Server Connection Error on Konica Minolta bizhub c220: Scanning Issue After Recent Installation
geomad 36492 5
  • #1 17130555
    geomad
    Rate: 9
    I think this problem is trivial but I can't solve it. A technician installed a copier and everything was ok. Printed and scanned over the network without a problem. A few days ago I tried to scan and jump out: "server connection error" , Result: "deleted due to error" . The service technician who brought the copier - installed everything and it was ok, apparently I mixed up something.
  • #2 17135004
    rysieklubicz
    Help: 8
    Rate: 11
    How did the device scan? to e-mail or to a folder, if you probably have dhcp set for the ip address for the folder and it has changed
    after restarting the computer.
  • #3 17135014
    copyman
    Photocopiers specialist
    Help: 1107
    Rate: 836
    If to folder then set the computer by host name. Check by the way whether your computer password-protected sharing has not returned to the standard "enabled" or whether the firewall and anti-virus allow the scan.
    C.
  • #4 17135028
    geomad
    Rate: 9
    I had set to the (SMB) folder. It turns out that the main reason could be the win10 update and the SMB protocol stopped working. I'm trying to bet on FTP (same from folder).
    Rysieklubicz -> to the folder and worked for a month (I have had a copier for a month). I rarely scan so I'm not sure what happened, as I wrote above because a colleague had the same problem.
    copyman -> I checked everything before. Once again, I'll transfer sharing.
  • #5 17135104
    copyman
    Help: 1107
    Rate: 836
    Every Win10 update will cause something like this ... Go to the properties of the folder you are scanning, sharing and select the network and sharing center. Then expand All Networks and check if password protected sharing is "off". If it is enabled, click disable and save the changes. It helps 99.9% :)
    C.
  • #6 17135124
    geomad
    Rate: 9
    copyman -> thanks a lot, we made it !!! Problem solved!
