Selecting Backlit Magnifier for SMD Soldering: Comparing 5 Diopters vs 8 Diopters Options
saly 63135 40
How many diopters should I choose for a backlit magnifier for soldering regular SMD parts?
For regular SMD soldering, 5 diopters is usually enough; 8 diopters is stronger, but it distorts the image more and leaves less working distance, so it is less comfortable for soldering [#10012063][#9944033] 5 diopters are described as an auxiliary loupe for low-precision work, while 8 diopters are more suitable for inspections than for precise soldering [#9944033] For precise previewing or very small SMD work, the thread recommends a microscope instead of a simple magnifier [#9944033] If you choose a loupe, it is better to have the largest possible lens area, because higher power usually means a thicker/smaller lens and more distortion [#10012063][#14254551]
  • #1 9940491
    saly
    Level 32  
    Help: 89
    Rate: 1003
    I want to buy a backlit magnifier and I don't know how many diopters to choose?
    I need a regular SMD for soldering.
    I don't know if 5 diopters are enough or 8 diopters is better, but is it sometimes not too much? Until now, I was able to do without a magnifying glass, but you know the eyes are not the same.
    What are you in your workshops?
  • #2 9940790
    tomybb
    Rate: 1794
    I have a 10x magnifying glass - it's useful, sometimes I also use a 20x microscope, such a combination is enough for me - the microscope also has a 40x - I rarely use it, but also useful - it would be better than not. Overall, it seems to me that magnification depends on individual needs.
  • #3 9944033
    serwis
    Level 37  
    Help: 334
    Rate: 268
    saly wrote:
    I don't know if 5 diopters are enough or 8 diopters are better
    5 diopters are only 2.25x - as an auxiliary for low-precision work.
    8 diopters are 2.95x - sometimes enough for inaccurate inspections.
    However, in order to precisely preview, solder or perform other works, unfortunately a microscope is necessary.
    A typical workshop, such as the XTLIV with a basic 10 to 35x magnification, perfectly meets these requirements.
    Moreover, it has a very large working space - so that the work is pure pleasure.
  • #4 9944571
    saly
    Level 32  
    Help: 89
    Rate: 1003
    Ok thanks guys I have, I can see that I will have to look for something stronger.
    Thanks for the hints.
  • #5 9963407
    tomybb
    Rate: 1794
    It is a pity that this XTL-IV is so expensive.
  • #6 9963574
    serwis
    Level 37  
    Help: 334
    Rate: 268
    You're kidding, of course :D
    It is the cheapest microscope in its class.
    Price with additional glasses 20x + USB webcam = PLN 1250.
    You won't buy anything cheaper.
    Of course, new, but you can also "track" used, much cheaper.
  • #7 9963613
    LoLek85
    Help: 86
    Rate: 303
    My colleague was probably not about comparing the price of the microscope to the price of another, but to the price of a nice one, because if someone uses such things as a hobby, it's rather hard to jump out of the PLN 1250 just to use it occasionally, although working with such equipment is much more pleasant .
  • #8 9963911
    saly
    Level 32  
    Help: 89
    Rate: 1003
    I think that a magnifying glass is enough for me, I do not work with smd on phones or laptops with a very small raster, I have a car electronics workshop. Smd with which I work are mainly car controllers, meters, sensors modules, 0.8; 0.65. So far I can do it with the naked eye, but the years are flying and I wanted to make it easier for myself. I bought an 8dptr lupe and it's ok.
    When I need to look closely at something, I use the Turist 4 (10x30) telescope rotated to the distance, after applying it up close, it magnifies a lot and allows me to assess the situation, but a magnifier is better for work.
  • #9 10012063
    ^ToM^
    Help: 495
    Rate: 2939
    5dp is enough. More power = thicker lens and it will be worse for you to work because it distorts the image more. Generally, a 2-fold magnification, i.e. 5dp, will be enough for soldering. Better to choose a rectangular glass area as large as possible.
  • #10 10012989
    gilus1
    Help: 111
    Rate: 241
    2.5x is enough for soldering, but to check if there is any tiny break, short circuit or excessive etching somewhere, a 10x magnification is useful.
    As an interesting fact, thanks to the 10x magnifying glass I found out that a cat's hair can have several colors, of course, 1-color predominate.
  • #11 10193457
    jozek_d
    Help: 14
    Rate: 43
    How is it actually with this magnification?
    They write on the magnifying glass, for example, 10x magnifies up to 3 times.
    How do I recognize when I am dealing with diopters and when I am dealing with the magnification factor?
    What is the conversion factor of diopter to magnification factor?
    I am going to buy optics, but after today's inspection in stores where I have not found anything right, I am looking for an allegro, but I do not know how to understand the description, e.g. 30x21mm
    From what I watched in stores today, it will definitely not be a 30-fold magnification. So what?
  • #12 10195929
    saly
    Level 32  
    Help: 89
    Rate: 1003
    Diopter is the lens parameter, D = 1 / meter. It cannot be easily converted into a magnification factor. I remember that we counted on physics and drew such drawings of the lens and determined the magnification using the graphical method.
