Screwdriver vs Screwdriver - The choice of tool on the construction site.
JanuszKarpaty 1398 1
  • #1 20606166
    JanuszKarpaty
    What's better for a construction site? Screwdriver or screwdriver?
  • Screwdriver recommended over drill for construction use
    #2 20762205
    gosp
    Printers specialist
    Help: 39
    Rate: 45
    I would recommend to the author a screwdriver for this construction, what I write is supported by my own experience, I use tools every day and even though I have 4 screwdrivers, I still embrace everything with a screwdriver. The screwdriver threads without problems (and even better than a screwdriver), drills with a sedan, there are diamond drills with 1/4" hex chucks with which you can drill in the hardest materials, there is a whole range of drills for wood and metal with 1/4" hex chucks, and if someone really wants to save money and drill with cylindrical drills, then for twenty-something zlotys he can buy a keyless drill chuck, e.g.:10mm with 1/4" hex output for the screwdriver. Alternatively, if the author really wants a screwdriver, I would suggest as someone above a combo set of e.g. makita 12V series. P.S. If someone does a lot of things in wood and wood-based materials with smaller screws, then I recommend screwdrivers (oil/hydraulic) give incredible comfort of control of screwing, they are also very useful for loosening baked screws without destroying the head, their only drawback is the high price , usually starts from 1000PLN.
