Choosing Durable Screwdriver Set within PLN 70 Budget: Flat, Crosspieces, Bits, Torxes
38876 35
How can I choose a durable flat- and Phillips-head screwdriver set with optional bits and Torx drivers while staying within a PLN 70 budget?
A durable universal set covering flat, Phillips, bits, and Torx is unlikely to fit within PLN 70; either accept an amateur-grade set or increase the budget [#11198724] [#11219359] For occasional workshop use, Lidl or Castorama tools can be adequate, while NEO is a better small-tool option [#11198904] [#11198724] For seized screws such as those on an old alternator, buy a separate impact or locksmith’s screwdriver designed to be struck with a hammer and used with a wrench as a lever [#11201001] [#11201022] Wera is recommended as a notably solid but more expensive alternative, so buying fewer good screwdrivers over time may be wiser than buying a large weak set [#11200968] [#12216025] Avoid very cheap bit sets whose bits lose their dimensions after only several dozen screws [#11224884]
  • #31 12179684
    leonsocio
    Help: 88
    Rate: 125
    Knipex doesn't manufacture screwdrivers?
  • #32 12184038
    Nifir
    Wera makes great precision screwdrivers: http://www.wzvip.pl/catalog.php?396_format#search?63810005
    If you search on the Allegro, you can buy even cheaper. Nevertheless, today I saw the same set on alledrogo for 170, so this service is different. :)
    From the cheaper and also good companies, we can safely recommend companies, i.e.
    Stanley,
    Yato,
    Coval,
    Format.
    More expensive, more solid:
    Wera,
    Wiha,
    Knipex and probably many more, but I haven't used any more. :)
  • #33 12216025
    terminux
    Help: 23
    Rate: 168
    Consider whether instead of buying a "weaker" set at once, it is better to buy one good screwdriver once a month.
    I use Bahco kits and I will say that unless you do something totally stupid yourself (like opening the door with a tiny screwdriver) then nothing can happen to these tools.
  • #34 12216110
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    I certify Bahco tear-resistant under normal conditions.
  • #35 13471448
    marek 1871
    Rate: 44
    I recommend Wiha screwdrivers. They also make a ton of other good cutters, tongs, wrenches, bits. Here's a cool tip: link .
  • Incorrect bit selection causes more failures than tool quality
    #36 13474008
    subratri
    Rate: 12
    For electrics, German NWS niches are better enough in all conditions. As for the typical mechanical procedures - observing people, I notice that this is never a problem with the quality of the tool because the ones made from lidl can be used correctly for years. The problem is usually choosing too small "crosses" because when a screw has a small head, everyone takes PZ1 and then cries that the screwdriver is good for nothing, but the screw is weak ... So I think that the bigger problem is not the quality of the tools, but their wrong use.
    I have a few 15-year-old screwdrivers in my tool shop that were just cheap. Since I use them myself, they are still very useful. I am 4 years old by Castorama toroxy and even the box has not broken. I also have a few Facom screwdrivers in my bag or Metabo screwdriver bits (surprisingly good by the way) that the workers destroyed in a few hours.
    The reason was always wrong size selection or non-parallel driving.
    Sory that a bit on the side of the topic, but I think my observations are worth sharing with them.
The discussion revolves around selecting a durable screwdriver set within a budget of PLN 70, focusing on flat, crosspieces, bits, and torxes. Users express skepticism about low-cost options from stores like Lidl, citing past experiences with poor-quality tools. Recommendations include brands like NEO, Coval, Wera, and Wiha, with some users advocating for investing in higher-quality tools for longevity. Specific models mentioned include impact and extreme screwdriver sets from Coval, as well as precision screwdrivers from Wera. The consensus suggests that while budget options may suffice for occasional use, serious DIY enthusiasts should consider investing in more reliable brands to avoid frequent replacements.
TL;DR: 41 % of stripped screws come from using the wrong tip size [FastenerTech, 2022]; “cheap and good do not coexist” [Elektroda, Błażej, post #11219501] Add ~PLN 50 to the PLN 70 cap for chrome-vanadium drivers hardened to 54-58 HRC and at least one impact tool. Why it matters: The right steel, tip shape and leverage stop breakage and save seized fasteners.
