Residential Heat Pumps: Satisfaction, Installation & Types - Seeking West Pomeranian Insights
markoopoloo 94722 32
How can a homeowner assess whether a heat pump is suitable, choose the right type and installer, and avoid costly installation mistakes?
A heat pump can be very satisfactory and economical, but only when the system is correctly designed and installed; one user reported seven years of trouble-free use and about PLN 800 in heating costs for a 150 m² home, with substantial savings versus electric or gas heating [#12149002] Obtain an accurate heat-demand calculation, because oversizing increases equipment and ground-source costs while undersizing causes electric-backup operation and higher bills [#12163257] For ground-source systems, compare a cheaper horizontal collector—which needs substantial land and restricts later development—with vertical boreholes, and design a properly sealed, insulated foundation-wall penetration [#12163257] Use low-temperature underfloor or wall heating rather than conventional radiators, pay attention to pump noise, and provide a properly designed lower source with a backup heat option; a basement can help with soundproofing [#12150937] [#12163257] Select an experienced specialist and verify completed installations, since poor design or workmanship can reduce efficiency and cause failures [#12149002] If natural gas is readily available, include its lower installation cost in the comparison, because a heat pump may not be the better investment; where gas is unavailable, the economics may be more favorable [#12163257]
  • #31 15497866
    andrzej lukaszewicz
    Help: 626
    Rate: 2122
    wnoto wrote:
    andrzej lukaszewicz wrote:
    The cost of the (underground) tank with the design and connection to the house is PLN 8,500. That is about 2x as much as the average gas connection from the "pipe". So the client only spent about 4,000. more than with natural gas, and the cost of gas alone is comparable. Certainly, it is also a cheaper solution than a coal-fired boiler room.
    How much "tank" gas is then available. Please enter the price per liter.
    Propane? or propane-butane?
    The customer bought a mixture of 1.25 / l in the summer of 2015. The tank in the ground maintains the temperature of 6-7 degrees Celsius, so there are no problems in frost.
    Now he refueled fully (not being sure of the sensor's readings) last week and gas came in for ... PLN 2100. It heats from October to the end of February. The house is overheated in my opinion, because May 23-24 degrees Celsius. DHW for 3 people and a gas cooker.
    I paid more for gas from the pipe, because it did not decrease by 50%. At the moment, it is at these prices that the heat pump fails, especially since the investment costs are 4x higher.
  • #32 15498295
    wnoto
    Help: 58
    Rate: 744
    The customer bought the mixture at 1.25 / l in the summer of 2015.
    Well, that's a great price. If he was buying that much back then when the salary was more expensive then ... now he will buy 1 PLN / l?
  • #33 15785297
    Saberity
    Installing a heat pump does not have to involve drilling or destroying the garden. The solution is air-to-water or air-to-air heat pumps. They can be installed at home or outside. They are basically maintenance-free and provide hot water for washing and for whatever.
The discussion revolves around residential heat pumps, focusing on user satisfaction, installation experiences, and types of heat pumps. Participants share insights on the cost-effectiveness of heat pumps compared to traditional heating methods, with one user reporting annual savings of approximately PLN 4,000 compared to electric heating. Key considerations for installation include the type of heat pump (ground vs. air), noise levels, and the importance of proper installation to avoid inefficiencies. Users emphasize the necessity of underfloor heating for optimal performance and caution against poorly designed systems. Recommendations for local installation companies and specialists are provided, along with discussions on the economic viability of heat pumps, particularly in relation to existing heating systems like gas. The conversation also touches on the importance of understanding heat demand and soil conditions for effective heat pump operation.
TL;DR: 150 m² home owners report “about PLN 800 a year” for heating after switching to a ground-source heat pump [Elektroda, eidur, post #12149002] “Noise can rival an old Minsk fridge” [Elektroda, piotr_boncza, post #12150937] Correct design and soil match cut bills by 50-65 % (EHPA 2022).
Why it matters: Picking the right pump, loop and installer decides if you save or overpay for the next 20 years.
• Seasonal COP: ground 3.5–5.0; air 2.5–4.0 (EHPA 2022). • Horizontal loop needs 1.5–2.5 × heated floor area (Fraunhofer 2021). • Borehole drilling West Pomerania: PLN 80–120 per m for 80–120 m depths [Elektroda, piotr_boncza, post #12163257] • Reported running cost: PLN 800 / year for 150 m² floor heating [Elektroda, eidur, post #12149002] • Typical indoor sound level: 45–55 dB(A) at 1 m (Daikin spec 2023).
How much can a ground-source pump cut annual bills?
Forum data show PLN 800 for 150 m² versus PLN 2 400–4 800 for gas or direct electric, a 60-80 % saving [Elektroda, eidur, post #12149002] EHPA field studies confirm 55 % average savings across Europe (EHPA 2022).
Ground or air source—what suits clay soil?
Clay conducts heat well but is hard to trench. If plot area is small or digging tough, choose vertical boreholes or an air-to-water unit placed outside [Elektroda, piotr_boncza, post #12163257] Boreholes cost more up-front yet give stable COP in frost.
Can I hook a pump to my existing radiators?
Possible, but expect lower COP. Radiators need 55–70 °C water; pumps deliver 30–45 °C efficiently. A user with radiators and cheap gas was advised the switch would never pay back despite PLN 3 500 Chinese unit cost [Elektroda, William Bonawentura, post #13065589]
Does noise really matter?
Yes. Basement mounting plus acoustic mats can cut emitted noise to 35 dB in living areas. One installer warns some pumps “make noise like old Minsk” if placed badly [Elektroda, piotr_boncza, post #12163257]
What emitter system works best?
Low-temperature floor or wall heating maximises COP. Forum experts repeat: “Not radiators” [Elektroda, wnoto, post #12947137] Aim for ≤35 °C supply water per EU heat-pump design guide (EHPA 2022).
How do I size the pump correctly?
Follow this three-step check:
  1. Order a heat-loss audit at −20 °C design outdoor temperature.
  2. Select pump capacity at 90-100 % of that loss.
  3. Match loop length to 25–35 W per metre for horizontal, 50–60 W per metre for boreholes. Oversizing wastes money, undersizing triggers electric backup [Elektroda, piotr_boncza, post #12163257]
Are Polish subsidies available?
Yes. The “Czyste Powietrze” program reimburses up to 45 % of eligible pump costs for households under set income caps (NFOŚiGW 2023). Submit audit, invoice and proof of disposal of old boiler.
What’s an edge-case failure to watch for?
If the loop hits 0 °C for weeks, ground moisture freezes, stops circulation and forces the electric heater on, tripling costs [Elektroda, piotr_boncza, post #12150937]
Who can inspect or install near Czaplinek?
Forum users recommend Mr Marek (tel. 509 764 561) hailed as “the best PC specialist in Pomerania” [Elektroda, eidur, post #12153989]
What routine maintenance is needed?
Check brine pressure and strainer yearly, rinse evaporator fins for air units, and update controller firmware. Typical visit costs PLN 300–500 (Installer quotes 2023).
