Lawn Mower Oil Differences: B&S 6KM Engine, Castrol Magnatec 5W40 Usage & Compatibility
djpits 91965 17
Can I use Castrol Magnatec 5W40 in a Briggs & Stratton 6KM lawn mower engine, or will it damage the engine?
Do not use 5W40 if you want the safest advice from the thread; the recommended oil for these B&S mower engines is SAE 30, and several replies warn that 5W40 is too thin [#12252592][#18810417] Briggs & Stratton-approved alternatives mentioned are detergent oils rated SF/SG/SH/SJ or higher, and users report good results with 10W40 or 15W40 automotive oil instead [#12416906][#12415080][#18810417] The smoking is more likely caused by a dirty or wet air filter, too much oil, mowing on a slope that tilts the engine, or worn rings/cylinder than by the oil brand alone [#12252592][#12416724][#2056710] If the head/cylinder has burnt oil deposits and the spark plug is oily, clean the carbon, replace the plug and air filter, and inspect for ring or cylinder wear [#12254315][#2056710] Keep the oil level at the specified amount (about 0.6 L was mentioned) and check it more often if you use a thinner multigrade oil [#12252592][#12416906]
  • #1 12252315
    djpits
    Rate: 15
    Hello, I have a B&S 6KM mower which is already 5 years old and it is quite smoking while working (it apparently takes oil), some mower oil was poured there before. Currently, I have a Castrol Magnataec 5w40 on hand and I wonder if I put it in it will finish the engine? - anyway, the whole cutter is already falling apart and it cost 2600- :(
    I would ask for advice.
  • #2 12252592
    jajacek120
    Level 19  
    Help: 32
    Rate: 59
    Mineral oil SAE 30 should be used for B&S engines. Is the oil running low?
    Smoke may be caused by a dirty, wet air filter.
    Is the oil level too high by any chance - pour in 0.6 liters.
  • #3 12252790
    djpits
    Rate: 15
    Yes, I already know that sae30 al e interested me whether this castrol will be bad as a replacement :)
    As for the filter, it must be replaced. Oil according to the measuring cup.
    I took off the front cover of the piston and it is covered with burnt oil and the candle is also stained with burned oil. When starting the piston, a minimum amount of oil remains in the cylinder - I do not know if it should be like that.
    For now I'm waiting for info about this oil and after cleaning the case back I will fire up the goat
  • #4 12254315
    helena33
    Help: 94
    Rate: 730
    djpits wrote:
    will this castrol be bad as a replacement
    He will be very angry.
    You took off the heads, the carbon deposit needs to be removed, the candles replaced, the SAE 30 oil, the air filter. And when the engine is running, do not tilt it sideways or shine down, if you have a sloping ground to mow, try to drive uphill, the engine tilts the oil blowing to the air filter and from there to the engine. If traces of oil remain on the cylinder surface, it does not bode well, if there is no large threshold on the cylinder, you can replace the rings.
  • #5 12415080
    liseczq
    Help: 13
    Rate: 193
    Instead of SAE30, you can easily pour 10W40, 15W40 automotive oils into the mower.
    I have been using such mower oils for years and nothing is happening.
    For sure, car oil will be better than lawn mower oil.
  • #6 12415102
    jack63
    Help: 851
    Rate: 2822
    Helena33 Explain to us why "very angry". Please.
  • #7 12415126
    Megawe
    Help: 246
    Rate: 1437
    I pour the following oil into the lawn mower and outboard engine:
    MoS2-LEICHTLAUF 10W-40 from Liqui Moly.
    In the mower I remade the air intake, the filter is at the top by the handle. I ran a conduit from the filter to the carburetor.
  • #8 12415735
  • #9 12416724
    BANANvanDYK
    Help: 1167
    Rate: 2601
    SAE30 oil is designed to operate in an ambient temperature of 10 ° C - 30 ° C. Multigrade oil is not needed - unless you are mowing snow at -10 ° C.
    The API class is important, it will definitely run on SE - SG class oil, but I do not know the recommendations for these engines. You certainly do not need high-quality car oil with MoS2 additives.
  • #10 12416906
  • #11 12417362
    bartosz789
    Level 30  
    Help: 92
    Rate: 382
    So far, you haven't written why the car oil will be bad.
    Why buy another oil when you can use the one you have?
    Certainly the MoS2 additives will not harm the engine.
