Cables for Electric Roller Shutters: Choosing Cross-Section & Number of Veins in New House
bhtom 39300 10
What cable cross-section and how many conductors should I run to each window in a new house so I can add electric roller shutters later?
Run a 5-core cable to each shutter motor; 4 conductors is the minimum (N, up, down, PE), but 5 conductors is the most universal choice because it also covers motors with switch/radio control [#11144761] For cross-section, the replies point to roughly 1 mm² to 1.5 mm², with 5x1 mm² suggested and 5x1.5 mm² also described as sufficient; the cost difference is said to be negligible [#11136930][#21240490] The limit switches are built into the drive, so you do not need separate external limit wiring [#11144761]
  • #1 11133449
    bhtom
    Help: 446
    Rate: 604
    What cables should I lead, in a newly built house, to each window if I want to install roller shutters with electric drive in the future? Of course, it is about the cross-section and the number of veins.
    Regards.
  • Recommended shutter wiring sizes and deep switch boxes
    #2 11133533
    Mleczyk89
    Help: 291
    Rate: 266
    Power supply 3x0.75mm ^ 2 or 3x1mm ^ 2, wires for the switch at each shutter (power supply to the switch and the shutter switch), unless radio-controlled.
    If you think about the central control of the roller blinds from one place (the cost of buying a gun and a controller), then 2x0.75mm2 for each roller blind converging to the central control points. It can be on a loop basis.
    It is advisable to plant deep boxes next to the roller shutter switches, which will allow for possible modifications (adding a radio receiver or radio receivers).
  • #3 11136930
    YR1
    Help: 49
    Rate: 52
    To control ordinary cables (LGY type) 5x0.75, power supply 3x1, regardless of whether LGY or YDY.
    You need Up / Down + limit switches to control. In some implementations you have it on 5 wires. The cost difference of 3x or 5x is negligible.
  • Questions about 4x1 mm2 shutter wiring and limit switches
    #4 11137067
    bhtom
    Help: 446
    Rate: 604
    So I understand that 3x1mm2 is enough to power it. Control 5x0.75mm2 also. Assuming that the blinds will be controlled from a central point in the house, I run two wires (power supply and control) to each blind and lead them outside in the upper corner of each window where the blind will be located, right?
    One more question, wouldn't one 4x1mm2 cable be enough (phase for upward direction, phase for downward direction, N and PE)? Limit switches I understand that they are installed in the drive and disconnect the phase wires (the lower one disconnects the downward movement, and the upper one upward movement), right?
    Regards.
  • #5 11144761
    tmf
    Help: 2090
    Rate: 2206
    The least you need is 4 wires - N, up, down, PE. 5-wire drives are very rare. For radio-controlled drives with the ability to be controlled by a switch, you have N, L, up, down, PE. So 5 wires is ideal and universal. The limiters are in the drives.
  • #6 17860651
    przemeq99
    Rate: 11
    Hello, and how to lead out the cables from the roller shutters, if their installation will be plastered. I took the wires from the boxes next to the window, but all blinds have their wires in the motors with a margin of about 1.5 m. How to install correctly?
  • Recommended pre-plaster cable routing with junction box and diagonal drill hole
    #7 19155543
    wladziu22
    Help: 8
    Rate: 56
    Two years have passed so she has probably dealt with swim's dilemma. For those who read and have a similar puzzle, the roller shutter cable is usually pierced through the mounting foam and it breaks. That's why you won't do it after plaster.
    At the same time, close to the top corner of the window, e.g. about 15 cm from, put an access box on the wall. In the can, we drill a hole through the outer wall. to the other side to push the motor cable into the inside of the box. There are also extensions to the box. room, 5x1mm2 cable from the control button. After plastering and connecting the cable, the blinds are usually 4x1mm with a 5x1mm2 cable.
    All in all, it is easier to first drill a hole diagonally with a long drill, starting from the side of the window frame to the outside, to the inside of the room. Then you should make a hole for the can.
  • Recommended 1.5–2.5 mm² cables for shutters
    #8 21144733
    avamax390
    When choosing cables for electric roller shutters in a new house:
    1. **Cross-Section**: Use 1.5mm² to 2.5mm² cross-section cables, depending on the current rating of the shutters and the distance from the power source.
    2. **Number of Veins**: Typically, a single-phase shutter motor requires a 3-core cable (live, neutral, earth). For three-phase motors, use a 5-core cable (3 phases, neutral, earth).
  • 5x1.5 mm² cable and garage control box recommended
    #9 21240490
    wladziu22
    Help: 8
    Rate: 56
    I did my own 13pc blinds.
    A 5x1.5mm2 is sufficient and you can also do the control on it, but you give up the PN (protective). This means 3 wires for the power supply of the roller shutter and two for the so-called short circuit/control (more info below).
    There is no need for access boxes, as every roller shutter must have a manual button in case of an emergency. For example, if the wifi does not work. Preferably somewhere next to the window, as it is not used much.
    Roller shutters mainly have 4 wires of approx. 1.5 m cable (top, bottom, zero and protective).
    Push the roller shutter cable through the foam (between the window and the block), then cover the cable with plaster inside the rooms.
    You can extend the cable, e.g. if you want to have two roller shutter buttons next to each other, e.g. for double patio shutters.
    Route all 5x1.5mm2 cables from the roller shutters into the garage to a separate box, as there will be a lot of them.
    For some central buttons or for the floor, 2x or 3x0.5mm2 are sufficient. Also run to the above-mentioned box.
    If you have all the cables in the box, you can do whatever you want.
    All pushbuttons work like a two-wire short, where you put a low voltage of 5V into one wire.
    A module in the control box recognises the short to 5V and decides what to do with the roller shutter.
    You will have to decide which module(s) will be in the box.
    You can either have separate wifi controllers for each roller shutter or a single wifi control for all roller shutters + one wifi control for the app.
    Good luck.
  • #10 21245216
    kostrze
    Help: 12
    Rate: 41
    I have a wire 5 times 1.5 mm
  • #11 21374478
    Dzonzi
    Rate: 59
    And is it possible to make it so that from the light switch goes an L, N 3x1.5mm2 bridge to the roller shutter switch (both switches side by side) and to the Shelly PLUS 2 PM underneath it, and from the controller to the roller shutter 4x0.75mm2. Would this be good?
For electric roller shutters in a newly built house, the recommended cable specifications include power supply cables of 3x0.75mm² or 3x1mm², with control cables typically being 5x0.75mm² (LGY or YDY type). A common wiring scheme involves 4 wires: live (phase for up and down directions), neutral (N), and protective earth (PE). Limit switches are usually integrated within the shutter drives, eliminating the need for additional wiring for end stops. For centralized control, separate power and control cables (e.g., 2x0.75mm²) can be routed from each shutter to a central control point, often arranged in a loop. Cable cross-sections may vary from 1.5mm² to 2.5mm² depending on motor current and cable length. Installation best practices include placing deep or access boxes near shutter switches to allow future modifications such as adding radio receivers. Motor cables typically have a length margin (~1.5 m) and should be routed through mounting foam between the window and block before plastering to avoid damage. For multiple shutters, cables (e.g., 5x1.5mm²) are routed to a central distribution box, often in the garage. Integration with smart controllers (e.g., Shelly PLUS 2 PM) can be achieved by bridging L and N from light switches to shutter switches and using 4x0.75mm² cables from the controller to the shutters. Overall, wiring should ensure safe power delivery, control functionality, and future expandability.
