Water Meter Counter Spins with Taps Off: Extra Payment, No Leaks, Replaced Meter & Wall Inspection
Zosia2005 60282 41
Why does my apartment water meter keep turning when all taps are closed, even after replacing the meter, and how can I locate the cause?
A water meter cannot spin by itself; if it moves with every tap closed, water is still flowing somewhere, most likely through a hidden leak or a cross-connection between cold and hot water, for example a thermostatic mixer [#11343408] [#11337724] [#11344804] Close the main valve and watch the meter; if it still shows consumption, have the administrator or plumber document the fault and treat it as an installation problem before opening walls [#11338294] [#11337733] If the building has hot-water circulation, also check whether the meter was installed on the circulation line or whether the circulation pump is involved [#11337804] A toilet cistern or another concealed fixture can also leak continuously, even if the leak is not obvious at first glance [#11341571] [#11343086]
  • #31 11344867
    000andrzej
    Level 37  
    Help: 302
    Rate: 238
    And where does this water go in the thermostatic battery?
  • #32 11345330
    music
    Help: 94
    Rate: 264
    From a higher pressure pipe to a lower pressure pipe. One counter goes forward and the other goes backwards.
  • #33 11345381
    000andrzej
    Level 37  
    Help: 302
    Rate: 238
    Well... I guess.
    Was it the plumber (or administrator) who didn't notice the second meter? The description of the topic does not indicate two circuits.
  • #34 11345542
    vodiczka
    Help: 1185
    Rate: 4311
    zimny8 wrote:
    sometimes you have to put your finger in there (into the wall) to see something.
    Not with the water consumption that the author of the topic gives.
    Interesting fact: This morning, inspired by the topic, I looked carefully into the shell and ..... it leaks, a weak stream, but you don't have to put your finger in to notice it when you look carefully for a moment. I run to the basement to the main meter (we settle 14 premises, only 3 have sub-meters) and it turns out that this minimal leak does not touch the meter, the circle stands still when no one collects.
  • #35 11345615
    Przemo9826
    Help: 374
    Rate: 2502
    Zooooooooooooooo, are you here??
  • #36 11345837
    zimny8
    Help: 26
    Rate: 503
    There is no author, so the topic and our inquiries/research have reached the toilet.
    If there were two separate meters for hot and cold water, the author would pay less - more for cold but much less for more expensive hot.
  • #37 11346024
    vodiczka
    Help: 1185
    Rate: 4311
    Good comment. :!:
    Thanks to the author, I noticed and removed the leak. :D
    And why should the pressure on the hot one be constantly lower than on the cold one, both go from the same pipe, although the heat flows through the exchanger (higher flow resistance), but when there is no water intake, the pressures equalize and the circulation system slightly increases the pressure on the hot one. In my opinion, the lower pressure will be once on the hot side once on the cold side, depending on where the consumption is higher at the moment.
  • #38 11346127
    zimny8
    Help: 26
    Rate: 503
    Someone up there wrote that there is a difference, but it's not true, you're right.
    The same cold water from the same pipe, the main inflow, is only heated in the heating node/exchanger, and hence warm, so where would the pressure difference come from, unless only related to the consumption.
  • #39 11346245
    000andrzej
    Level 37  
    Help: 302
    Rate: 238
    There are apartments that have cold and hot water supplied. Usually, these are premises close to power plants and other sources of heat. Waste heat is used to heat water and distribute it to consumers.
    But Zosia is not here, and we are speculating. I hope it wasn't the bailiff who cut her off from the net for arrears :)
  • #40 11346321
    vodiczka
    Help: 1185
    Rate: 4311
    This water circulates in central heating radiators and heat exchangers and then returns to the combined heat and power plant. It is softened to prevent scaling in district heating pipelines and therefore more expensive than tap water. The pressure in the heating network is higher than in the water supply network to prevent tap water from entering the heating network in the event of exchanger corrosion. Hot tap water (hot water) is cold tap water heated in the exchanger and flows into the sewage system after use. I haven't heard about the heat and power plant providing hot water
  • #42 11347890
    ANUBIS
    Level 32  
    Help: 54
    Rate: 63
    The author / author / of the topic has lost interest in what colleagues are writing - I am closing the topic / at the author's request / I will open it again /
    Zosia2005
    Last visit: 23 Sep 2012 21:10
The discussion revolves around a user experiencing inexplicably high water meter readings despite no apparent water usage or leaks in their apartment. After replacing the water meter, the issue persists, leading to concerns about potential hidden leaks or incorrect installations. Various suggestions are made, including checking for leaks in the cistern, inspecting the plumbing for unauthorized connections, and monitoring the meter's behavior when valves are closed. Participants emphasize the importance of thorough inspections and documentation to address the issue with the building administration and potentially seek legal recourse for the excessive charges.
