Durability of Diesel Fuel: Storage Lifespan, Chemical Reactions, Injector Effects in CR Engines
Pascalt 65581 33
How long can diesel fuel be stored without losing quality, what changes happen during long storage, and can old diesel damage common-rail injectors?
Diesel is commonly treated as usable for about 6 months under EN 590, although some users report longer storage if it is tightly sealed. [#13300641] In the thread, practical reports range from about 2 years in a closed tank to up to 5 years for diesel without biocomponents, with some military storage systems being tested and replaced when samples fail specification. [#15328325] [#15366072] [#16610468] During long storage, moisture can still get in, bacteria can grow on biocomponents, and the fuel can form sludge/gel or sediment at the bottom of the tank. [#15326368] [#16610468] That contamination can clog filters, fuel lines, and injectors, and it can also corrode tanks and fuel lines. [#15326368] For modern common-rail engines, old fuel may make the engine run poorly, with reduced power and acceleration, so topping up with fresh fuel is recommended if the fuel is already aged. [#15323288] [#15323516]
  • #1 9771546
    Pascalt
    Help: 9
    Rate: 143
    question about the durability of diesel fuel. How many years of ON can be stored without loss of quality, what happens after long storage (chemical reactions, precipitation of ingredients, etc.)?
    The injectors are probably the most exposed to too poor quality (old) diesel fuel - electric injectors, of course. ON will be used in modern diesel engines with CR injectors and a turbine.
    kwok
    Level 40  
    Help: 493
    Rate: 1336
    You probably mean diesel, not crude oil, so correct the subject.
    On the subject, if you want to pour old CR diesel fuel, I do not predict a long mileage of this diesel engine.
    I just don't know how long the ropka has matured - probably a few months so it will go to the old clatter, but I would rather not pour the new one.
    decybel91
    Help: 1021
    Rate: 4211
    After about 3 months, a good amount of water is removed from such oil.
    robokop
    Help: 1763
    Rate: 6360
    decibel 91 Explain to me, how is that? If the vessel is closed, it can stand - after a few years of ethylene, there was sediment, and after ON, I did not notice anything disturbing after a year or two in the tanks.
  • #5 9772858
    decybel91
    Help: 1021
    Rate: 4211
    Moisture will always get into even a closed tank.
  • #6 9772911
    robokop
    Help: 1763
    Rate: 6360
    That's why you have separators in the filters.
    Anyway, what are you talking about - ask someone who has dealt with tanks at petrol stations, he will tell you how much water is in them.
  • #7 9772918
    miler80
    Help: 272
    Rate: 1393
    Especially as it is stored in a metal tank.
  • #8 9773615
    Pascalt
    Help: 9
    Rate: 143
    Since water, the injectors will not get the most, as it seems to me - the water is not compressed to a large extent.
    According to what you write - diesel fuel stored for 3 years in a metal barrel would not be usable anymore.
  • #9 13300641
    DoktorB
    Rate: 85
    ON durability is 6 months (manufacturer's warranty for meeting the requirements of EN 590).
  • #10 13302538
    Alfred_92
    Help: 148
    Rate: 705
    After all, there will be small amounts of this water, not liters, so the presence of such an amount of water in the combustion chamber will not be noticeable.
    Just out of curiosity, the water in the combustion chamber turns into a water jet under the influence of temperature and facilitates even distribution of the mixture in the cylinder in order to obtain an even temperature distribution. Such solutions are used in marine engines by using separate water / steam injectors or by using dual-function injectors.
  • #12 15320524
    Fidelis
    Rate: 140
    I wonder what the army stores? I assume industrial quantities.
  • #13 15320566
    robokop
    Help: 1763
    Rate: 6360
    Theoretically, every specified period should be tested for physicochemical changes in the content and replaced. A ekhmmm is stored. War stocks in the so-called bunkers - in unified standard 200l barrels, ready for distribution to vehicles, and larger amounts "for later" in steel underground tanks. Such a tank has probably two layers of steel, plus a bitumen coating on the outside.
  • #14 15320580
    Fidelis
    Rate: 140
    I am more interested in the composition / quality of ON stored by the army.
    Somehow I find it hard to believe that in these warehouses the fuel is changed after 6 months.
  • #15 15320818
    robokop
    Help: 1763
    Rate: 6360
    There is such a thing as the Research and Development Center of the MPS Service, which examines the stored fuels and lubricants. If the delivered sample is classified as non-compliant, the fuel in the tank is replaced. And this is not only diesel and gasoline - aviation fuel, kerosene, a whole range of lubricants (i.e. greases and oils).
  • #16 15322617
    Fidelis
    Rate: 140
    After what time in practice are the fuels (gasoline or diesel) replaced? Does the fuel have these critical biocomponents?
  • #17 15323288
    manta
    Help: 463
    Rate: 1533
    The fuel is not changed, and chemical changes, especially in the case of military vehicles, are not a problem. Most vehicles have multi-fuel engines. So they can be powered by everything that is burning, the issue of generated power remains. Most vessels try to use the stored fuel when maneuvering, adding fresh fuel as a supplement.