  • #12 18748674
    Hecht 548
    Hello dear group, I'm new here and I have such a problem with the hecht 5 KM mower, namely: you can hear a rattling in the engine, when there is new oil, it is not there, but after a month it returns, also when I lift the rear of the mower up and when I go down the mower also does not hear it even if there is old oil. I change the oil twice a season. I am attaching a video. [attach: 7fd729d9f8] [/ attach: 7fd729d9f8]
  • #13 18810417
    jacekxxx10
    Rate: 13
    You can use a different car oil, but within reason. Certainly, it cannot be synthetic oil, i.e. the one with the designation 0W ......, 5W ....... these are oils for modern car engines. The mower's engines are simple and you can't overdo it with oil. Mower manufacturers recommend SAE 30 10W30 oil. It is a low grade semi-synthetic oil - API SG. Personally, I would recommend 10W 40 - API SL car oil, it is also a cheap oil of a slightly higher quality. Its advantage is better lubrication and behavior on hot days, as indicated in the name by the number 40 (originally 30).
    Why is it worth flooding with car oil. For lawn mower oil, we pay about PLN 15 for 0.6 l, for a car with much better parameters, we also pay about PLN 15, but for a liter, we often have such oil.
    If the mower takes up too much oil, it can be flooded with 15W40 mineral oil. It is a thicker oil.
    Added after 33 [minutes]:
    Answering the question "djpits"
    Castrol 5W40 is not suitable, it is too rare, it will damage the mower in a short time.
    As for the 10W40 oil, I use the OPEL GM 10W40 SEMISYNTHETIC SL / CF A3 / B3 / B4 1L, it costs about PLN 14 per liter, 5 liters - about PLN 55 (allegro). This oil can be safely mowed on a hot day.
  • #14 18810464
    laufer888
    Level 19  
    Help: 25
    Rate: 37
    I have a B&S 5KM mower for about 18 years. I have been using 10W40 oil (different brands depending on what is left after replacing the car) from the moment of purchase. I change the oil +/- every 20 hours of operation 2 times a season. Weekly baskets of 15 acres of lawn. The mower does not pick up any oil. Filter - air insert every season. In addition, after each mowing, it is washed with a carcher from the bottom and the entire engine, although apparently it cannot. The engine works like new, the only repairs are welding the housing.
  • #15 18810491
    jacekxxx10
    Rate: 13
    "loufer888" I also have this opinion. 10W40 oil, no matter what. I just use the Opłowski because I have easy access to it. No semi-synthetic material knocks out the quality and content of cleaning agents, so it will not damage the mower.
  • Questioning 10W-40 versus 5W-30 for SAE 30 replacement
    #16 21542859
    qkohe155
    Hello, I wanted to join the topic. As someone already wrote, car oil is sometimes cheaper per litre, is always left over after a change and in theory should be better. I am therefore considering using one myself.
    Just the essential question is, which oil would be the best to replace SAE 30.
    I see a lot of people here recommending 10W-40, but why not 10W-30 or 5W-30? To my understanding such should be more like it? B&S sells 5W-30 synthetics in addition to the 30 oil as a premium or for winter running engines.
    I have 5W-30 and 5W-40 synthetics in my cars, will either of these be suitable or is it better not to risk it?
  • #17 21886524
    stratos37
    Rate: 125
    I have 5w40 oil, can I pour it into a powered lawnmower, OHV engine 173cm in size ?
    If not, why not?
  • 5W-30 works fine in B&S mower engine
    #18 21886639
    qkohe155
    I don't know, I'm guessing she'll be fine, but I don't want to mislead.
    As I wrote above - here they advised mainly 10W-40, and B&S sells 5W-30 (though not necessarily for mowers).
    I have one like you in 1 car and the 5W-30 mentioned in 2 and have since started pouring that.
    It certainly hasn't harmed the mower, in fact I feel it has helped. The Husqvarna LC353VI mower with the B&S 675iS engine is now almost 10 years old and very high mileage, and surprisingly it keeps going. Last year the stupid starter system died and I resignedly bought a tugger as a new one is pennies. Just as on more than one occasion it had to spin a bit to start, I pulled it now after winter and it started.
    Although this could be due to other factors that have coincided, such as the fact that I also bought a new carburettor last year as the throttle in the old one had broken, plus I stopped leaving fuel on over the winter and recently cleaned the spark plug.
    As for the oil change itself, I also bought a mth counter and found out that instead of 1, max 2 changes per season I have to do several, and I started to tilt the mower in 2 axles for draining instead of playing with that stupid pump, after which some is left anyway.
Discussion about oil choice for an aging Briggs & Stratton 6KM lawn mower engine that smokes and appears to consume oil. The main concern is whether Castrol Magnatec 5W-40 can be used instead of the recommended SAE 30 mower oil without damaging the engine. Replies explain that Briggs & Stratton typically recommends SAE 30 for warm conditions, with acceptable alternatives including 10W-30, 10W-40, 15W-40, or other detergent oils meeting API SF/SG/SH/SJ or higher. Several comments note that excessive smoke is more likely caused by a dirty air filter, overfilled oil, worn piston rings, cylinder wear, carbon deposits, or a faulty spark plug rather than the oil alone. Some users report long-term successful use of automotive 10W-40 oils in mower engines, while others caution that 5W-40 may be too thin for this application.