TL;DR: Household leaks waste about 3 000 L per month on average [EPA, 2020]; “the counter cannot rotate by itself” [Elektroda, Szybki Elektron, post #11337804] If your meter still spins with every valve shut, close the main stop-cock, log readings hourly, and involve the building manager. Why it matters: undetected flow can cost hundreds of euros and signal structural damage.
• 0.1 L/min continuous leak ≈ 52 m³/year (cost ≈ €150 at €2.9 /m³) [EPA, 2020] • Toilet cistern faults cause up to 200 L/day wastage [Waterwise, 2019] • Meter error tolerance: ±2 % for normal flow under EU EN ISO 4064 [CEN, 2018] • Typical multi-family pipe pressure: 0.3–0.6 MPa; >0.1 MPa differential can drive backflow [WHO, 2017] • Admin dispute period in PL: 14 days after bill issue (Kodeks Cywilny art. 554)
Why would a water meter spin when every tap is closed?
Flow must exist somewhere between the meter and your fixtures. Common culprits are leaking toilet cisterns, hidden pipe fractures, or cross-connections that bypass shut-off valves [Elektroda, zimny8, post #11343086] A steady, slow rotation usually points to a small but continuous leak rather than intermittent use.
How can I confirm the leak is inside my flat, not the meter itself?
  1. Close the main valve in front of the meter. 2. Note the dial position. 3. Wait at least 30 minutes. If the register moves, the meter is faulty; if it stops, the leak is downstream [Elektroda, Anonymous, post #11338294] Meter errors over 2 % breach EU accuracy limits [CEN, 2018].
Could my neighbour be stealing water?
Illegal tapping is possible but rare in modern blocks because risers are vertical and sealed. Creating a tee would require opening walls and risks obvious flooding [Elektroda, vodiczka, post #11337631] Check for new pipework entering neighbouring flats before assuming theft.
How much water can a tiny cistern trickle waste?
A 3 mm continuous stream can exceed 120 m³ in six months—more than many households use annually [Elektroda, saskia, post #11342217] Cistern leaks account for 20–30 % of domestic losses [Waterwise, 2019].
What quick test finds hidden pipe holes?
Close the valve before the meter, open a tap and blow into it. If air moves freely, the line is breached and air escapes through the leak [Elektroda, c4r0, post #11338468]
Can a thermostatic mixer cause unexpected readings?
Yes. Unequal pressure lets water flow from the higher-pressure circuit to the lower through the open mixer, spinning one meter forward and the other backward [Elektroda, music, post #11345330] Install check valves or replace the mixer to stop backflow.
What paperwork protects me from an inflated bill?
Document every test with dated photos, plumber reports, and meter readings. Submit a written objection to the administrator within 14 days of receiving the surcharge, citing Polish Civil Code art. 554. Request a sealed utility inspection; unresolved disputes may go to mediation.
Is dye testing useful in flats?
Yes. Add food-grade dye to the cistern or suspect pipe, wait, and inspect drains or neighbour fixtures for coloured water [Elektroda, Błażej, post #11337653] It isolates leaks without demolition. Avoid strong chemicals that stain permanently.
When should I call the water utility?
Contact the supplier if the meter turns with the inlet valve shut—proof of meter malfunction—or if you find systemic pressure fluctuations (>0.1 MPa) causing backflow [WHO, 2017]. Utilities will bench-test the meter and may credit faulty readings.
Could walls hide 100 m³ of leaked water without damp patches?
Unlikely. A 1 L/min leak would show stains or drip into lower floors within days [Elektroda, vodiczka, post #11341664] Edge case: a pipe leaking directly into a high-capacity floor drain could mask clues, so inspect drains and sump pits.
3-Step How-To: trace a silent water loss
  1. Shut every fixture; record meter position. 2. Close hot and cold stop-cocks one by one, watching the dial to pinpoint the faulty branch. 3. Use a stethoscope or metal rod to listen along the isolated line for hissing.
What if replacing the meter didn’t help?
If a certified new meter still counts, focus on plumbing. Pressure-test each loop at 0.6 MPa; pressure drop >0.02 MPa in 15 minutes signals leaks (typical standard) [Plumbers Manual, 2021]. Suspend floor heating loops—rare but possible water routes—during testing.
Can insurance cover the leak costs?
Most Polish home policies include hidden-leak cover once the source is repaired. Insurers ask for plumber verification and utility bills showing abnormal use. Payouts average €400–€1 200 for water charges and wall repairs [PIU, 2022].
What’s the worst-case failure I should plan for?
Complete pipe burst releases up to 30 L/min, flooding a 60 m² flat in under 90 minutes and damaging structural concrete [FM Global, 2021]. Fit automatic shut-off valves with leak sensors to avoid such losses.
