Is the blind motor with slat rotation compatible with the PLC2011A0/PLC2011B0?
jach49 7527 16
Can PLC2011A0/PLC2011B0 controllers operate a blind motor that both raises/lowers the blind and rotates the slats, and which actuator should be used for automatic window tilting?
Yes—Venetian blind motors with slat rotation all work on the same principle, so compatibility depends mainly on whether the PLC can generate the right pulse lengths, not on a special motor model [#11482914][#11483601] Roller blinds do not have slats; the slat-rotation control described in the thread applies to Venetian blinds [#11481497] The motor uses a simple timing scheme: pulses longer than about 1 second raise or lower the blind, while pulses shorter than 1 second rotate the slats; example values given were about 0.5 s for roughly 45° and 0.3 s for roughly 30° [#11482914] The main requirement for the PLC2011A0/B0 is that it must be able to produce very short pulses, around 0.2–0.3 s [#11481497] For automatic window tilting, one reply linked a Z-Wave window tilt actuator as an example solution [#11480770]
  • #1 11479892
    jach49
    I own a flat where I am installing a smart home system based on PLC controllers (PLC2011A0 and PLC2011B0). I’ve got the lighting and socket power supply sorted. I control the radiators using Honeywell actuators.
    The flat is mainly heated by radiators, though I also have underfloor heating in the bathroom, all controlled via the PLC2011B0. I’m also planning to fit sensors by the windows so that the radiators switch off when a window is open.
    However, I’m having a big problem with the blinds. I can’t find a motor that would control not only the up/down movement but also the rotation of the slats.
    Does anyone know of a motor that would allow me to control both the slats and the up/down movement of the roller blinds using a PLC? Also, could anyone advise me on which actuator to use for automatically tilting a window?
    Please help
  • #3 11481497
  • #4 11482657
    jach49
    Blinds have slats.
    Of course, I’m talking about blinds
    Each blind has slat control.
    I understand that every motor has this capability?
    ...but it won’t work if it isn’t possible to send a pulse within the 0.2–0.3 s range.
    Unfortunately, I don’t understand that.
    In the instructions for the blind controllers, I saw that three wires (up/down) (and N), just like with roller shutters. Does the controller for changing the slat angle send a signal – perhaps a modulated, digital one – to the mechanism? How does the mechanism know when to move the slats?
    I simply don’t know whether it’s possible to force a change in the slat angle by applying a voltage to the mechanism? And for both up and down movements, at that.
  • #5 11482914
  • #6 11483265
    jach49
    The control system looks really cool; now the only question is whether the PLC2011A0 can handle it (whether it can produce such short pulses).
    Can you recommend a motor, or does it not matter and do they all have the same control system?
  • #8 11518865
    jach49
    I’m currently wondering how to create ‘leaving home’ and ‘arriving home’ buttons.
    I’m wondering if it’s possible to do this so that, if I have more than one PLC2011A0 and B0, I can programme a single input on each A0, on which all outputs depend. However, could I programme the A0 responsible for the lighting so that, in addition to its ‘normal’ operation, when the input is set to ‘leaving home’, all outputs can be controlled, for example, by a solar calendar?
    The idea is that when the ‘leaving home’ status is active, A0 opens the blinds, switches the lights on and off at the appropriate times (basically simulating a presence).
  • #9 11522388
  • #10 11523069
    jach49
    I don’t really understand why there’s a variation for the lights and blinds?
    When I leave home, say for a week, I’d like the lights to switch on at a specific time, the blinds to close in the evening and open in the morning (to simulate someone being at home).
  • #11 11526571
  • #12 11759457
    jach49
    I didn’t reply for a while because I was away.
    Yes, I get up at the same time every day and go to the loo at the same time every day. A bit of a bore, perhaps. I tried out this controller at a friend’s place – it’s really worth it. A brilliant bit of kit, and the PLC2011C0 with LED strip support is absolutely brilliant.
  • #13 11762587
  • #14 11800081
    neodym
    Rate: 36
    jach49 wrote:
    I have a flat where I am installing a smart home system based on a PLC controller (PLC2011A0 and PLC2011B0). I’ve got the lighting and socket power supply systems sorted.
    To control the lighting, you’ll need a PLC2011C0:
    http://www.youtube.com/watch?v=2LsKcNTzYeg
    This flat is on one A0 and one C0, without an alarm. The C0 also has more thermostats, outputs for controlling roller blinds, etc.
  • #15 12529655
    siwy337
    I’m also fascinated by the smart home system based on the PLC 2011A0 controller.I’m building a house and intend to use this solution; however, although the manufacturer provides examples of connections https://www.elektroda.pl/rtvforum/posting.php?mode=reply&t=2412436 , I’m not sure how to connect this controller to bistable relays, such as this one bistable-relay-pbm-01-zamel .I’d need a wiring diagram for such a connection – for example, how to do it using, say, diagrams no. 4 or no. 7 from the website mentioned above.And one more thing: the diagrams suggest that five-core cables would be required; does anyone know how to make these connections using three or four cores?? Please help.
  • #17 13550801
    jach49
    The PLC manufacturer has been very helpful and assisted us in finding a solution.
