Drilling an 8mm Hole in Cast Iron Furnace Door: Methods & Precautions (Thickness approx. 4-5mm)
Big Lebowski 41883 6
  • #1 11677479
    Big Lebowski
    I have a strong need to drill a hole in the cast iron, some fi8. This is the door to the CO furnace, I need to screw the insulation. The door thickness is about 4-5 mm (I have no way to measure it more precisely).
    Question: will it break, not break? I have no experience with cast iron, I only know that it is quite brittle. Only for how much?
    Regards, Paweł
  • #2 11677492
    pawel16150
    Level 30  
    Help: 204
    Rate: 640
    Drill slowly, it will not break.
  • #3 11677497
    kwantor
    Help: 352
    Rate: 1227
    Why would it break - on the contrary, any holes prevent the material from breaking in which some stresses arise.
    You can drill slowly and you can drill quickly.
  • #4 11677525
    Big Lebowski
    Thanks for the answers. I work tomorrow or the day after :)
  • #5 11678412
    robokop
    Help: 1763
    Rate: 6370
    Drill normally, as in any other iron - it's not glass. Sharp drill bit required.
  • #6 11680804
  • #7 11681114
    robokop
    Help: 1763
    Rate: 6370
    tomo1885 do you have any other equally "wise" questions?
Drilling an 8mm hole in a cast iron furnace door, approximately 4-5mm thick, is feasible without breaking the material. Users recommend drilling slowly and using a sharp drill bit, as cast iron is not as brittle as glass. The consensus is that drilling will not cause the door to break, and any holes may actually relieve stress in the material. Proper technique is emphasized, with a focus on using appropriate tools for the task.