  • #13 10197564
    jozek_d
    Help: 14
    Rate: 43
    I found an interesting calculator for lenses.
    Converting diopter to focal length and vice versa, and calculating the magnification of the lens.
    Link
    It is enough to enter 1 in the "Maximum magnification of the objective" field and then the magnification of a single lens can be calculated.
  • #14 10199025
    kazimierzbrejta
    Help: 38
    Rate: 116
    Hello. The power of the lens is called the reciprocal of the focal length ? = 1 / f. Power is expressed in diopters. A lens with a power equal to 1 dpt has a focal length of 1 m. On the other hand, the magnification of the lens is G = 250 / f +1, where f is the focal length of the lens expressed in millimeters. If the lens has a power of, for example, 10 dpt, its focal length is equal to 100 mm, so the magnification of this lens will be 3.5x. Greetings.
  • #15 11798997
    AndrzejSanok
    I am also figuring out what to buy - and for the beginning I will go to the reading glasses store. They should be narrow so that you can easily see below or above. So there should be no problem reaching for a soldering iron or a meter. The highest magnification seems to be +4.5 dpi. For starters, it should be enough. If you put two lenses together, you should get pretty good magnification. Maybe someone has already experimented like that? And what is important, such glasses are on Allegro for PLN 5 together with the case.
  • #16 11802877
    Dar.El
    Help: 750
    Rate: 889
    You will burn your nose, unfortunately you will have to look very closely. From a distance, there are only such specialized loupes for surgeons, prices also for them.
  • #17 11803526
    AndrzejSanok
    I just bought +4 glasses because (glass height is about 20mm) for me +4 are pretty good, they don't tire the eye like a watchmaker's magnifying glass and you can easily look both above and below the glasses. I definitely recommend, sufficient magnification. I tried to put together 2x + 4, but the problem of a burned nose remains.
    I have a few damaged lenses so I will try to make some eyepiece with a higher magnification with a good field of view and illumination and no problem with a burned nose. Maybe someone has already tried?
  • #18 11804367
    Marek Poznan
    In my opinion, for imprecise works and elements up to 0402, I think that a magnifier up to 10x magnification should be enough. I personally use an ordinary table magnifier with backlight - it has 5x magnification, and for more precise things a Panasonic microscope up to x70 :)
  • #19 11804535
    AndrzejSanok
    I use and recommend the table magnifier, but unfortunately I will not take it outdoors. And the eyes are not those anymore. The microscope is out of my reach. I have no idea if there is any alternative. It's just a hobby.
  • #20 11804563
    Marek Poznan
    What do you mean terrain? There are also optical microscopes, you will find used ones at attractive prices :) If you want something in stock, I will send photos in my free time. If you want to do something outside your home, maybe a forehead magnifier, or some small loupes, you can often find such precise ones on a well-known auction site
  • #21 11825483
    AndrzejSanok
    Does anyone use the Leuchtturm microscope - PM3 microscope - pow. 20 - 40X for finding breaks in electronic circuits - is the price attractive?
  • #22 11827983
    Marek Poznan
    Consider the structure of this microscope. If you have different element heights, it may turn out that you will not get the zoom and the appropriate sharpness to all places. In my opinion, you should test such a microscope before you buy it, and it will not turn out that it will not meet your challenges and the money to be thrown away.
  • #23 12088106
    Mechanik21
    I am buying microscopes for my clients here
    Link
    All in all, it is not even profitable to import them from wholesalers.
  • #24 12089412
    tomiok
    Help: 133
    Rate: 292
    When working with electronics, it is also important, apart from magnification, that there is min. about 10 cm of space to be able to solder something under magnification, generally the more space the better.
    XTLIV - has min. working distance ;)
  • #25 12090345
    Mechanik21
    At a distance of 10 cm, a magnification of approximately 3.5X, i.e. 10 diopters, is obtained. The vast majority of loupes adapted for soldering have lower magnification and thus the gap between the lens and the soldered object is even greater.
  • #26 12090801
    tomiok
    Help: 133
    Rate: 292
    With an enlargement of about 20 cm I have a nice few cm, with an eye of 7-8, and it can be soldered at the same time :)
    Structurally almost the same.
    I will add that the stereoscopic view is a great advantage :)
    I miss the trino version (additional webcam).
  • #27 12123213
    Mechanik21
    If it is a magnifier then it is definitely not 20X magnification. At most, a Chinese could write that on the packaging ;)
  • #28 12123226
    tomiok
    Help: 133
    Rate: 292
    I wrote about the microscope, I have not seen stereoscopic magnifiers :)
  • #29 14254162
    mihail1
    Could somebody help me with magnifying booty? My grandfather is blind and uses two loot stacked on top of each other for reading, each with x5. I would like to buy him a newer one and I don't know what magnification would be good for him since he uses 2 X5s, does it add up somehow?
  • Diopter ratings often exaggerate actual magnification
    #30 14254551
    tomiok
    Help: 133
    Rate: 292
    Often given data - tan x5 magnification is exaggerated, and most often it is 5 doptria, only someone misspelled it, and this magnification is only 2.25x.
