Vaillant ecoVIT plus VKS INT 196: Dealing with SEr Maintenance Message on Condensing Boiler
pracplast 52735 20
How can I turn off the Vaillant boiler's SEr maintenance message myself?
You can disable the SEr maintenance reminder from the service/diagnostic menu by entering d.97 and setting the password to 17, then opening d.84 and changing its value to “-” to switch off the maintenance information [#19271262][#10574135] To do it, press “i” and “+” together to enter diagnostics, go to d.97, confirm, set 17, save it, then go to d.84, set “-”, and confirm again [#19271262][#10574135] After that, exit the diagnostic menu with “i” + “+” or wait for it to time out [#19271262] One reply notes that this message is only a maintenance reminder and says it is normally removed by the service technician, not as a fault reset [#10423962] Another reply warns that if the message appears again it may indicate cleaning or chimney-draft issues, so the underlying cause should still be checked [#10423222]
  • #1 10422941
    pracplast
    Rate: 24
    Hello. The case concerns a condensing boiler with a Vaillant ecoVIT plus VKS INT 196 tank, so from yesterday a pulsating "message" SEr appeared on the display of the boiler, indicating the need for maintenance. I would like to point out that the stove is three years old and so far it has been serviced on a regular basis, most recently in September last year. By the way, a "specialist" from Vaillant, after removing the casing, swept everything with a brush, claiming that everything was ok and he collected PLN 200! My question: can I turn off this function myself, because calling a service technician is probably about PLN 100 back.
  • #2 10423222
    markmd
    Help: 49
    Rate: 278
    You can clear this message yourself, but the next ones will indicate the need for cleaning or disturbance of the chimney draft.
  • #3 10423592
    pracplast
    Rate: 24
    Thanks, but how can I clear this message?
  • #4 10423962
    duddy
    Help: 56
    Rate: 186
    The message is removed by the service technician.
    It was created to inform the user about the need for review and I do not recommend deleting this type of information yourself.
    Please ask the service technician during the inspection to disable the maintenance information option. It will automatically cause that the user will have to remember about the date of the next inspection.
    PITSTOP
    Piłkarska 21, Gorzów Wielkopolski, 66-400
  • #5 10424025
    Grzegorz Siemienowicz
    Level 36  
    Help: 146
    Rate: 600
    It seems strange to me after 4 months from correct such a message was displayed for maintenance and inspection of the boiler.
    Maintenance and inspection should ensure a minimum of one year of trouble-free operation (unless the inspection reveals an element that needs to be replaced soon or there is damage to one of the elements) but ... there is no need for maintenance.
  • #6 10424044
    duddy
    Help: 56
    Rate: 186
    pracplast wrote:
    Although, by the way, a "specialist" from Vaillant, after removing the casing, he swept everything around with a brush, claiming that everything was ok and he collected PLN 200
    that would have given me a lot to think about.
    As a service technician, I carry out a lot of such inspections, and despite the lack of time, I at least check the basic security measures that care for the user's safety.
    It is from tond my suspicions of improper maintenance, or, as you can call it, failure to do it at all!
    PITSTOP
  • #7 10424192
    markmd
    Help: 49
    Rate: 278
    Check the chimney draft. Relax.
  • #8 10425545
    mauri_b
    Heating systems specialist
    Help: 109
    Rate: 529
  • #9 10425725
    mirrzo
    Help: 441
    Rate: 2609
    In a condensing boiler?
    EURO-DOM
    Krótka, Elbląg, 82-300
  • #10 10426584
    duddy
    Help: 56
    Rate: 186
    Buddy, something went wrong for you, you just need to read the post carefully
    PITSTOP
  • #11 10427227
    markmd
    Help: 49
    Rate: 278
    Really. I haven't read it. Sorry.
  • #12 10574135
    cezarek79
    Rate: 15
    Hello, Recently, I also had this problem with the SER message on the Vaillant stove. There is hardly any way to find out how to remove this on the web. However, by chance I managed to find a hint on the pages of ... Vaillant.
    1. Enter the diagnostic menu by pressing the "i" and "+" buttons simultaneously
    The display will show the diagnostic parameter "d.0"
    2. Press the "+" button until you get to the parameter 84 - "d.84"
    3. Press the "i" button to move to the value of parameter 84 which is the number of operating hours until the next maintenance. The display will show a number showing how many hours the stove will continue to work until the message "cheese" appears. In your case it will be "0". To set a different number, press the "+" button, to disable this function, press the "-" button until the "-" sign appears.
    4. To confirm the changes made, press the "i" button for a few seconds until it stops flashing
    5. To exit the diagnostic menu press "i" and "+" simultaneously.
    Ready
  • #13 10575690
    DARIUS67
    Help: 63
    Rate: 338
    You read, you write, but none of it.
    Ser signaling means incorrect or no operation of the boiler due to poor water flow. This may be due to the calcification of the exchanger in the boiler or a dirty filter on the return. In the VKS boiler you will probably press "i" and S.53 will be displayed. These messages are not reset, the cause of the flow suppression must be found.
