Mono vs Stereo Issue: Sound Only in Left Ear with Creative Fatality HS-800 Mic
adamos24h 24141 4
  • #1 12121711
    adamos24h
    Hello everyone very warmly. I have a problem. Well, when I record something with my microphone, which comes with the Creative Fatality HS-800 headphones, the sound is heard only on one left ear. What annoys me the most is that I've recorded with this microphone before and everything was fine. I heard that the problem can be in mono and stereo what's the deal. I have a Realtek HD Audio sound card integrated into the motherboard.
  • #2 12121731
    pitrala1
    Help: 129
    Rate: 111
    what are you recording with?
  • #3 12121764
    adamos24h
    Audacity, Action, even the recorder, whatever the same everywhere. But I discovered something new. When in the Realtek HD Audio manager I select the interference suppression or acoustic echo removal options, I can hear me on both headphones! Unfortunately, I prefer not to use these options, because then the voice is clearer, and I will denoise myself in Audacity. I used to do that and it was on two, now I have sound on one handset. Why when I use these options I only have one!?
  • #4 12306276
    Gigaarmada
    I know that the answer is long too late, but it doesn't matter who else will find it useful because headphones are a horror for every user. Either something is not connected or the cables break or break off.
    I'm no expert, but it seems to me that each microphone is monophonic. In most cases, the signal from the micro in headphones for computers is separated by a bundle of cables into the left and right channels, or it is done only on the plug. Of course, if it is a mono microphone, then mono signals can be passed through a special mixer and then the sound is pseudo stereo, as in the case of, for example, Team Speak 3 (you transmit mono and they hear you in stereo).
    But it does not matter.
    You can take a look at your headphones. What is the plug with micro (stereo or mono). If it is stereo and you only have sound in one earphone and you are sure that the mixing program on your computer is working correctly, then it is worth checking how it is connected with a cable inside because the microphone transmits a mono signal ...
    I once bought a Saitek Pro Flight Headset that worked fine in both channels when I used the microphone. I mean, when I had the microphone listening turned on to hear my voice in the system, it reached the right and left earbuds and I didn't have to combine software like my colleague above. But the cable was worn in one place and I had to replace it with a new one, because unfortunately the quality of the cable was poor and even repairing and playing with soldering and shortening the cable gave a short-term effect. When I wanted to replace the cable with a better quality, one that has everything in one, during the exchange I came across a problem with the microphone.
    After a quick replacement of the cable and connecting to the computer, only the sound from the microphone could be heard in only one earphone, which surprised me ... I didn't want to modify the plug, because it would look ugly later (one original, the other modified). So I bought 2 stereo cables and used the microphone and headphone connections separately. The thing about the microphone is that the cable cannot be patched. It must consist of a single piece. From plug to microphone connection. Any tampering with soldering, cable connections or a poorly insulated plug has an impact on quality. If we use the whole original cable then additional interference can be avoided.
    In order to have sound in both headphones from the microphone, you need to allow the signal from the micro to be transmitted to the computer on the left and right channels. That's like stereo. So I connected the microphone by jumpering the wires from the right and left channels. (for the lazy, a similar jumper can be made on the plug by connecting the cable to the Left and Right simultaneously). After connecting to the computer, then the sound from the micro sounded in both headphones, and this is how the microphone should work. To this day I use these headphones and the sound is clear without interference, so sometimes it's worth knowing how what works and how it should be connected.
    ;) Greetings.
  • #5 13575783
    morfeusz1202
    I have the same problem, but the solution given by the user above me does not bring anything, besides, I doubt that it was the fault of the cables because I have new headphones and nothing has changed, but if in the Realtek HD Audio manager I select interference suppression, the voice will be recorded normally :|