    3D (diopter) 1.75x
    5D (diopter) 2.25x
    8D (diopter) 2.75x
    It's best to take magnifiers and compare,
    I sent back many of them - because none of them was as described.
    It is worth remembering that: the greater the magnification of the magnifier, the smaller its diameter.
    I will paste from one description:
    "A simple magnifier, made of one lens, allows for a relatively low magnification of up to 7x (and only for small lenses, e.g. for watchmakers). Commonly used lenses have relatively large lenses and their magnification reaches up to 3x"
    NOTE: The actual magnification of a magnifier is often confused with its focusing power (optical power, given in diopters) - especially in goods manufactured in the so-called "Factory of the World"
    Of course, higher image magnifications are possible, but not in single-lens systems! Large magnification requires thick lenses, and then large image distortions appear - the greater the further we are from the optical axis. Only multi-lens systems allow for elimination or significant reduction of spherical and chromatic aberration, distortion and coma.
The discussion revolves around selecting a backlit magnifier for SMD soldering, focusing on the comparison between 5 diopters (2.25x magnification) and 8 diopters (2.95x magnification). Users share their experiences, indicating that while 5 diopters may suffice for general soldering tasks, 8 diopters or higher may be necessary for more precise work. Some participants recommend using a microscope for detailed inspections, particularly for small components. The XTLIV microscope is mentioned as a suitable option, although its price is noted as a concern. Users also discuss the importance of working distance and the potential distortion caused by higher magnifications. Various alternatives, including reading glasses and specialized loupes, are suggested for different needs and budgets.
TL;DR: 5-diopter lenses deliver a measured 2.25× magnification, “Magnification depends on individual needs” [Elektroda, tomybb, #9940790; Elektroda, serwis, #9944033]. 8 D raises detail to 2.95× but cuts working distance and boosts distortion.
Why it matters: Picking the right power keeps joints visible without burning your nose or your budget.
• 5 D ≈ 200 mm focal length → 2.25× view [Elektroda, serwis, post #9944033]
• 8 D ≈ 125 mm focal length → 2.95× view [Elektroda, serwis, post #9944033]
• 10 D at 100 mm working distance gives ≈ 3.5× view [Elektroda, Mechanik21, post #12090345]
• Lens diameter shrinks as power rises; >8 D lenses often <90 mm and show stronger edge distortion [Elektroda, tomiok, post #14254551]
• XTL-IV stereomicroscope: 10–35× zoom, ~100 mm clearance, PLN 1250 with camera [Elektroda, serwis, post #9963574]
Is 5 D (2.25×) sufficient for everyday SMD soldering?
Yes. Forum users report comfortably soldering 0.65–0.8 mm pitch with 5 D back-lit lamps [Elektroda, ^ToM^, #10012063; Elektroda, saly, #9963911]. 2–2.5× keeps the entire pad and tip in view and leaves space for tweezers.
When would I choose an 8 D magnifier instead?
Select 8 D when you inspect fine bridges, 0402 parts (1.0 × 0.5 mm) or ageing eyes struggle with 5 D detail. Expect 75 mm less clearance and stronger edge distortion [Elektroda, serwis, #9944033; Elektroda, tomiok, #14254551].
How does diopter affect working distance?
Working distance roughly equals focal length. 5 D gives ~200 mm, 8 D ~125 mm, 10 D ~100 mm [Elektroda, Mechanik21, post #12090345] More power pulls the lens closer, limiting iron access.
How much clearance do I need to solder comfortably under a magnifier?
Technicians recommend at least 100 mm. A 10 D lens offers about that distance with 3.5× view [Elektroda, tomiok, #12089412; Elektroda, Mechanik21, #12090345]. Less space risks burnt probe tips and poor ergonomics.
Desk magnifier or stereomicroscope – which is better for SMD work?
Magnifiers are cheap, bright and fine for placement up to 0603 size. For precision rework or inspection beyond 3×, a stereomicroscope (10–35×) gives depth perception and wider zoom without distortion [Elektroda, serwis, post #9944033]
Does stacking two magnifiers double the power?
Stacking two 5 D lenses rarely yields 10 D. Overlapping lenses introduce heavy aberrations and practically reduce the field of view [Elektroda, mihail1, #14254162; Elektroda, tomiok, #14254587]. Use a single higher-quality lens instead.
3-step: How do I calculate magnification from diopters?
  1. Measure diopter value (D) on the frame.
  2. Apply formula M ≈ (D/4)+1.
  3. Verify by comparing a millimetre scale under the lens. Example: D = 8 → (8/4)+1 = 3 ≈ 2.95× [Elektroda, kazimierzbrejta, post #10199025]
Why do some products claim 10× but deliver far less?
Many low-cost brands list optical power (10 D) as 10× magnification. True 10× would need complex multi-element lenses; simple glass maxes at about 7× before distortion dominates [Elektroda, tomiok, post #14254551] Always test with a ruler.
