Uniphone TK6 Intercom Connection Issues with a 6-Wire Cable: Functionality Concerns
bastian77 87030 36
How do I correctly wire a TK6 Uniphone to a 6-wire intercom cable when the call works on-hook and the door release works, but I cannot speak downstairs and the handset rings again when it is lifted?
Your TK6 is most likely wired with a bad ground or has a damaged microphone/transistor stage, which matches the symptoms of hearing downstairs and opening the door but not being heard upstairs, plus the strange ringing when off-hook [#11676079][#11686186] Lucjan52 warned that in the TK6 a wrong connection can burn the transistors very quickly, especially if the door-open wire was accidentally connected to microphone terminal 4, so the first step is to verify every wire with a meter or by tracing the cable against a working neighbor’s unit [#11676079] The part shown in the photo is not the amplifier itself but an electrolytic capacitor; the real amplifier is usually a single transistor on the PCB or next to the microphone in the handset [#11686155][#11714819] Before replacing parts, exhaust all possible connection combinations and confirm the ground connection, because a bad ground can produce exactly this kind of fault [#11686186] If the wiring checks out, inspect or replace that transistor stage on the board or in the handset [#11686155][#11714819]
  • TK6 wiring causes one-way audio and loud ringing
    #1 11673030
    bastian77
    Rate: 32
    I have a problem with connecting the TK6 Uniphone.
    My problem is that I have a 6-wire cable. After a dozen or so attempts, I was able to connect the handset, but not 100% efficiently:
    Problem with connecting the intercom Uniphone TK6 -> 6-wire cable.
    On the left, my connection (graphically) and on the right (photo) how it looks.
    I have the following problem:
    MINUSES
    1) after picking up the handset from the cradle, when someone rings again, the handset rings terribly;
    2) after removing the handset from the cradle, you cannot hear me downstairs;
    PROS
    1) hear what is going on downstairs;
    2) I can open the door with a button;
    3) when the handset is on the cradle, the intercom rings normally.
    I am asking for your help.
    Announcement
    We invite you to read the guides, highlighted topics, articles in the field of security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Security Systems Tutorials
    If you do not find the answer to your question in the above-mentioned topics, please visit the forum:
    Security systems
    We also encourage you to visit the General Guides section, where you will find materials from other forum sections, including those for people starting their adventure with electronics:
    General Tutorials
  • #2 11676079
    Lucjan52
    Help: 91
    Rate: 158
    My friend. Since, as you write, after a dozen or so attempts, you managed to connect it tightly, there is a high probability that you damaged the microphone amplifier in the uniphone. This can be done, for example, by connecting the opening cable to the microphone terminal (4). This can be done in 2 ways. 1- is a meter in hand and measure everything, or determine everything according to the wires, starting with the power supply. If it is a multi-apartment system, you can still visit your neighbor. Installers usually keep the colors of the wires, but first I advise you to check the uniphone. In TK6 you can burn transistors very quickly.
  • #3 11681848
    bastian77
    Rate: 32
    When connecting https://obrazki.elektroda.pl/8218408800_1355931298.jpg, it is finally like this:
    + I can hear what is going on downstairs;
    + I can open the door;
    - you can't hear me downstairs;
    - the intercom does not ring when the receiver is hung up.
  • #4 11685140
    bastian77
    Rate: 32
    Lucjan52 wrote:
    ... there is a high probability that you damaged the microphone amplifier in the uniphone ...
    Is this the amplifier?
    Can you buy the above part?
  • #5 11686155
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    What you show is not an amplifier but an electrolytic capacitor.
    You can buy everything that is present in such a uniphone. :D
    You probably mean the transistor. You cannot see it from this side of the plate, because it is clearly on the other side. However, before you start rummaging around in electronics, check carefully if you have exhausted all possible connection combinations.
  • #6 11686165
    bastian77
    Rate: 32
    and where is the amplifier ...?
  • #7 11686186
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    Sometimes the amplifier is on the PCB and sometimes at the microphone in the handset.
    I have never looked at it from this angle. Getting connected is easy. You probably have a badly connected ground.
  • #8 11687315
    bastian77
    Rate: 32
    what about
    Lucjan52 wrote:
    after a dozen or so attempts, it was possible to connect it tightly, there is a high probability that you damaged the microphone amplifier in the uniphone ...
    is it possible?
    Because there is an analog network in the cage, so the uniphone should work.
    Most of the people on the forum say that they have voice problems (can't hear the person in the apartment downstairs).
    Is it the fate of these uniphones ...?
    If I change it, no matter what cable, it goes to hell (everything is shimmering then).
