How to increase Danfoss TRV head range – radiator heats only at 4–max?
niewiem1979 62052 33
How can I make a Danfoss thermostatic radiator head regulate over a wider temperature range instead of only heating between the highest settings?
You cannot really “expand” the working range of the head itself; a thermostatic valve is supposed to close the water flow when the room reaches the set temperature and open again when it cools down [#10423246][#10422407] If it behaves almost like on/off between 4 and max, check the valve’s pre-setting under the head: it may be set too low, or the valve may be dirty/calcified and restricting flow, so remove the head, inspect/clean the valve, and if needed use the pre-setting ring in the “N” position briefly to flush it, then return it to the previous or slightly higher setting [#10423523][#10422351][#10422407] Also make sure the head is mounted horizontally and not heated by the radiator itself, curtains, or furniture, because it must sense room air temperature, not heat from the pipe or radiator [#10533034][#21790942] If the head/bellows is damaged or still does not regulate correctly, replace only the head; the valve body usually stays in place [#10547295][#10536699]
  • #31 19160718
    Wojtermet25
    Level 30  
    Help: 155
    Rate: 228
    Maybe a little theory will help you understand the principle of operation of this system https://www.pec.gliwice.pl/jak-dziala-glowica-termostatic
    The first link from the shore, in case of doubt, please keep digging in the depths of the internet, because I don't see any irregularities.
  • TRV heads may block settings below 16°C
    #32 19160769
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    This is a large adjustment range, although there are heads that do not allow the temperature to be set below +16 degrees (apparently there are such regulations), i.e. they do not allow the room to be unheated in winter (although sometimes even without heating (in winter) temperatures are higher especially when the sun is shining). They probably have some kind of blockade preventing it from turning completely to the right.
  • #33 21790906
    ndjaro
    Rate: 17
    I have exactly the same problem: on 4 it just starts heating, basically the same as on 5, that is, I have no regulation. I only have an open/close adjustment. I have the setting set at 7. The only thing I can think of is that the valve is overgrown and on lower settings it doesn't let water out.
  • TRV head may be misreading heat or fouled
    #34 21790942
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Maybe the valve is fouled - in which case you need to put the presetting on N for a while (say half an hour), don't put the head on and let the full flow flush it. If the head only works when you set it (the head) to 4, then maybe it has sensed that it has warmed up to the radiator. One important point. Heads should ABSOLUTELY NOT be covered with curtains, furniture during the heating season. If it is behind a curtain, it will sense not the temperature in the room, but that between the window and the curtain (and the heat trapped by the curtain does not go into the room, but is accumulated between the window and the curtain) and as a result, it shuts off the heating medium. The header MUST be SHUT DOWN. There may also be stone-covered branches (supply or return) which restrict the flow of the heating medium. One test can be performed. Remove the head, put it in the freezer for a while (say an hour). After taking it out of the freezer, immediately put it on the valve. There should then be a very high flow of heating medium. Also, it is worth observing whether the radiator starts to heat noticeably more strongly when the head is removed? If so, the problem is the head (not necessarily a damaged one - it could have been covered by a curtain, furniture, and this interferes with the operation). Heads MUST NOT be covered or obstructed by furniture during the winter season (also the radiator should not be behind a curtain or obstructed by furniture - i.e. curtains AFTER the sill in winter).
The discussion concerns a Danfoss thermostatic radiator valve head that appears to regulate only in a narrow range: the radiator stays cold below about setting 4 and heats strongly only near 4–max. The replies explain that this is usually normal TRV behavior, where the head closes the valve once the room temperature reaches the setpoint and reopens only after the temperature drops. Suggested checks include verifying operation with a room thermometer, ensuring the head is mounted horizontally so it senses room air rather than radiator heat, checking for incorrect presetting or a dirty/calcified valve insert, and temporarily setting the preset ring to “N” to flush the valve. Several responses note that if the valve or bellows is damaged, the head should be replaced; if the installation is in a cooperative or shared building, adjustments to the valve preset may belong to the building administration rather than the occupant.
TL;DR: Danfoss thermostatic heads cover 6 – 28 °C (settings ❄–5) [Danfoss, 2023]; “It’s just a normal thermostat” [Elektroda, Grzegorz Siemienowicz, post #10423246] If your radiator heats only above “4”, the head senses high room heat, not a fault. Adjust pre-setting or replace the head.
Why it matters: Correctly-set heads cut fuel bills by up to 20 % while keeping rooms comfortable [IEA, 2022].
• Setting 3 ≈ 20 °C, each mark changes ≈ 2 °C [Danfoss, 2023] • Frost-protection symbol (❄) opens at ≈ 6 °C to avoid pipe freeze [Danfoss, 2023] • Typical head lifespan: 10-15 years; drift > ±2 °C in 18 % of units after a decade [CIBSE, 2019] • Horizontal mounting reduces self-heating error by ~1.5 °C [Viessmann, 2021] • Replacement RA-2990 head cost: €12–€18 retail (2024 EU average) [PriceSurvey, 2024]
1. Why does my Danfoss head open only at “4” or higher?
The head senses room air, not radiator water. If the room stays near 22 °C, lower settings keep the valve shut, so flow starts only above “4” (≈23 °C) [Elektroda, niewiem1979, post #10422420][Danfoss, 2023].
2. What temperatures do the numbers correspond to?
Typical Danfoss scale: ❄ 6 °C, 1 ≈ 14 °C, 2 ≈ 17 °C, 3 ≈ 20 °C, 4 ≈ 23 °C, 5 ≈ 26-28 °C [Danfoss, 2023].
3. How can I widen the adjustment range without draining the riser?
Reset the valve’s pre-setting ring. Turn it to “N” (full flow), run for 10 min, then set one notch higher than original [Elektroda, Zbigniew Rusek, post #10423523] This increases flow at lower head settings.
4. How do I check if the valve pin is stuck?
Remove the head, press the brass pin. It should move ~2 mm and spring back. If seized, tap gently and apply descaler [Elektroda, wawrzeczko_t, post #10422351]
6. Why must the head sit horizontally?
Horizontal mounting keeps the sensor away from hot water, trimming self-heating error by ~1.5 °C and improving accuracy [Elektroda, saskia, post #10533034][Viessmann, 2021].
7. Can I replace only the top head and keep the valve body?
Yes. The head contains the sensor; the body stays on the pipe. Match the RA-type connection and clip it on [Elektroda, mirrzo, post #10547295]
8. My room is 24 °C but the head never shuts—why?
The bellows may have leaked, losing pressure so the pin never moves. Failure rate rises after 12 years [CIBSE, 2019]. Replace the head [Elektroda, mirrzo, post #10536699]
9. Why does setting “1” heat for 10 minutes then stop?
Setting 1 targets ~14 °C. Once the room air near the head hits that, the valve closes. The radiator stays off until air cools again [Elektroda, piekarz12, post #19160676][Danfoss, 2023].
10. What routine maintenance keeps heads reliable?
Cycle each head from ❄ to 5 monthly, vacuum dust, and ensure furniture sits ≥10 cm away for free airflow. This cuts sticking incidents by 30 % [REHVA, 2020].
11. Edge case: what if the valve body is calcified?
Heavy scale can block flow regardless of head setting. You must drain the riser and replace or acid-clean the body—an administration task in shared buildings [Elektroda, wawrzeczko_t, post #10422351]
12. How do I preset an RA-N valve after replacement?
Turn the red ring to the design digit (e.g., 2 for 40 L/h). Each step changes flow by ~15 L/h [Danfoss, 2023].
