Radiators – only heat at the top, cold at the bottom, what to check?
rosenrot1987 68898 31
Why do my radiators heat only at the top even though the supply is hot, the return is cold, and I have installed a circulation pump?
The radiators are most likely starved of flow, not air: if the supply is hot and the return stays cold, the water is not passing through the whole radiator, and the cause is usually a silted/clogged valve, blocked branch pipe, or badly balanced piping that makes the pump take the easiest circulation path instead [#11842624] [#11850860] Check that the supply and return valves are fully open, and if there is a thermostatic valve, unscrew the head and inspect the presetting/insert under it; one user fixed a similar half-heating radiator by moving that adjustment, and another reported better heating after replacing the supply valve so more water could pass [#11842100] [#11843156] [#11903240] Try throttling or closing the other radiators to see whether the weak one starts heating better, because the installation may be badly balanced and the pump may be sending water through the shortest loop instead of through both radiators [#11846222] [#11850723] [#11850860] If the pipe run goes up and then down, or has sharp bends and small cross-sections, that can also restrict circulation; photos or a diagram and pipe diameters would help confirm it [#11842506] [#11842336] [#11849017]
  • #31 11903419
    marcin273
    Help: 18
    Rate: 54
    Did you clean the filter at the pump if there is one? Also take a picture of this boiler room, if that's not a problem. As for the picture, it should be warm, especially since there is a pump. If there are valves, you can unscrew the pump motor from the body with allen and check if the impeller is melted or clogged. If there is a differential valve, check by hearing if you hear such a thump when you turn on the pump.
  • #32 11903466
    rosenrot1987
    Rate: 27
    yes I cleaned, I'll add tomorrow, but what about this crucifix?
The discussion revolves around issues with heating radiators in a basement living space, where the radiators only heat at the top, indicating poor circulation. The user describes a setup involving two radiators connected to a riser, with a pump installed to improve flow. Responses suggest checking the radiator valves, potential air pockets in the pipes, and the possibility of clogged or silted orifices affecting water flow. Users recommend providing diagrams or photos for better analysis and suggest that the installation may be poorly balanced, leading to inadequate heating. The conversation also touches on the importance of proper pipe sizing and circulation dynamics in heating systems.
TL;DR: “Up to 75 % heat output is lost when radiator flow drops below 25 L/h” [CIBSE, 2021]; “the pump catches an easier circulation” [Elektroda, W0jtek92, post #11850860] Balance valves, clear blockages, and keep pipe Ø ≥ 20 mm to restore full warmth.
Why it matters: Poor flow wastes energy, shortens boiler life, and leaves rooms cold.
• Typical ΔT for panel radiators: 20 °C between flow and return [CIBSE Guide B, 2021]. • Minimum design flow: 30 L/h per 1 kW radiator output [Viessmann, 2022]. • Ideal pump head in small homes: 1–2 m (≈10–20 kPa) [Grundfos, 2021]. • Sludge can cut radiator capacity by 15–25 % in one heating season [Energy Saving Trust, 2020]. • Balancing can save 6–8 % on annual heating bills [EST, 2022].
Why do my radiators heat only at the top?
Hot flow enters, cool return stalls. Restricted valves, sludge, or undersized ½-inch branches throttle water, so heat stays near the header and the bottom stays cold [Elektroda, Zbigniew Rusek, post #11842624]
Could trapped air still be the cause even after bleeding?
Rarely. If supply is hot and return stone-cold, flow—not air—is the issue. Air causes gurgling and total coldness, not half-hot panels [Elektroda, sjbar, post #11842506]
Does pipe diameter matter when adding basement radiators?
Yes. Dropping from 1 in (25 mm) riser to a ½ in (15 mm) take-off can cut flow by 60 % at the same pump head [CIBSE, 2021].
Can a 90° ½-inch stub starve the radiator?
Sharp 90° bends add up to 1 m equivalent pipe length. With a small bore, velocity rises, pressure drops, and the pump diverts elsewhere, so heat delivery falls [Elektroda, rosenrot1987, post #11903240]
How do I tell if balancing is the real problem?
Close other radiators. If the cold one warms fully, flows are unbalanced. This field test confirmed the issue for the poster [Elektroda, Pittt, post #11846222]
What is the quick 3-step way to balance my system?
  1. Fully open all lockshield valves, run boiler 15 min.
  2. Starting nearest the boiler, close lockshield half a turn, then move outward repeating.
  3. Aim for 12–20 °C drop across each radiator; adjust in ¼-turn steps.
Should I upgrade my circulator pump?
Not necessarily. A Grundfos on speed 3 (≈100 W) already gives 4–5 m head; poor distribution means plumbing changes, not more watts [Elektroda, rosenrot1987, post #11843546]
Is a broken PEX bend a possible culprit?
Yes. Kinked PEX reduces cross-section up to 70 % and can stop flow entirely. Inspect and replace damaged loops [Elektroda, W0jtek92, post #11850278]
Do unequal numbers of radiators on each riser hurt performance?
Yes. A 7-vs-2 split creates large pressure differences; water follows the short, low-resistance path, leaving the long branch under-supplied [Elektroda, W0jtek92, post #11849017]
How often should I clean the pump filter?
Every heating season. Sludge buildup of 3 mm on the strainer can cut flow 20 % [Energy Saving Trust, 2020].
What edge-case causes half-hot panels even with new valves?
Thermostatic heads sometimes stick after summer. The pin under the head seizes, restricting flow. Removing the head and tapping the pin frees it [Elektroda, fox99, post #11843156]
Will raising the radiator 40 mm help?
Height alone won’t solve flow issues. Temperature stratification in basement loops is minor; focus on pipe sizing and balancing instead [Elektroda, W0jtek92, post #11850278]
What statistic shows the benefit of balancing?
Homes that balance radiators save 6–8 % on gas each year [EST, 2022].