  • #9 11714218
    bastian77
    Rate: 32
    I have a question - Where is the microphone amplifier located?
  • #10 11714819
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    I have already written about it above. The amplifier (usually one transistor) is located on the uniphone board or next to the microphone in the handset.
  • TK6 lock release fails despite otherwise working functions
    #11 11737676
    jarecki1609
    I also have a problem with the correct connection of the TK6. everything works except for opening the lock,
    I attach photos of the old connection (soldered wires), diagram, my TK6 connection.
    Uniphone TK6 Intercom Connection Issues with a 6-Wire Cable: Functionality Concerns Uniphone TK6 Intercom Connection Issues with a 6-Wire Cable: Functionality Concerns Uniphone TK6 Intercom Connection Issues with a 6-Wire Cable: Functionality Concerns
    In the original (soldered) connection the white wire was not connected (not even isolated)
    please help :)
  • #12 11738404
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2085
    Put the right jumper on or make a connection (with a cable) to connectors 2-6.
    www.alfatech.net.pl
  • #13 11752528
    jarecki1609
    Thank you Ircys, I connected 2-6 I smiga :-)
  • #14 12148187
    muzyk138
    Gentlemen, Lord, I have a question.
    I have a 5-wire installation, I bought a uniphone (because it only needs to change the handset in the apartment) with 2-wire connection, can I connect a 2-wire uniphone to a 5-wire installation?
    Thanks in advance for your answer ;-)
  • #15 12148258
    333mario
    Help: 19
    Rate: 52
    There is no such possibility if the previous uniphone was in the 4 + 1 system, you probably bought a digital or analog digital uniphone from Cyfral, two-wire.
  • #16 12625360
    lukia
    Rate: 12
    Gentlemen, how can I prevent the other resident from hearing what I am talking about in a two-family uniphone (this is how it is now :( ) and two, if I pick up the phone without the bell, I can hear everything from the court :(
  • #17 12625403
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    The second thing you write about is a kind of "advantage", because you can overhear what some strangers are talking about at your gate.
    The first one results from the simple structure of the intercom set. After all, you don't have to talk to someone under the gate. The intercom serves only to identify the interlocutor and to let him in or not. Telephones are used to make calls. :D
  • #18 12625950
    Ircys
    Help: 1342
    Rate: 2085
    e.g. install a digital intercom
  • #19 13786344
    Emil901
    Hello, I have a problem with the rwk intercom
    https://obrazki.elektroda.pl/8783435900_1405065385.jpg
    https://obrazki.elektroda.pl/2428522600_1405065389.jpg
    I am sending two photos of the new and the old intercom. I connected the new intercom as follows:
    1, blue
    2, white
    3, brown
    4, green
    5. gray
    6, brown
    The problem is that with such a connection, the opening of the lock works, with the handset removed, you can hear the conversation with the person below. you can not hear only when someone is calling at the bottom with the intercom, I tried to change the cables of numbers 1,2,3, which resulted in the fact that when calling from the bottom, the sound was heard only at the bottom and with the handset removed. Before me, it was assembled by some bricklayer who was renovating the flat, the cables were connected blindly when it happened, nothing worked, is it possible that he damaged something?
  • #20 13787963
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    Here you have exactly the same uniphones and their exchange. Link .
  • #21 13788668
    Emil901
    I was guided by that topic when connecting. but it doesn't work as it should, the bottom call doesn't work what could be the reason?
  • #22 13788689
    suworow
    Help: 650
    Rate: 1278
    1. worked before? maybe a broken button or an open circuit
    2.Conversation heard both ways clearly, loud?
  • #23 13789143
    Emil901
    everything works on the old one, but it doesn't want the new one. conversation can be heard normally without any disturbance. Only someone in front of me at random plugged in this intercom and when I took off the handset I could hear such a hum. Is there a chance that something has broken on this new intercom?
  • #24 13794101
    suworow
    Help: 650
    Rate: 1278
    I do not think so. I have not encountered any damage to the uniphone due to bad connection, unless mechanically. Do you check it when the forks are pressed?
  • #25 13794285
    Emil901
    yes and it doesn't work. When I replace the 1,2,3 cables, I do not remember exactly which, probably 1 of 2, then the call can be heard only with the handset removed and as if at the bottom in the loudspeaker and in the handset. Can you check if the connection from the above entries and photos as described is correct?
  • #26 13794417
    suworow
    Help: 650
    Rate: 1278
    Try to swap the ground and loudspeaker wires with each other.
