EA 8050 KRUPS Coffee Machine: Solutions for Error 09 Issue - Power Disconnect & DIY Fixes
mrrainy666 55654 5
  • #1 10873689
    mrrainy666
    Rate: 8
    A few days ago I got "error 09", but I'm not going to use the wonderful advice of the guide like report for service so quickly. At least not without a fight. Disconnecting from the power does not help. Anyone have any idea? Thank you in advance.
  • #2 10897891
    Laja0
    Rate: 14
    I have the same and the same model. A month after the warranty, I got an error 09. Nothing can be done, only to replace the boiler with a new one. My coffee machine was on diagnostics in the service, the cost of replacing the boiler was PLN 570.
  • #3 10899139
    mrrainy666
    Rate: 8
    Last weekend, I unplugged the coffee machine for the whole night. Everything is back to normal. I don't know for how long, but for now ... knock on the door.
  • #4 10928699
    DarekKie
    Rate: 14
    I have a different Krups coffee machine, but the same error disappeared after soldering the originally very poorly fitted contacts on the front wall of the boiler (in the photo - from above).
  • #5 10928959
    mrrainy666
    Rate: 8
    Thanks for the advice, as soon as (hopefully not) the error repeats, I will start there. Regards.
  • #6 12932434
    Elektryk80
    Help: 89
    Rate: 61
    In my EA 8050 this morning, after making coffee, error 09 appeared. After disassembling the coffee machine, unscrewing the thermal fuse fastening and removing the rubber cover of the sensor mentioned in the previous posts, and checking it with a meter, it turned out that it has a gap in the place of soldering. I made a makeshift connection between the sensor foot (SMD) and the connector. So far it works fine.
    Regards