    As for civilian engines, they have much higher quality requirements. Here, unfortunately, the manufacturer actually specifies the durability for six months. I often run cars on fuel older than this period and I must say that the engines are not working properly. Topping up fresh will improve the situation considerably.
  • #18 15323426
    Fidelis
    Rate: 140
    I heard that one of the tank models (T-55?) Can be flooded with completely unrefined oil. I don't know how much truth there is.
    It occurred to me to "buffer" 80-100l ON for 1.9 SDI (Skoda). And I wonder if it is safe ... I mean, will I not hurt the engine (although simple in design). Possibly until when maximally (as successively) this "buffer" use / replace. If I was consistent (i.e. not lazy), the buffer would be replaced after (up) 3 months.
    manta wrote:
    here, unfortunately, the manufacturer actually specifies the durability for six months
    The question is, where does this requirement come from? Due to admixtures of biocomponents versus established by the standard "quality requirements"? Because maybe it is just a whim ordered by the producers by the all-powerful one of those looking to justify their existence by the EU commission?
  • #19 15323516
    manta
    Help: 463
    Rate: 1533
    Read the last sentence of my post, I don't know if it's about bio, but what I wrote comes from practice. SDI will work, but will it work normally? It will light, it will go, power and acceleration ... like a medicine. For this unknown changes in the injection system ...
  • #20 15323541
    Fidelis
    Rate: 140
    It's SDI. So the wife has power and acceleration for medicine and fresh fuel :-) Does not complain.
    OKAY. Of course. You wrote a sentence earlier about the used fuel OLDER than 6 months ;-)
  • #21 15326282
    Stermotorzysta
    Rate: 125
    Maybe not exactly what the topic is, but I think it's worth it.
    We had a case that after a summer break (about 4 months) the burner of the central heating boiler in the company did not want to light - despite cleaning, changing the filter, the nozzle did not light. Only after replacing the fuel oil in the tanks with the "new" burner, the burner fired. The company that supplies the oil stated that it is best to store such oil for a maximum of 3 months ... ;) Looking at the oils in the tanks, they did not differ completely from each other ...
  • #22 15326328
    Fidelis
    Rate: 140
    Interesting ... maybe I was lucky that for two years, "without failure" I used a 30l tank of gasoline (regular 95k) in a generator exposed to frost and heat. Without refilling the fuel, adding any "improvers" or mixing with fresh fuel.
  • #23 15326368
    andrzej20001
    Help: 1574
    Rate: 6648
    After all, it is home to bacteria which a nice mushroom can effectively clog the siti at the pump / dragon inlet in the tank. I wonder how they fight it in the ministry?
    https://www.google.pl/search?q=bakterie+w+on&...AzAOIjqOYBw#q=bakterie+w+oleju+nap%C4%99dowym
    The development of microorganisms in fuel systems causes a number of processes that adversely affect the power systems and the quality of the fuel in them. These include: clogging of filters and fuel lines, blockage of injectors, corrosion of the tank and fuel lines, decomposition of hydrocarbons and additives, increase in the content of water and sulfur in the fuel, formation of deposits and suspended solids in the fuel, and the production of surfactants causing emulsification of the fuel . The occurrence of these phenomena results in a decrease in engine efficiency and greater wear of its components.
  • #24 15328325
    Ermax
    Rate: 17
    Easy, if it is tightly closed, it can be safe for 2 years. As for the mixing of diesel or gasoline with water, I recommend going back to primary school for Physics / Chemistry and not to shit such nonsense. When it comes to nap. of course, the one that does not contain biocomponents is definitely better and can be aged for up to 5 years (it does not become cloudy and no "sticky" precipitates). So, buddy, if you have a clean, greasy diesel, it's funnel and don't worry ...
  • #25 15366072
    321ziko
    Rate: 12
    For several years I have been buying diesel in winter as a reserve for the whole year for vehicles with Common Rail. I have noticed that in two years there is less sediment in a form similar to chocolate pudding. The reason for the lower amount of sludge is the reduced or lack of bio additives in the winter due to the large number of complaints from transport companies for winter fuels. I have the information from an employee of the fuel company.
  • #26 15379900
    Fidelis
    Rate: 140
    On the filter? At the bottom of the tank?
  • #27 15381598
    321ziko
    Rate: 12
    At the bottom of the 1000-liter tank, 8 months after the purchase (gas station purchase), I start using the fuel. It digs 3 thousand liters annually.
  • #28 16605904
    stasiekb100
    Help: 118
    Rate: 454
    Gasoline may not age so much and paraffin does not precipitate out of it. He's only fresh, old, worth nothing, you can light a fire in the furnace. The old one smokes 1.5 times more and there are still problems with the injectors.
  • #29 16606483
    Fidelis
    Rate: 140
    stasiekb100 wrote:
    Gasoline may not age that much ,,. ,,
    I don't know if it's a matter of aging, but out of the 6 plastic canisters (20L), 2 were noticeably swollen. It turned out that the vapor under pressure had collected (unlike the others). A puzzle, because the fuel was bought at the same petrol station at different times ...
    stasiekb100 wrote:
    He's just fresh, old worth nothing ...
    What does "fresh" mean and where does this conclusion come from?