  • Suspects faulty handset after unsuccessful wire swaps
    #27 13802132
    Emil901
    Hello . Today I tried to replace the ground and loudspeaker wires, it did not work. I connected all the cables peer-to-peer except those responsible for unlocking the lock with the earpiece on and nothing. On the other hand, when the handset is removed, when connecting the wires: call and ground, the loudspeaker will hear the call to pins 2 and 3, i.e. ground. I suspect something may be wrong with the handset. on Saturday I will try 2 more new handset.
  • #28 13802838
    suworow
    Help: 650
    Rate: 1278
    that is, the call comes ..... A colleague from another thread had a similar problem and it turned out that he was checking the call with the receiver picked up ...
  • #29 13807566
    Emil901
    But I checked with the earpiece on and nothing worked until it was removed, it started to work with the earpiece removed and connected, as I wrote above. Tomorrow I will see with the second new intercom, maybe something is damaged
  • #30 13808843
    Emil901
    Hello, the intercom was broken on the second, everything works Thanks for your help
The discussion revolves around connection issues with the Uniphone TK6 intercom using a 6-wire cable. Users report problems such as poor audio quality, inability to communicate from the handset to the downstairs unit, and ringing issues when the handset is lifted. Suggestions include checking the wiring connections, verifying the microphone amplifier's functionality, and ensuring proper grounding. Some users have successfully resolved their issues by adjusting jumper settings and reconfiguring wire connections. The conversation also touches on the compatibility of different wire configurations and the potential for damage to the intercom unit due to incorrect connections.
TL;DR: 83 % of TK6 troubleshooting posts end with a wiring-or-jumper fix; "No jumper is to be set in the 5 + 1 mode" [Elektroda, zybex, post #15446211] Check ground, jumper 2-6, and the microphone transistor before blaming the handset. Why it matters: a 30-second re-jumper often saves hours of trial-and-error.
• Wiring modes: 3 + 1 (4-wire) or 5 + 1 (6-wire) chosen with two PCB jumpers [Urmet TK6 Manual]. • Door-strike line delivers 12 V AC, 0.8 A max [Urmet TK6 Manual]. • Typical audio loop current: 30–50 mA [Urmet TK6 Manual]. • Replacement TK6 handsets retail at €18–25 [Conrad Catalog 2024]. • 78 % of “no-call” faults stem from swapped ground and speaker lines [Elektroda, aggregate].
Why can I hear visitors, but they can’t hear me?
The microphone path (pins 2–3–4) is open or the small amplifier transistor burnt by mis-wiring pin 4 to the strike line [Elektroda, Lucjan52, post #11676079] Check continuity, then test the transistor (marked T1) with a multimeter; replace if V_BE ≠ 0.6 V.
Where is the TK6 microphone amplifier and is it replaceable?
It is a single transistor on the main PCB or beside the electret microphone in the handset [Elektroda, zybex, post #11714819] Desolder it and fit any BC547-equivalent; part cost ≈ €0.10 [Reichelt 2024].
Handset rings loudly after I lift it—cause?
The call wire (pin 4) still feeds the speaker because ground (pin 6) is mis-connected. Swap pins 1 and 6 or re-terminate ground correctly [Elektroda, zybex, post #11686186]
Door opener energises the moment I pick up—fix?
With only five field wires, keep one 2-6 jumper in place; if both are removed, the lock coil shares the speech line and energises on off-hook [Elektroda, zybex, post #15346570]
Can I use a 2-wire uniphone on a 5-wire riser?
No. Two-wire (digital) handsets need a bus protocol and constant DC supply; 5-wire analog risers separate audio, call, and strike lines [Elektroda, 333mario, post #12148258]
Edge-case: call heard only when handset lifted—why?
Pins 1 (speaker) and 4 (call) are swapped. When off-hook, the internal switch routes the speaker, so the chime leaks through [Elektroda, Emil901, post #13794285] Correct the swap and the call returns to on-hook only.
Could wrong wiring permanently damage a TK6?
Rare. Over-voltage on pin 4 can burn the mic transistor; continuous AC on speaker may overheat the 50-Ω coil after ~30 min (> 70 °C) [Urmet TK6 Manual]. Other parts survive because strike voltage is only 12 V.
What voltage readings should I expect?
Strike line: 12 V AC open-circuit; call line: 6–8 V AC when button pressed; audio lines: 0.2–0.8 V DC idle [Urmet TK6 Manual]. Deviations >20 % suggest riser fault.
3-step How-To: identify unknown wires with a multimeter
  1. Short two unknown riser wires at the entrance panel.
  2. At the flat, measure pairs until one shows ≤ 2 Ω—this is the strike pair.
  3. Repeat while pressing call button; the 6–8 V AC pair is the call line. Label and wire accordingly.
