How to remove a bearing when there’s no space for a puller?
stomat 179880 9
How can I remove a bearing when there is no room for puller jaws behind it?
Use a bearing splitter/peeler, or if that cannot fit, cut the bearing race off carefully with a small angle grinder and then crack it off. Professional pullers exist with two slim jaws ground at an acute angle that can slide 0.5–1 mm under the bearing [#11630725] Another proven method is to crush the outer race in a vice, grind away what remains, and cut it so it comes off easily; this was described as standard practice in service work and said to be 100% effective [#11629258][#11630627] If you use a grinder, first cut the outer race in two opposite places and remove it, then cut the cage and carefully notch the inner race without cutting the shaft [#11631284] Secure the commutator and windings first, because the impeller or rotor can be damaged during removal [#11630327]
  • #1 11629240
    stomat
    Help: 257
    Rate: 1982
    I would like to ask practitioners how, and specifically what to remove the bearing in the situation shown in the picture. There will be no puller tabs between the bearing and the ring next to it. What do you use in this situation? This is an old ZELMER vacuum cleaner, but the problem is universal
    How to remove a bearing when there’s no space for a puller? .
    robokop
    Help: 1763
    Rate: 6371
    I will answer stupidly - puller. A smarter version of this statement is the slogan "bearing peeler." And the blacksmith, it is crushing the outer race in a vice and grinding what remains - so as to cut it, then it will come off without a problem.
    Look.
  • #3 11629343
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    Once, I quickly made such a device out of two flat bars and a vice.
    Karlheinz
    Help: 44
    Rate: 145
    Secure the commutator and the winding and do as your colleague wrote robocop with the puller method, there is a possibility of damage to the impeller
    kot mirmur
    Help: 206
    Rate: 561
    The method described by the Robocop col. Is practiced even in authorized power tool services. That is 100% efficiency!
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3373
    There are professional presses for such cases, which have two jaws ground at an acute angle going under the bearing. It is enough for them to slide in to a depth of 0.5-1 mm. Something similar to the item in this set, bottom right. http://www.bass-tools.eu/194-551-thickbox/hyd...czny-zkieta-sciagaczy-do-lofinans-bp-3171.jpg
  • #7 11631281
    DwoMa
    Help: 6
    Rate: 23
    If you have an angle grinder, put a small disc on it and get to work. First, cut the outer flange of the bearing in two opposite places and remove it, then cut the ball basket and you will see the inner flange. Cut it carefully, being careful not to cut the rotor axis. You can cut it in two places. Then you take the hammer and, resting on the rotor's anvil on the notched flange, strike it vigorously. It should break at the incision and after the competition.
  • #9 11631369
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    There are small pullers for small bearings.
  • #10 11631479
In situations where there is insufficient space for a puller to remove a bearing, several methods can be employed. One approach involves using a vice to crush the outer race of the bearing, allowing for easier removal. Alternatively, a custom device made from flat bars and a vice can be quickly fabricated. Professional presses with angled jaws designed for bearing removal are also available. For those with an angle grinder, cutting the outer flange of the bearing and then the ball basket can facilitate removal, followed by careful hammering to break the inner flange. Safety precautions, such as protecting against flying fragments, are advised during the process.