    I use about 8-9 months of diesel fuel and I do not see ANY difference, also in the degree of wear (SDI engine). But without exaggerating with smoking in the fire ...
  • #30 16606755
    stasiekb100
    Help: 118
    Rate: 454
    Maybe you get a better one. It also depends on how it is stored, i.e. stored at a constant temperature, mixed, without exposure to frost. You buy a winter one and use it in summer. I bought it in late autumn, everything was fine at first, but by spring the car was burning from 6.5 out of 100 to 10 out of 100 and it stopped working on one cylinder (it just passed the same).
✨ The discussion centers on the durability of diesel fuel (ON) and its storage lifespan, particularly in relation to common rail (CR) diesel engines. It is generally agreed that diesel fuel can be stored for about 6 months without significant quality loss, as per EN 590 standards. After this period, chemical reactions may occur, leading to the formation of sediments and the growth of bacteria, which can clog injectors and fuel lines. Water contamination is a concern, even in closed tanks, and can lead to injector issues. Some participants noted that diesel without biocomponents may last up to 5 years if stored properly. The conversation also touches on military fuel storage practices, which involve regular testing and mixing to prevent bacterial growth. Overall, while some users report using older fuel without issues, the consensus is that fresh fuel is preferable for optimal engine performance.
TL;DR: EN 590 makers guarantee diesel for only 6 months, yet “sealed, low-bio fuel can last 5 years” [Elektroda, DoktorB, #13300641; Elektroda, Ermax, #15328325]. Test for water, bacteria and cetane every 12 months. Why it matters: Modern CR injectors fail fast on degraded fuel.
• Manufacturer shelf-life (EN 590): 6 months [Elektroda, DoktorB, post #13300641] • Army max storage: 5 years with periodic mixing [Elektroda, darfur5, post #16610468] • Winter diesel often <3 % FAME, cutting sludge ≈50 % [Elektroda, 321ziko, post #15366072] • Vented tanks absorb ≈150 ppm water monthly [“Chevron Diesel Fuels Tech Review”] • Bacterial growth doubles above 20 ppm free water [“Conidia Bioscience, 2020”]
How long can diesel be stored before it degrades?
Retail diesel meets EN 590 for 6 months. In airtight drums without biocomponents it may remain usable 2–5 years, but you must sample-test annually [Elektroda, DoktorB, #13300641; Elektroda, Ermax, #15328325].
What chemical changes happen during storage?
Oxygen triggers polymerisation, lowering cetane and forming insoluble resins. Bacteria convert FAME into acids and sludge. ASTM tests show cetane can drop 10 % in 12 months [ASTM D975].
Why are common-rail injectors sensitive to old fuel?
CR injectors use 2–3 µm clearances. Resin particles and acidified fuel raise wear rates and stick nozzles, causing misfire within hours [Elektroda, Pascalt, post #9771546]
Does water always enter a closed tank?
Yes. Temperature swings pull moist air through vents or micro-leaks; condensation adds water even in sealed metal barrels [Elektroda, decybel91, #9772858; Elektroda, miler80, #9772918].
How do I keep bacteria out of stored diesel?
  1. Keep water below 20 ppm; separators, desiccant breathers help [Elektroda, robokop, post #9772911] 2. Dose 100 ppm biocide every six months. 3. Mix or circulate fuel monthly to avoid stagnant layers [“Conidia Bioscience, 2020”].
What is the effect of biocomponents on shelf-life?
Fatty-acid methyl esters (FAME) absorb water and oxidise faster. Users report two-year-old low-bio winter fuel yields 50 % less sludge than summer blends with 7 % FAME [Elektroda, 321ziko, post #15366072]
How does winter-grade diesel behave in storage?
Winter diesel has reduced FAME and cold-flow improvers. It stores longer in warm months, yet wax crystals can appear below −10 °C, so keep indoor if you stock it year-round [“Chevron Diesel Fuels Tech Review”].
Is a 100 L home reserve safe for a Skoda 1.9 SDI?
Yes, if you rotate every 3–6 months, add 0.1 % stabiliser, and keep containers 95 % full. Users running SDI on eight-month-old fuel saw no wear increase [Elektroda, Fidelis, post #16606483]
How does the military manage five-year stocks?
Fuel sits in double-wall steel tanks with agitators; labs test samples periodically. Non-conforming batches are replaced before issue [Elektroda, robokop, #15320818; Elektroda, darfur5, #16610468].
Does gasoline age better than diesel?
Gasoline loses light ends, raising gum. After 24 months octane can fall by 5 points, yet small engines often still run, as one user observed on 30 L stored outdoors for two years [Elektroda, Fidelis, post #15326328]
How can I check if stored diesel is still good?
  1. Draw a 100 ml sample. 2. Inspect clarity and smell; look for haze or sour odour. 3. Shake with water-finding paste; any layer >0.1 % signals drainage needed [“ASTM D2709”].
Edge case: What happens if sludge reaches the engine?
Sludge forms a “smelly gel” that clogs pick-up screens, starving pumps and causing sudden stall—documented in army tests and field incidents [Elektroda, darfur5, post #16610468]
