Selecting Backlit Magnifier for SMD Soldering: Comparing 5 Diopters vs 8 Diopters Options
saly 63135 40
How many diopters should I choose for a backlit magnifier for soldering regular SMD parts?
For regular SMD soldering, 5 diopters is usually enough; 8 diopters is stronger, but it distorts the image more and leaves less working distance, so it is less comfortable for soldering [#10012063][#9944033] 5 diopters are described as an auxiliary loupe for low-precision work, while 8 diopters are more suitable for inspections than for precise soldering [#9944033] For precise previewing or very small SMD work, the thread recommends a microscope instead of a simple magnifier [#9944033] If you choose a loupe, it is better to have the largest possible lens area, because higher power usually means a thicker/smaller lens and more distortion [#10012063][#14254551]
  • #31 14254571
    mihail1
    Unfortunately, the old loupes are without a company, and the new one I bought is Eschenbach x10 (I didn't write with it before) and somehow it didn't suit my grandfather, it's probably too strong.
  • #32 14254587
    tomiok
    Help: 133
    Rate: 292
    The stronger the luba - the more distorting is felt.
    As I wrote above, the farther we are from the optical axis, the greater the (large) image distortions.
    And it's probably bothering grandpa, and it's a little one, and I don't know what the real magnification is.
    He probably sees a letter or two at a time, and that irritates him.
  • #33 14254592
    mihail1
    Sure I understand it, but I bought a 10 because it uses two 5. It's hard to return and buy either x5 or x7.
    Does Eschenbach reliably provide the magnification?
  • #34 14254599
    tomiok
    Help: 133
    Rate: 292
    I think it's better to buy (sponsor) good glasses, much better effect.
    Alternatively, do the so-called Videolupa.
    But the costs.
  • #35 14254614
    mihail1
    Unfortunately, it's nothing because my grandfather had an accident in his childhood, he doesn't see the colors, etc., he sees something only from a few centimeters, describing it with his words, "I only see the contours".
    Nothing can be done about it, he visited many specialists.
  • #37 14254634
    mihail1
    Approx. Thanks for the info.
    He often visits an ophthalmologist.
  • Medical surgical loupe offers sharp 30 cm working distance
    #39 14307799
    AndrzejSanok
    One of the solutions for the grandfather may be a medical eyeglass loupe for micro surgical operations. It is great because it has a large field of view and the image is sharp from about 30 cm.
    In order for such a magnifier to meet the expectations, it would probably have to be modified to this eye defect.
    (Only applicable for reading) Unfortunately, the price is down.
    The second: enlarging the image on the screen to a size recognizable by grandfather and choosing glasses.
    Added after 17 [minutes]:
    tomybb wrote:
    I have a 10x magnifying glass - it's useful, sometimes I also use a 20x microscope, such a combination is enough for me - the microscope also has a 40x - I rarely use it, but also useful - it would be better than not. Overall, it seems to me that magnification depends on individual needs.
    It would be handy for someone who would be able to construct cheap glasses for electronics, similar to a medical magnifier.
    There is quite a lot of scrap from digital cameras available.
    Maybe there would be an optician who could comment on this topic, because you know, a short focal length is a big problem when soldering.
  • #40 19013786
    bobruk.pl
    Rate: 19
    saly wrote:
    A typical workshop, such as the XTLIV with a basic 10 to 35x magnification, perfectly meets these requirements.
    Is it possible to buy something similar on the market today? is it about functionality and the price of, say, PLN 1000-1500?
