WORCESTER 24i Stove Gas Issue: Water Leak, Electro Valve Release, Sealed System Recovery
miro2207 8901 5
  • #1 16445093
    miro2207
    I have a problem with the WORCESTER 24i stove that doesn't let gas go. There was a leak in the water system and water was leaking. The stove went a little without water and when I sealed the system would not turn on. As if the electro valve would not release gas. I would like to ask what could have happened? Maybe someone will help something. greetings
  • #2 16445249
    serwisszulborski.pl
    Heating systems specialist
    Help: 360
    Rate: 1448
    There are many of these models and they differ depending on the year, so it is difficult to advise. You need to check the security. Check whether there is no reset on the thermal protection e.g. of a button. In one of the models there was one on the left from the top (I don't remember if there was a nut) ... Today I was in an emergency at Worcester but there was a usual temperature limiter without reset ... Yesterday I also had a Worcester and there was also a circuit water level sensor ... Check the protections for signal transitions. Next check whether the pump impeller is loose or turning.
  • #3 16445327
    miro2207
    Hello. And you could give me an e-mail, I would send you pictures of this furnace that I have.
    Or maybe you live somewhere near Kołobrzeg, maybe you would come and try to fix it.
  • #4 16445365
    Matheu
    Help: 61
    Rate: 305
    [Miro2207] : If you went to some trouble, you would see in profile data [serwisszulborski.pl] city:
    Olsztyn
  • #5 17101772
    Loka22
    Hello, I also have a problem with the worcester 24i stove, as above, I had a water leak and after removing the fault, the stove does not turn on the gas supply, the blue window is not lit in a small window. I ask for advice
  • #6 17102355
    serwisszulborski.pl
    Help: 360
    Rate: 1448
    Reset on thermal protection from the left side of the boiler at the top.
