Passat B6 2008 - Manual Deletion of 'Service Jetzt' Message: VAG+CAN or VCDS?
Marcin_ca1 105339 11
How can I manually reset the 'Service Jetzt' message on a 2008 Passat B6, and do I need VCDS or another diagnostic tool to do it?
You can reset the service reminder manually by turning the ignition off, holding the button with the key, turning the ignition on, releasing that button, then within 20 seconds briefly pressing the MIN button on the left side of the cluster and finally turning the ignition off [#11390957][#13329902] This exact procedure was confirmed to work on a Passat B6 2008 [#15728926] If the manual reset does not work, one reply recommends clearing the inspection with a computer instead [#11392565]
  • #1 11390845
    Marcin_ca1
    Help: 14
    Rate: 278
    The patient is a Passat B6 2008, the "service jetzt" message is displayed, I have tried to manually delete it several times using the following method:
    -hold the key button
    -turn on the ignition
    -release the key button
    -within 20 seconds, press the min button
    This procedure doesn't work, maybe it's long life, but I don't know if that could be the reason.
    I tried gutmann but it didn't help either ehh
    -Do you know any other manual procedures?
    -Can vag+can handle this car or do I need to invest in vcds?
    Regards
    Marcin
  • #2 11390957
    andrzej0769
    Help: 26
    Rate: 163
    Buddy, try this. Deleting the inspection is done as follows:
    1. Turn off the ignition
    2. Press and hold the X button
    3. Turn on the ignition
    4. Release the X button
    5. Within 20 seconds, briefly press the button once
    6. Turn off the ignition
  • #3 11391994
    Marcin_ca1
    Help: 14
    Rate: 278
    The X button is a button with a key on the right side of the counter, do you mean that?
  • #5 11392565
    konrad98-47
    Help: 10
    Rate: 136
    It is best to delete using a computer
  • #6 11392595
    wirus466
    Level 19  
    Help: 22
    Rate: 132
    Po co compute Passat B6 2008 - Manual Deletion of 'Service Jetzt' Message: VAG+CAN or VCDS? r em?
  • #7 13329902
    selukas
    Rate: 22
    buddy, you do that
    1.turn off the ignition
    2. press and hold the button with the key
    3rd in. ignition
    4. release the button with the key
    5. within 20 seconds, briefly press the button on the left side of the counter with the inscription min.
    6. off ignition :)
    this is how it is in my 2.0 tdi 2006 belt, I hope I helped :)
  • #8 15728926
    remes
    Thank you for your advice. It works in Passat b6 2008. Regards
  • #9 16211418
    marix1998
    Rate: 36
    Hello. I have a question
    After deleting SERVICE JETZ with your computer. Will it appear after 15,000 km? Does it need to be programmed somehow?
    Regards
  • #10 16211552
    MarcinS70R
    Help: 52
    Rate: 290
    It will appear in 15,000 km.
  • #11 16212859
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4186
    And what interval was set? Regular 15tkm or longlife?
  • #12 16212962
    marix1998
    Rate: 36
    Hmm. I'll tell you what interval was set, I honestly don't know. Is there any way to change this? So that it would be, for example, 10,000? At the same time as an oil change?
The discussion revolves around the manual deletion of the "Service Jetzt" message on a 2008 Passat B6. The original poster attempted a manual reset procedure involving the ignition and specific button presses, but it was unsuccessful. Various users provided alternative methods, confirming that the correct procedure involves turning off the ignition, holding the appropriate button, and following a sequence of ignition and button presses. Some users suggested that using a computer tool like VCDS is the most reliable method for resetting the service message. There were also inquiries about the service interval settings and whether the message would reappear after a certain distance.
