indicates the presence of only 3.0).
    The possibilities described here: https://www.elektroda.pl/rtvforum/topic3149076.html - the one from post number 18 also - did you check too?
    Ew. you can use here: http://dyski.cdrinfo.pl/artykuly/dodanie-sterownikow-do-instalki-windows/ described the method of driver integration (for USB 3.0).
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #3 16275188
    sylweksylwina
    Help: 1882
    Rate: 2355
    The WinPE image probably does not contain drivers for your USB controller. What does 100% of the processor use?
  • #4 16275228
    dzedaj2000
    Rate: 37
    The first option is off. As for the second I was thinking about throwing the driver under 3.0 on the pendriva loosely and then at the message manually indicate the location of the driver only everything I found were the files installation and not inf.
  • #6 16277152
    dzedaj2000
    Rate: 37
    Regarding the driver, can it be exe. or with inf
  • #7 16277158
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Use the Windows 7 * USB 3.0 Creator Utility and do not think about it, because you probably do not know what you are doing at all.
  • #8 16277206
    dzedaj2000
    Rate: 37
    I know what I'm doing, my friend's way above. New ISOs are just being saved. How good a driver will go.
    Or maybe a bit more polite? I do not know, I'm asking. Drivers can be installed in several ways, but not everything can be found everywhere.
  • #9 16277628
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    I see what you write and only state the fact, there is nothing naughty about it.
    You've got links and you should not just ask to read and understand them.
  • #10 16301711
    dzedaj2000
    Rate: 37
    Touch did not work. I installed 10 x64 because x32 no drivers.
The discussion revolves around the challenges faced by a user attempting to install Windows 7 on an HP ENVY x360 - 15-w151nw laptop, which lacks a CD/DVD drive. The user is experiencing issues with USB installation, as the laptop's USB ports are 3.0 and may not have the necessary drivers for the installation media. Suggestions include integrating USB 3.0 drivers into the installation media and using the Windows 7 USB 3.0 Creator Utility. The user also inquires about the types of driver files needed for installation, indicating a need for .inf files rather than executable installers. The conversation highlights the importance of ensuring the installation media is compatible with the hardware specifications of the laptop.
