How to Initiate Forced Descaling on Krups EA8260 Coffee Machine
asdrat0r 30843 3
  • #1 11960846
    asdrat0r
    Hello. I bought this coffee machine a year ago. Since then, I have never had information about performing a descaling cycle. I have cleaned with tablets 5-6 times. Does anyone on the forum know how to force the descaling cycle in this coffee machine? There is nothing in the manual about forcing descaling, only that it will inform you if necessary.
    Regards
    M
  • #2 15980164
    pp.vidi
    Rate: 13
    Pour water into the tank up to the calc level. Dissolve the tablet. Turn on hot water 300ml. When finished, pour out the rest of the solution from the tank and pour in clean water. Repeat the 300ml hot water cycle at least twice. And after descaling.
    However, it will not be saved in the machine`s memory.
  • #3 17588793
    Janzet66
    Rate: 13
    Giving the method of descaling in the answer is only an emergency method, because this process is carried out with cold water without heating. To start the automatic cycle, you must activate the counters /service-settings/, including the activation of the filter, even without its physical installation. And after the problem everything should start automatically. Regards.
  • #4 19025207
    grustom
    Rate: 8
    After all, pp.vidi wrote
    so the descaling process provided by pp.vidi takes place in hot water and is absolutely correct. Regards