  • Removing one lens improves focal length for SMD inspection
    #41 19016075
    saly
    Level 32  
    Help: 89
    Rate: 1003
    It recommends a simple device for SMD control, etc., inexpensive and helpful, the disadvantage is a small focal length and when there are some sockets on the board, you cannot push it close, but you can remove one glass from the magnifier and it is much better when it comes to focal length, admittedly magnification it drops slightly but it is ok anyway. Smd control after soldering, this magnifier is also perfect.
    https://www.tme.eu/pl/details/fut.sl-71/lupy/engineer/sl-71/
The discussion revolves around selecting a backlit magnifier for SMD soldering, focusing on the comparison between 5 diopters (2.25x magnification) and 8 diopters (2.95x magnification). Users share their experiences, indicating that while 5 diopters may suffice for general soldering tasks, 8 diopters or higher may be necessary for more precise work. Some participants recommend using a microscope for detailed inspections, particularly for small components. The XTLIV microscope is mentioned as a suitable option, although its price is noted as a concern. Users also discuss the importance of working distance and the potential distortion caused by higher magnifications. Various alternatives, including reading glasses and specialized loupes, are suggested for different needs and budgets.
TL;DR: 5-diopter lenses deliver a measured 2.25× magnification, “Magnification depends on individual needs” [Elektroda, tomybb, #9940790; Elektroda, serwis, #9944033]. 8 D raises detail to 2.95× but cuts working distance and boosts distortion.
Why it matters: Picking the right power keeps joints visible without burning your nose or your budget.
• 5 D ≈ 200 mm focal length → 2.25× view [Elektroda, serwis, post #9944033]
• 8 D ≈ 125 mm focal length → 2.95× view [Elektroda, serwis, post #9944033]
• 10 D at 100 mm working distance gives ≈ 3.5× view [Elektroda, Mechanik21, post #12090345]
• Lens diameter shrinks as power rises; >8 D lenses often <90 mm and show stronger edge distortion [Elektroda, tomiok, post #14254551]
• XTL-IV stereomicroscope: 10–35× zoom, ~100 mm clearance, PLN 1250 with camera [Elektroda, serwis, post #9963574]
Is 5 D (2.25×) sufficient for everyday SMD soldering?
Yes. Forum users report comfortably soldering 0.65–0.8 mm pitch with 5 D back-lit lamps [Elektroda, ^ToM^, #10012063; Elektroda, saly, #9963911]. 2–2.5× keeps the entire pad and tip in view and leaves space for tweezers.
When would I choose an 8 D magnifier instead?
Select 8 D when you inspect fine bridges, 0402 parts (1.0 × 0.5 mm) or ageing eyes struggle with 5 D detail. Expect 75 mm less clearance and stronger edge distortion [Elektroda, serwis, #9944033; Elektroda, tomiok, #14254551].
How does diopter affect working distance?
Working distance roughly equals focal length. 5 D gives ~200 mm, 8 D ~125 mm, 10 D ~100 mm [Elektroda, Mechanik21, post #12090345] More power pulls the lens closer, limiting iron access.
How much clearance do I need to solder comfortably under a magnifier?
Technicians recommend at least 100 mm. A 10 D lens offers about that distance with 3.5× view [Elektroda, tomiok, #12089412; Elektroda, Mechanik21, #12090345]. Less space risks burnt probe tips and poor ergonomics.
Desk magnifier or stereomicroscope – which is better for SMD work?
Magnifiers are cheap, bright and fine for placement up to 0603 size. For precision rework or inspection beyond 3×, a stereomicroscope (10–35×) gives depth perception and wider zoom without distortion [Elektroda, serwis, post #9944033]
Does stacking two magnifiers double the power?
Stacking two 5 D lenses rarely yields 10 D. Overlapping lenses introduce heavy aberrations and practically reduce the field of view [Elektroda, mihail1, #14254162; Elektroda, tomiok, #14254587]. Use a single higher-quality lens instead.
3-step: How do I calculate magnification from diopters?
  1. Measure diopter value (D) on the frame.
  2. Apply formula M ≈ (D/4)+1.
  3. Verify by comparing a millimetre scale under the lens. Example: D = 8 → (8/4)+1 = 3 ≈ 2.95× [Elektroda, kazimierzbrejta, post #10199025]
Why do some products claim 10× but deliver far less?
Many low-cost brands list optical power (10 D) as 10× magnification. True 10× would need complex multi-element lenses; simple glass maxes at about 7× before distortion dominates [Elektroda, tomiok, post #14254551] Always test with a ruler.
