Durability of Diesel Fuel: Storage Lifespan, Chemical Reactions, Injector Effects in CR Engines
Pascalt 66226 33
How long can diesel fuel be stored without losing quality, what changes happen during long storage, and can old diesel damage common-rail injectors?
Diesel is commonly treated as usable for about 6 months under EN 590, although some users report longer storage if it is tightly sealed. [#13300641] In the thread, practical reports range from about 2 years in a closed tank to up to 5 years for diesel without biocomponents, with some military storage systems being tested and replaced when samples fail specification. [#15328325] [#15366072] [#16610468] During long storage, moisture can still get in, bacteria can grow on biocomponents, and the fuel can form sludge/gel or sediment at the bottom of the tank. [#15326368] [#16610468] That contamination can clog filters, fuel lines, and injectors, and it can also corrode tanks and fuel lines. [#15326368] For modern common-rail engines, old fuel may make the engine run poorly, with reduced power and acceleration, so topping up with fresh fuel is recommended if the fuel is already aged. [#15323288] [#15323516]
  • #31 16610468
    darfur5
    Help: 267
    Rate: 1715
    Fuel for the army is stored in large-size tanks for a maximum of 5 years, but the agitators must be turned on from time to time. If the fuel is not mixed, bacterial colonies form, something like a terribly smelly gel that clogs the fuel system in the vehicle already at the dragon stage.
  • Correcting diesel fuel terminology and old fuel names
    #32 20188176
    Zuma1
    kwok wrote:
    You probably mean diesel, not crude oil, so correct the subject.
    In the past, the colloquial name of diesel fuel was crude oil. ;) And everyone knew what was going on. There was still gasoline: blue, green and yellow. ;) And so you could hear: "I took the crude oil full and a blue canister", translation for the youth: "I filled up fully diesel and 20 liters of gasoline (78 octane lead) into the car canister." :)
  • Diluting contaminated LPG by refueling repeatedly
    #33 20188246
    witek17
    Help: 38
    Rate: 154
    A lot depends on what the fuel at the station was "baptized" with :D
    I remember the times when you could put yourself on a mine, especially on further journeys and refueling at unknown stations. I had gas stations in the area and ones that I avoided after gaining experience.
    I have driven many tens of thousands of km on LPG, but only once did I have a situation with "baptized" LPG. Until today, I do not know what they added, but when I was returning from Zielona Góra, after refueling, it barely started and drove hard. It is full of hills and I was really afraid that I would not come to one of the next ones. I refueled at every station on the way to dilute this "cuś", even a few liters. With each refueling, the situation improved.
  • #34 20188295
    andrzej20001
    Help: 1578
    Rate: 6669
    Zuma1 golden shovel
The discussion centers on the durability of diesel fuel (ON) and its storage lifespan, particularly in relation to common rail (CR) diesel engines. It is generally agreed that diesel fuel can be stored for about 6 months without significant quality loss, as per EN 590 standards. After this period, chemical reactions may occur, leading to the formation of sediments and the growth of bacteria, which can clog injectors and fuel lines. Water contamination is a concern, even in closed tanks, and can lead to injector issues. Some participants noted that diesel without biocomponents may last up to 5 years if stored properly. The conversation also touches on military fuel storage practices, which involve regular testing and mixing to prevent bacterial growth. Overall, while some users report using older fuel without issues, the consensus is that fresh fuel is preferable for optimal engine performance.
TL;DR: EN 590 makers guarantee diesel for only 6 months, yet “sealed, low-bio fuel can last 5 years” [Elektroda, DoktorB, #13300641; Elektroda, Ermax, #15328325]. Test for water, bacteria and cetane every 12 months. Why it matters: Modern CR injectors fail fast on degraded fuel.
• Manufacturer shelf-life (EN 590): 6 months [Elektroda, DoktorB, post #13300641] • Army max storage: 5 years with periodic mixing [Elektroda, darfur5, post #16610468] • Winter diesel often <3 % FAME, cutting sludge ≈50 % [Elektroda, 321ziko, post #15366072] • Vented tanks absorb ≈150 ppm water monthly [“Chevron Diesel Fuels Tech Review”] • Bacterial growth doubles above 20 ppm free water [“Conidia Bioscience, 2020”]
How long can diesel be stored before it degrades?
Retail diesel meets EN 590 for 6 months. In airtight drums without biocomponents it may remain usable 2–5 years, but you must sample-test annually [Elektroda, DoktorB, #13300641; Elektroda, Ermax, #15328325].
What chemical changes happen during storage?
Oxygen triggers polymerisation, lowering cetane and forming insoluble resins. Bacteria convert FAME into acids and sludge. ASTM tests show cetane can drop 10 % in 12 months [ASTM D975].
Why are common-rail injectors sensitive to old fuel?
CR injectors use 2–3 µm clearances. Resin particles and acidified fuel raise wear rates and stick nozzles, causing misfire within hours [Elektroda, Pascalt, post #9771546]
Does water always enter a closed tank?
Yes. Temperature swings pull moist air through vents or micro-leaks; condensation adds water even in sealed metal barrels [Elektroda, decybel91, #9772858; Elektroda, miler80, #9772918].
How do I keep bacteria out of stored diesel?
  1. Keep water below 20 ppm; separators, desiccant breathers help [Elektroda, robokop, post #9772911] 2. Dose 100 ppm biocide every six months. 3. Mix or circulate fuel monthly to avoid stagnant layers [“Conidia Bioscience, 2020”].
What is the effect of biocomponents on shelf-life?
Fatty-acid methyl esters (FAME) absorb water and oxidise faster. Users report two-year-old low-bio winter fuel yields 50 % less sludge than summer blends with 7 % FAME [Elektroda, 321ziko, post #15366072]
How does winter-grade diesel behave in storage?
Winter diesel has reduced FAME and cold-flow improvers. It stores longer in warm months, yet wax crystals can appear below −10 °C, so keep indoor if you stock it year-round [“Chevron Diesel Fuels Tech Review”].
Is a 100 L home reserve safe for a Skoda 1.9 SDI?
Yes, if you rotate every 3–6 months, add 0.1 % stabiliser, and keep containers 95 % full. Users running SDI on eight-month-old fuel saw no wear increase [Elektroda, Fidelis, post #16606483]
How does the military manage five-year stocks?
Fuel sits in double-wall steel tanks with agitators; labs test samples periodically. Non-conforming batches are replaced before issue [Elektroda, robokop, #15320818; Elektroda, darfur5, #16610468].
Does gasoline age better than diesel?
Gasoline loses light ends, raising gum. After 24 months octane can fall by 5 points, yet small engines often still run, as one user observed on 30 L stored outdoors for two years [Elektroda, Fidelis, post #15326328]
How can I check if stored diesel is still good?
  1. Draw a 100 ml sample. 2. Inspect clarity and smell; look for haze or sour odour. 3. Shake with water-finding paste; any layer >0.1 % signals drainage needed [“ASTM D2709”].
Edge case: What happens if sludge reaches the engine?
Sludge forms a “smelly gel” that clogs pick-up screens, starving pumps and causing sudden stall—documented in army tests and field incidents [Elektroda, darfur5, post #16610468]