    Well, unless I'm wrong.
  • #14 10577086
    cezarek79
    Rate: 15
    I do not understand why the SER message indicates a malfunction in the oven. It is described everywhere that it is a message about the expiry of the programmed time for the next service. When I entered the parameter d.84, I had the value "0". After all, there are FXX messages from the error signaling. But of course I can be wrong.
    BTW. During the last service, the Vaillant technician only cleaned the combustion chamber and said nothing about the water flow. It is a pity to spend 200 for removing the SER message, which appears in the middle of the heating season and which partially limits the functionality of the temperature controller because the error message appears.
  • #15 10579073
    duddy
    Help: 56
    Rate: 186
    cezarek79 wrote:
    During the last service, a Vaillant technician only cleaned the combustion chamber
    So he doesn't look like a professional. On top of that you call Vaillant ... it's weird. Our specialists do much more.
    PITSTOP
  • #16 10581054
    1tropek
    Help: 30
    Rate: 152
    duddy wrote:
    So he doesn't look like a professional. Plus you're calling Vaillant ... it's weird. Our specialists do much more .
    Wasi ????
    Why your ad under your entries no longer contains Wanlajt - they chased your professionals ?
    What??????
  • #17 10585956
    DARIUS67
    Help: 63
    Rate: 338
    Coming back to the topic.
    Boilers have their own logic of operation, if something goes beyond a certain range, the information appears on the display - Ser. There is an internal clutch installed in the VKS boiler, there is also an electronic pump between it and the coil, so maybe something is clogged on this circuit.
    An example that I was able to observe at the client's. The boiler operated with a weather-compensated controller (for highly inflated heating curves) on two heating circuits, but the installer installed an on-off room thermostat on the radiator circuit. When the latter disconnected the pump, the boiler rapidly overheated and the message Ser. So the message appears not only because the amount of boiler operation is exceeded. In the described example, it was enough to set the heating curves for the boiler to work with weather control, and not like a kettle, and the problem disappeared.
  • #18 13402578
    cynamonik
    Rate: 143
    I found a full description of this code in one manual - details below in the picture:
    in addition, I will ask if entering the setting in the form of the "-" sign completely eliminates the display of this message, also in the event of a failure? because according to the instructions it concerns "maintenance messages"?
  • #19 13402845
    mauri_b
    Help: 109
    Rate: 529
    Only maintenance work. In your burner barrel, flow disturbances are unlikely to be a threat.
  • #20 19269674
    plutoxl
    If the set value can have a maximum value of 300, then multiplied by 10 hours is 3000. 3000 hours is 125 days, i.e. 4 months just ....
    How is this setting supposed to last for e.g. a year?
  • Service-level procedure to clear the SEr message
    #21 19271262
    ROWE
    Help: 239
    Rate: 535
    You must enter the first diagnostic level and the second level, i.e. the service level, thus using the password to change the code value d.97 on "17" and code d.84 on "-" , that is:
    1. You open the first diagnostic level to enter the password!
    o Press the buttons simultaneously "and" and "+" .
    The display shows the code " d.0 ".
    o Using the buttons "+" or "-" go to the diagnostic code, i.e. "d.97" !
    o Press the buttons "and" .
    The display shows the current diagnostic information.
    o With the button "+" or "-" (blinking indications) you change the password value to "17" .
    o You register new set password value in memory "17" holding button "and "Pressed for approx. 5 seconds until the flashing and indications stop.
    2. Now you are on the second diagnostic level to turn off CHEESE (at this level, all information from the first and second diagnostic level will be displayed), that is:
    The display shows the code again "d.0" .
    o Using the buttons "+" or "-" now go to the diagnostic code one by one, "d.84" !
    The display shows the corresponding diagnostic information.
    o With the button "+" or "-" change value (flashing displays) change from to "-"
    o You register a new set value in memory "-", holding button "and" in the pressed state for approx. 5 seconds until the flashing and indications stop.
    3. Now you close and exit the diagnostic mode as follows:
    o Press the buttons simultaneously "and" and "+".
    or
    o Do not press any button for approx. 4 minutes.
    The display shows the current flow temperature of the central heating circuit, and this is the end of the procedure.
    Jt. procedure quite complicated but manageable, good luck!
The discussion revolves around the SEr maintenance message displayed on the Vaillant ecoVIT plus VKS INT 196 condensing boiler, which indicates the need for maintenance. Users express concerns about the frequency of this message, especially given the boiler's recent servicing. Some participants suggest that the message can be cleared by the user, while others advise against it, recommending that a service technician handle it to ensure proper maintenance records. Detailed instructions for accessing the diagnostic menu and modifying the maintenance settings are provided, including steps to disable the maintenance reminder. Additionally, there are discussions about potential underlying issues causing the SEr message, such as water flow problems or chimney draft issues.