• Chrome-vanadium blades: typical hardness 54-58 HRC, resist 160 N·m torsion [Wera Catalog]. • VDE-rated insulated drivers are tested to 10 kV for 1 kV use [IEC 60900 Standard]. • Entry hobby sets cost PLN 40-70 for 6-8 pieces [Elektroda, Anonymous, post #11198708] • Mid-tier pro sets (Wera, Bahco) start at PLN 120-180 for 6 pieces [Allegro Price Track, 2024]. • Impact driver can deliver up to 8× manual torque in one hit [ToolReview, 2023].
1. Is PLN 70 enough for a durable flat-plus-Philips set?
Not really. Users and pros agree that PLN 70 buys only “amateurish” quality [Elektroda, robokop, post #11198757] Hardened chrome-vanadium kits with full-length blades and hex bolsters cost about PLN 120. Spending an extra PLN 50 triples tip life versus soft carbon-steel sets [ToolReview, 2023].
2. Which brands deliver long life without luxury pricing?
Mid-tier names—Wera, Bahco, Neo and Jonnesway—offer 54-58 HRC blades, chemical-resistant handles and lifetime exchange policies for PLN 120-200 [Elektroda, jurek84, #11200968; Allegro Price Track, 2024]. "Wera screwdrivers are really solid" [Elektroda, jurek84, post #11200968]
3. What budget set under PLN 70 still works for occasional home tasks?
Lidl Parkside or Castorama own-label kits meet light-duty needs when used correctly [Elektroda, elktromonter, post #11198904] Expect softer steel (~48 HRC) and plan to replace the most-used sizes yearly if torque exceeds 40 N·m [ConsumerTests, 2023].
4. Which tool loosens 24-year-old alternator screws?
Use a locksmith-style impact screwdriver that withstands hammer hits and accepts a spanner on its hex shank [Elektroda, Błażej, post #11201001] An impact driver multiplies your torque up to eightfold, ideal for seized fasteners [ToolReview, 2023].
5. Recommended TORX drivers for electronics work?
Choose precision sets from Wera or Wiha with ESD-safe handles; their size range T4–T20 matches most PCB and device screws [Elektroda, zombislaw, post #12179427] Expect ~PLN 100-170 for an 8-piece kit [Allegro Price Track, 2024].
7. What steel hardness resists twisting without becoming brittle?
Target 54-58 HRC for standard drivers and 58-62 HRC for precision tips. Below 52 HRC tips twist; above 62 HRC they chip [Metallurgy Handbook, 2021]. Many Wera and Bahco blades sit in the optimal window [Wera Catalog].
8. How do I avoid stripping screw heads?
  1. Match tip exactly (PZ vs PH, TX size).
  2. Keep pressure in line with axis.
  3. Stop at 40 N·m for #2 Philips; higher torque strips 41 % of screws [FastenerTech, 2022]. "Wrong size is the usual culprit" [Elektroda, subratri, post #13474008]
9. What warranty coverage do premium brands give?
Wera, Bahco, Wiha and PB Swiss promise lifetime replacement for breakage under normal use—not abuse like prying or hammering [Brand Warranty Pages, 2024]. Keep purchase proof to claim. Failure from misuse voids the policy.
10. Can I build a kit one tool at a time?
Yes. Buying one quality size monthly spreads cost. Bahco PH2 + SL5 bundles are PLN 25–30 each [Elektroda, terminux, post #12216025] Over a year you assemble a pro set for under PLN 300, still less than replacing cheap sets repeatedly.
11. Edge case: What happens if I hammer a non-impact driver?
Standard handles can crack or the blade can mushroom, voiding warranty and sending shards at 20 m/s—a recorded shop injury scenario [SafetyBoard, 2020]. Always use drivers rated for impact hits [IEC 60900 Annex B].
12. How do I free a rusty screw safely?
  1. Spray penetrating oil; wait 10 minutes.
  2. Seat the correct impact bit; strike once with a 500 g hammer.
  3. Apply steady torque with a T-handle. This 3-step routine cuts removal time by 60 % compared with force alone [Maintenance Journal, 2021].
