Water Leak from 9-Year-Old Stove: Fixable Fault or Time for Replacement?
Gaj777 56887 6
  • #1 9882956
    Gaj777
    Water started leaking from the stove (it stopped only after draining the water). What could be the reason for this fault and is it a minor issue that needs to be fixed, or is it more serious and it is better to replace the stove (it is already 9 years old and long out of warranty)?
  • #2 9883000
    Piotr Pajkert
    Level 32  
    Help: 165
    Rate: 141
    Hello!
    I will say this. There was a stove manufactured in Pleszew. After 3 years of connection, it started leaking. The service came and welded the body around the door. After another 2 years it started leaking. Call Pleszew - they will come and repair it for a fee. I gave up and asked a welder friend of mine. He welded a piece of sheet metal to the lower, rusted part of the stove. After 1 year it started leaking again. I bought a new furnace. I leave the conclusions to you.
    Hi!
  • #3 9883003
    stanislaw1954
    Help: 2013
    Rate: 4675
    If you write
    Gaj777 wrote:
    (only after draining the water did it stop).
    this means that you have a leak (hole) in the furnace. If you manage to locate it, you can try to weld it if it is available.
  • #4 9883009
  • #5 9883013
  • #6 9883111
    kreslarz
    Help: 317
    Rate: 460
    Dude, when the water is gone, it usually stops leaking.
    After 10 years of operation, there is no point in patching, because, as my colleagues said above, it is a repair for a season or less. This will be especially troublesome when, after repair (welding), the boiler shows further defects at e.g. -15 degrees Celsius outside. . Every boiler, even a branded one, will require replacement after some time due to corrosion, just like a car. Corrosion is a ubiquitous phenomenon and there is no solution for it. The central heating boiler is particularly exposed to this phenomenon due to the influence of the thermal factor.
    All that remains is to look at the offers and buy a new boiler. The next 10 years will be (theoretically) peaceful.
    When purchasing, pay attention to:
    - length of the manufacturer`s warranty on the tightness of the boiler
    - thickness of the sheet metal used to construct the boiler
    - certificates for the sheet metal used (if it comes from beyond the eastern border, avoid it like the plague)
    - online opinions about the manufacturer and its products
    - technical conditions specified (sometimes) in the warranty that must be met by the user in order for warranty claims to be valid. There are very different provisions here, so you need to read carefully. This sometimes concerns water hardness, boiler temperature (if it is too low, internal moisture in the boiler, sulfur exposure, etc.) and other types of bad fuel (for eco-pea coal boilers). Generally, everyone wants to sell, praising their product, and then they try to avoid warranty liability as much as possible.
  • #7 9883288
    Sokrat58
    Level 19  
    Help: 19
    Rate: 65
    I also advise you to delve into the problem of the water grate, which is quite important both for the durability of the stove and for saving fuel.
Water leakage from a 9-year-old stove may indicate a serious issue, potentially due to rust or a hole in the furnace. Users suggest inspecting the leak's source and considering welding repairs if feasible. However, given the age of the stove, many recommend replacement rather than patching, as repairs may only provide temporary solutions. Factors to consider when purchasing a new stove include the manufacturer's warranty, the thickness of the sheet metal, and the quality of materials used to prevent corrosion. Additionally, attention should be paid to the water grate for durability and fuel efficiency.
